Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
Tyranid Warrior Stats
 Post subject: Re: Tyranid Warrior Stats
PostPosted: Tue Feb 15, 2011 7:37 pm
15 or 20 cm movement depends on the synapse rules. I believe the 20 cm move is to be able to initiate engagements without transport options. This is not a major issue, since most Tyranid formations can march instead of double without loosing too much shooting anyway. However, if there is a synapse range involved, the 20 cms are needed to be able to launch engagements. 20 cms could easily be justified with Fleet or last edition's Leap ability.
I would like to echo Neal's sentiments. Restricting them to 15 cm opens up the possibility for winged warriors with worse save and Jump pack move.
/Fredmans
PostPosted: Tue Feb 15, 2011 8:04 pm
I'm obviously biased towards 15cm Inf.
The rest of the stats are ok. Keep the deathspitter as small arms and the save at 4+, as synapse the extra resilience helps. There really haven't been many changes or issues with them for quite a while (Apart from the LV issue). Shrikes will need to be forked to another unit so the winged option can be removed.
PostPosted: Tue Feb 15, 2011 11:09 pm
nealhunt wrote:
Same comment on the wings as for the Tyrants - 2 stat lines will make it easier to tweak the stats for balance.
Agree. It also offers 'options' which is what an assault force really needs.
PostPosted: Wed Feb 16, 2011 12:43 am
I thought there had been a long debate over LV / Infantry, that went something along the lines that if 'INF', it made the swarm very hard to destroy (similar debate to Chaos Obliterators :)), but if LV, it made them too easy to target. Does anyone remember the outcome of this??
I would tend to favour 20cm move, to allow the other brood creatures to move as intended but am not passionately attached to it.
PostPosted: Wed Feb 16, 2011 3:22 pm
I think moving them to LV was to compensate for the difficulty of getting BTS when it was tied to synapse creatures. If we're moving away from that then the need/want for the them to be LVs would go with it.
