Post new topic Reply to topic  [ 316 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 22  Next
Malika's workshop (models for Vanguard Miniatures)
 Post subject: Re: Malika's workshop (models for Vanguard Miniatures)
PostPosted: Thu Oct 27, 2016 10:13 pm
malika2 wrote:
Curious to hear your thoughts!
+1, will buy, especially if available with a T26-esque companion light scout tank...
PostPosted: Fri Oct 28, 2016 6:43 am
Ragnarok can be only used in Baran Siege Masters list, but there is no problem using it as any other tank. I really like the look of Apocalypse tank and I will probably pick some up to use as Machariuses, because I prefer the look of Apoc tank.
Rrgarding tank suggestions, Valkyria Chronicels has some cool vehicles. They are prettt much some WWII tanks merged in one and they look really cool.
This particular is my favourite:
http://vignette4.wikia.nocookie.net/val ... 0317022640
It has Pz II turret with different barrel and front, Pz I hull, Pz II chassis and schürzen from Pz III.
Flickr|Flickr#2|Brickshefl
PostPosted: Fri Oct 28, 2016 11:07 am
That's a fun tank! Also note that lists are for a starting point and generally strict for tournament play only. Meaning someone that wants to use something from another list in friendly play is generally encouraged to discuss with their opponent to see how they feel about inclusion for that game. Of course that usually requires a very firm understanding of the lists in question and the knock on effects from a rules perspective to fully grok it (hence 'friendly' play :) )
You know what? You need to design a light tank with a dozer blade.that reassembles some of those early WW1 era designs. Something that say takes design hints from the Renault FT and the German Leichttraktor
PostPosted: Fri Oct 28, 2016 5:28 pm
Regarding the light tank, basically a tracked version of the Light Walkers right? Would like to do a kit like that, one with the standard scatter laser, and another one with a missile launcher turret.
Speaking of the Novan Light Walkers, how about some heavy walkers?
PostPosted: Fri Oct 28, 2016 10:44 pm
More walkers is always great!
PostPosted: Sat Oct 29, 2016 2:25 am
I'm not following you about the walkers there. If you mean simply replace the legs with track then no. If you mean fast scouting tank with a scatter laser then sure!
PostPosted: Sat Oct 29, 2016 5:42 pm
I meant the latter. In the background the light tanks were designed to replace the walkers due to difficult terrain. So not a walker cockpit with tracks, but actual light tanks with the same weapons as the light walkers.
PostPosted: Sat Oct 29, 2016 5:50 pm
yes good that then (provided it kinda looks like this) :D
PostPosted: Mon Oct 31, 2016 2:55 pm
By the way, if the light tanks were made to replace the light walkers, would there be any interest in a bi-ped walker version of the Centurion tanks?
PostPosted: Mon Oct 31, 2016 3:09 pm
You can just do light tanks looking like this and everyone will be happy (or I will make them happy >:D )
PostPosted: Mon Oct 31, 2016 3:34 pm
Hey, check your link, 'casue I see nothing there. Should it be 7TP light tank? ;)
++ DEATH FROM ABOVE! ++
PostPosted: Mon Oct 31, 2016 5:33 pm
Plan is to make a smaller and lighter version of the Apocalypse tank's hull and with a small turret on top. The basic kit will include both a missile/rocket launcher and scatter laser. Later on we might include other variants (laser cannon, automatic cannon, flame thrower, fusion cannon).
But yeah, no interest in walker versions of the Centurions?
PostPosted: Mon Oct 31, 2016 6:08 pm
I'm not sure we understand what that exactly means
PostPosted: Mon Oct 31, 2016 6:24 pm
Well, the Light Tank was designed as a replacement for the Light Walker. Taking that logic to a next step, there would be walker versions of the heavier tanks.
So basically a walker version of the Centurion tank, kinda akin to this or that, but with an aesthetic matching my other vehicle designs.
PostPosted: Mon Oct 31, 2016 6:57 pm
Give it a whirl!!
