Gold Summary for Squats
 Post subject: Gold Summary for Squats
PostPosted: Mon Apr 07, 2014 11:56 pm
Summary
1. increase cost of biker squads from 200 to 250 points
2. increase cost of guild biker company from 600 to 700 points (to reflect new cost of bikes), remove the "unique".
3. increase cost of Colossus from 500 to 600 points
4. increase cost of Cyclops from 450 to 500 points
5. increase cost of Leviathan from 350 to 400 points (no change for the IronBreaker company)
6. increase cost of the DoomAnvil Squadron from 1400 to 1600 points (break point should be "each", morale: "-" and VP "each"
7. Edit some of the company compositions for better clarity.
8. Reword for better clarity the process of firing and inflicting damage from the Cyclops.
 Post subject: Re: Gold Summary for Squats
PostPosted: Mon Apr 21, 2014 11:38 pm
Again...these are for platinum right?
Also, even with an increase in cost to 700 there's still no way I'd remove unique from the Guild Bikers. Maybe at 900....
Dont understand the imperative to up the cost of the pretty feeble Leviathan, or the Cyclops for that matter. One thing you could do is fix the fire arc for the side weapons to be 180 degrees left x3 and right x3. Colossus is arguably a bit cheap, but against some armies it is just crunchy points....I'm looking at you Tyranids!
PostPosted: Tue Apr 22, 2014 1:10 am
These are the changes for gold.
If you have data to suggest against any of these, now is the time to post them. :)
PostPosted: Wed Apr 23, 2014 7:23 am
Hi zap,
I've tested all those costs since few years now and they work well.
increase points on praetorians is logical as they now benefit a template that give them a better chance to survive on battlefield.
At least, those new costs put the squat army back in the game against other armies (tested vs IG, TL, Orks...) "except" tyranids. Imho, it's not really fair to keep the squats so high in performance just because of the tyranid list that's still over them.
About the "too good" squat cavalry, the "unique" ability on the card was an "easy" solution to restrict presence of bikers on the battlefield but honestly, it was not that restrictive. You could still pick 1 guild biker company and add many biker support cards at 200 points...
If the bikers are too good at 200 points for a detachment, we have 3 solutions to avoid "unique":
- reduce caf
- increase cost
- reduce caf & increase cost
I've tested the 2nd solution, giving it a try and with praetorian cost increase, it works pretty well.
PostPosted: Wed Apr 23, 2014 10:53 am
I'm not in favour of reintroducing restrictive fire arcs. I remember these well from 1st Edition Epic. They were a pain in the arse and players would waste a lot of time trying to get their minis facing an enemy unit dead on so they could use the weaponry from both sides.
I don't see the Leviathan as feeble. Just compare it to a similarly costed Reaver Titan. It has better weaponry, as many void shields and hit locations just the same as the Reaver. The 350 was fine when it just used to be a 1+ save for the Leviathan. The introduction of the damage tables has granted them increased longevity on the battlefield. I'd argue we should consider increasing their cost by another 50 points...
PostPosted: Wed Apr 23, 2014 6:30 pm
In my experience a cost increase is enough. The addition of a hit location template adds a lot of durability. While a titan may have better firepower, the preatorians generally have better survivability.
The cost increase is the easiest method of balance.
PostPosted: Thu Apr 24, 2014 8:46 am
At the moment, +50 for each praetorian and +100 for colossus is enough. Don't forget that they are very slow in comparison to a reaver and they don't benefit the "titan defense rule" (they can be surrounded in CC by any models).
PostPosted: Thu Apr 24, 2014 5:42 pm
Agreed. The increase is justified at what it currently is, any more would be too penalizing.
