[Units] Carnifex Armour Save
 Post subject: [Units] Carnifex Armour Save
PostPosted: Thu Dec 18, 2008 1:24 pm
Quote: (vytzka @ 18 Dec. 2008, 07:48 )
Actually Carnifex starts at +1 T over a Hive Tyrant.
Fully upgraded, a Carnifex will have +1 T and one more wound over Tyrant but will lack an invulnerable Warp Field save.
Unless there's been a correction I'm not aware of, my (4th Edition) Tyranid Codex lists T4, W6, SV 3+ for the base stats of both Hive Tyrant and Carnifex.
And, yes, different Genus of Carnifex could be "tougher", getting Thick Rear Armour or other variables/weapons.
IMO a fex should have better armour than a Tyrant (even though in 40k are about the same) to better represent its role in the brood.
Could you expand on what you mean by this SHermo?
PostPosted: Thu Dec 18, 2008 1:58 pm
What I was trying to say its that a fex has evolved to endure a great amount of pain and is considered the tanker of the brood so if a tyrant is as tough as a fex (in epic is weaker), it will lose personality.
I've always felt that in 40k, a Fex should be much tougher than a tyrant. In fact it's what it does best (that and wrecking tanks  :) )
PostPosted: Thu Dec 18, 2008 2:03 pm
Well, I could be wrong.
I would check the army summary sheet on the GW website. If, you know, it was possible to find one.
PostPosted: Thu Dec 18, 2008 3:39 pm
Enough with the stat crunching. :)
Fact is, they're close enough that they *could* have the same armour save.
Are 'fexes working properly in Epic?
IMO, not really; They could well do with going to RA 4+.
PostPosted: Thu Dec 18, 2008 4:09 pm
IIRC I wanted the Carnifex and Hive Tyrant to go up to 20cm speed, which in some regards is a *downgrade* as it stops them garrisoning (Which I regard as a bit odd). Conversely, late in the game it makes it a little bit easier for them to reach CC.
Chroma's seen my old proposed stats list.
