Units not in the Imperial Guard list for Epic
 Post subject: Units not in the Imperial Guard list for Epic
PostPosted: Fri Apr 18, 2014 8:25 am
Games Workshop Guard Units not in Net Epic
Stormlord
Banehammer
Banesword
Hellhammer
Doomhammer
Stormsword
Tank Ace
Bullgryns
Taurox
Taurox Prime
Vendetta
Wyvern
Leman Russ Eradicator
Leman Russ Punisher
Devil Dog
Banewolf
Forgeworld Guard Units not in Net Epic
Centaur Artillery Tractor
Centaur Light Assault Carrier
Heavy Mortar
Earthshaker Gun
Medusa Gun
Tauros
Tauros Venator
Sabre Platform
Mukaali Rough Riders
Praetor Armoured Assault Launcher
Rassus Armoured Assaut Transport
Macharius
Macharius Omega
Macharius Vanquisher
Macharius Vulcan
Malcador
Malcador Defender
Malcador Annihilator
Malcador Infernus
Valdor
Minotaur
Leman Russ Annihilator
Colossus
Cyclops
Trojan
Atlas
Rightyus Indergestyun I
Stabb-Blasta II
Verum Irae II
 Post subject: Re: Units not in the Imperial Guard list for Epic
PostPosted: Fri Apr 18, 2014 3:15 pm
Impressive list. Ehm. "Counts as" is not kosher I gather?
PostPosted: Fri Apr 18, 2014 5:29 pm
We love coming up with stats! ;D
The trick is to make them different enough to matter on the table. But we try! :)
PostPosted: Fri Apr 18, 2014 7:50 pm
It's perfectly kosher as far as I'm concerned frankly I'm only bunging the lists up to get people to go hmm huuh and consider what needs and wants to be added.
Stabb-Blasta II
Verum Irae II
PostPosted: Sat Apr 19, 2014 3:13 am
I'm sure we'll give it our best shot to include as many as we can. :)
PostPosted: Sat Apr 19, 2014 9:53 am
Rug wrote:
Thanks for the list! I'll go through this and have a think...
Netepic
www.epic-uk.co.uk
PostPosted: Sat Apr 19, 2014 10:31 am
Yeah, absolutely everything to be included, then it will be up players to work out what models to use for them, either proxies, conversions or sourced from other places ;)
PostPosted: Sat Apr 19, 2014 6:38 pm
Stormsword
Earthshaker Gun
Medusa Gun
Sabre Platform
Colossus
Cyclops
Actually, NetEpic already has units for the above, unless you are saying that the current 40K units of those names are significantly different than the NetEpic ones.
Stormsword, Earthshaker, Medusa, & Sabre are all named & detailed specifically in the Adeptus Militaris PDF. The Centaur Artillery Tractor seems to be present as well, but is just called Artillery Tractor. Colossus and Cyclops are in the Squat PDF.
Net Epic Coordinator
PostPosted: Sat Apr 19, 2014 6:57 pm
MagnusIlluminus wrote:
Stormsword
Earthshaker Gun
Medusa Gun
Sabre Platform
Colossus
Cyclops
Amusingly they aren't the ones in the squat book ;)
The guard Colossus is a rare type of artillery tank and the Cyclops is a miniature demolition vehicle.
Guess much of what is in the PDF list should be rolled into the standard guard list.
Matt
PostPosted: Sat Apr 19, 2014 9:14 pm
Stormsword
Earthshaker Gun
Medusa Gun
Sabre Platform
Colossus
Cyclops
The PDF list probably needs a big revision. It's supposed t be a very "basic" force with lots of static defense and few special vehicles.
Matt
PostPosted: Sat Apr 19, 2014 11:05 pm
Did you have something to add there Primarch? You seem to have forgotten to type it... Whoops, I see it now, you included it in with the quoted bit. Slightly confusing there.
Doesn't surprise me that they are different from the Squat units. GW does like to reuse names.
Actually, Primarch does bring up a good point. For all of these new units it will have to be determined whether to place them in just one list or to put them in both lists. The lists being: Imperial Guard and Planetary Defense Force. Assuming the two are kept separate that is.
PostPosted: Sat Apr 19, 2014 11:22 pm
Right I included them because
Centaur-Doesn't actually use the Centaur in front of the Artillery Tractor entry they might be different I don't know
Earthshaker Gun/Medusa Gun- The Medusa is a vehicle the Forgeworld unit I'm referring to is a field piece. The Earthshaker is in the PDF but not the regular list.
Sabre Platform is a manned defense gun apparently dirt in tournaments while a Sabre Tank Hunter is a vehicle and totally different
Matts perfectly right with the Cyclops and Colossus.
The Stormsword I goofed getting it and the Net Epic Stormblade confused
Stabb-Blasta II
Verum Irae II
