Laser Cut Command Terminals
 Post subject: Laser Cut Command Terminals
PostPosted: Mon Aug 27, 2018 11:40 pm
I've finished the cut/engrave files for the Warlord and thought I'd link here for comments and criticisms...
link
It's two layers of 1/16 acrylic. This graphic shows both.
The holes under the cards and Titan ID will go through the bottom layer so you can "poke" them up from underneath to change them out.
The dual circles for all the status holes are actually a small hole through the bottom, and then a "donut" ring in the upper layer in the appropriate color (green, white, yellow, orange, or red).
I've purposefully kept the fonts ultra-simple to make sure anyone could use the file, which is in Inkscape.
Comments?
 Post subject: Re: Laser Cut Command Terminals
PostPosted: Tue Aug 28, 2018 9:09 am
I prefer the look of full colour card terminals myself to plastic ones and would like to keep supporting the game so there's more chance of more things coming out.
Do whatever works for you though :)
PostPosted: Wed Aug 29, 2018 7:17 am
Heh-heh.
I don't think there's ANY risk of GW not getting enough of my money on this game...
