Post new topic Reply to topic  [ 128 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
Army List: Imperial Guard
 Post subject: Re: Army List: Imperial Guard
PostPosted: Fri May 02, 2014 9:50 pm
MagnusIlluminus wrote:
Noted. Means their cost (for Transport) goes up a bit.
That is fine, to have such flexibility in transport should be a premium price.
PostPosted: Fri Jul 11, 2014 6:17 am
Just noticed a thing.
In the entry for Colonel & Major (page 11 of the pdf) it reads: "... they may change the orders of one Imperial Guard detachment that is within 25 cm..."
This seems odd as they may also be selected as Special formations on the Planetary Defense Forces list. I'm guessing the specific mention of Imperial Guard is a typo and they would also be able to affect PDF troops as well.
Net Epic Coordinator
PostPosted: Fri Jul 11, 2014 4:06 pm
I believe you are correct and it is a typo/omission.
PostPosted: Sun Aug 24, 2014 5:06 pm
As I construct the corrections master PDF and focus my attention on the IG transports. Since all integrated transport formations are being removed, I would need the cost of ONE gorgon according to the old Gold way of pricing them.
Is 100 points per gorgon sufficient?
PostPosted: Sun Aug 24, 2014 6:50 pm
Personally, I've been using a value of 75 for the Gorgon at Gold level.
However, I thought that we were NOT changing any Gold level formations. All of the changes of that nature were for Platinum. I will admit that it has been a while since I've gone through this thread, but my recollection at the moment is that Gold was not being changed to that degree.
PostPosted: Sun Aug 24, 2014 10:31 pm
The gold summary thread for IG mentions that transport will not be integrated and people can "add them on". It also mentions options for the gorgons, thus my question.
I will use the value of 75 points you mentioned for them.
The use of integrated transport options was "optional" under gold (thus the Astrix on them). Now they will be separate for people to use or not. :)
PostPosted: Mon Aug 25, 2014 1:59 am
Integrated Transport was optional in Gold. Fascinating. Every listed formation currently in Gold (that includes Transports) just lists them as being a part of the formation. No notation of them being optional. I cannot see where you are getting "they are already optional" from at all.
That said, I am aware of the "Footsloggers" rule in the Core, but that seems to me like the option, and Integrated Transports is the standard.
If people decided that they would rather the Transports be optional, that's fine. But as far as I can tell, at the moment they are standard rules.
PostPosted: Mon Aug 25, 2014 3:53 am
If you go to the Adpetus Militaris book starting on page 27, all companies listed under "mechanized infantry" have one asterisk next to their title (except mole and hellbore companies that have two).
On page 28 and following pages after this it is noted that one asterisk means "optional unit, requires consent of all players to use".
In fact there are quite a few formation with this one asterisk in that book, denoting their "optional status".
With the sole exception of the gorgon tactical company, hellbore company and mole company all the rest that have integrated transport have the asterisk.
Strangely enough I counted about 48 formations (out of approximately 113) between pages 27-30 that had the asterisk marking them as optional.
That's quite bit of optional formations. ;)
I also think that this is a holdover from when the revision was going on, nearly 12 years ago. :)
PostPosted: Tue Aug 26, 2014 2:04 pm
Oh, you meant that the entire formation is optional. Gotcha. I thought you were saying that the formation having Transports in it was in and of itself optional. That makes sense then.
Frankly, noting any formations as "requires consent" at this point is probably silly, as all of the models are long out of production.
PostPosted: Tue Aug 26, 2014 3:26 pm
Agreed. While I won't change it in Gold, we will certainly dispense with it in Platinum.
I have made good progress on the errata PDF summary for gold changes. I am making it in such a way that if you printed out the book, all you need is this PDF.
Once I finish it I will post it on the forums for general commentary as I begin editing the master gold files to incorporate the changes.
I expect to do this fairly swiftly. :)
PostPosted: Tue Mar 03, 2015 4:01 am
I just looked at the errata added version of the Adeptus Militaris pdf to see how you altered the Companies as the errata document says that you were removing transports from them. At least, it seemed to say that, as I see that you did not remove any formations with transports in them. Which is confusing.
To add to the confusion, you changed the Support formations for Chimera (and variants) to just be adding to an existing formation. I strongly dislike this. The Guard are not Orks, they just don't work that way. Also, what about people who might want to take (as a random example) a Support formation of Chimerax for a Vindicator Company? They cannot do that now. It is also going to be more difficult to do the Points Formula values for this.
Even though it is good to now have a Support Formation for the Gorgon, it is in the wrong sub-list. It should be in with the Super Heavy, as that is what it is. You have also missed a few transport options.
Hmm, I'm going to have to go into more detail with the next tweak listings for the Guard as to their options for formations both with and without included transports. I'll be working that up as soon as I can. In the mean time, I'd suggest reverting the Chimera (& variant) Support Formations to their previous format.
PostPosted: Tue Mar 03, 2015 4:29 pm
The add on transport was what seem most wanted, if I recall correctly. :)
As for what I left in, its a formatting issue. I'm not too proficient with Indesign, so deleting things and adding them may prove tricky since it alters the format in which it is done. It took me a while to even do the little I did without totally screwing it up. ;)
Tell you what, forward to me how you think the all this should look like and I will shift all the IG vehicle support things to a separate PDF that can be downloaded. So Gold stays in the original format for IG and then there will be an add-on for those whom like it that way.
I probably should have done this from the get go, but its not a big deal to do this now. :)
PostPosted: Tue Mar 03, 2015 8:10 pm
Ah, right. That sounds familiar that people wanted the transports to be able to be added on. However, that should probably be done more like Platinum is doing it. IE without using up Support formations. In other words, list the companies without any transports, then list the options for transports and their costs. Then Special formations, then Support formations. Adding transports to a formation should not use up another formation slot. Well, in my opinion anyway. I guess if most people wanted that done via Support formations then that is different.
Yeah, formatting issues can get tricky.
While I don't have a final list just yet, I am currently working on Guard formations. While doing this, I have (again) noticed the discrepancy of some formations having 10, 6, or 5 stands. Sometimes for no discernible reason. So I've kept all of them, just to give people more options. At the moment, I'm referring to any formation with 10 stands as a "Legion", ones with 6 stands as a "Platoon", and ones with 5 as a "Squad". With a few exceptions.
Consider the following a preview of the second tweak run. I have not yet done the Company formations, but here are the Infantry-based Special and Support formations. Note also that many of these are 'new' formations, but based on existing ones. Any formation presented here that is not in the Gold pdf (and some that are) should be considered 'optional'.
_Formation Name _____ Contents _______ BP _ Morale _ VP _ Cost
_ Adeptus Mechanicus:
Foot _____ 2 AM stands ___________________ 2 _ - _ 1 __ 75
Bike _____ 2 AM Bike stands ______________ 2 _ - _ 1 _ 107
Horse ____ 2 AM Horse stands _____________ 2 _ - _ 1 __ 91
Speeder __ 2 AM Speeders _________________ 2 _ - _ 1 _ 145
Chimera __ 2 AM stands, Command Chimera __ 2 _ - _ 1 __ 86
Chimedon _ 2 AM stands, Command Chimedon _ 2 _ - _ 1 __ 95
Chimerax _ 2 AM stands, Command Chimerax _ 2 _ - _ 1 __ 87
Chimerro _ 2 AM stands, Command Chimerro _ 2 _ - _ 1 __ 89
Rhino ____ 2 AM stands, Command Rhino ____ 2 _ - _ 1 __ 85
Gorgon ___ 2 AM stands, Command Gorgon ___ 2 _ - _ 2 _ 158
Valkyrie _ 2 AM stands, Command Valkyrie _ 2 _ - _ 2 _ 197
Termite __ 2 AM stands, Command Termite __ 2 _ - _ 1 __ 86
_ Adeptus Psyker:
Foot _____ AP stand ___________________ stand _ - _ 1 __ 29
Bike _____ AP Bike stand ______________ stand _ - _ 1 __ 42
Horse ____ AP Horse stand _____________ stand _ - _ 1 __ 36
Speeder __ AP Speeder _________________ stand _ - _ 1 __ 60
Chimera __ AP stand, Command Chimera __ stand _ - _ 1 __ 43
Chimedon _ AP stand, Command Chimedon _ stand _ - _ 1 __ 42
Chimerax _ AP stand, Command Chimerax _ stand _ - _ 1 __ 39
Chimerro _ AP stand, Command Chimerro _ stand _ - _ 1 __ 40
Rhino ____ AP stand, Command Rhino ____ stand _ - _ 1 __ 43
Gorgon ___ AP stand, Command Gorgon ___ stand _ - _ 1 __ 70
Valkyrie _ AP stand, Command Valkyrie _ stand _ - _ 1 __ 73
Termite __ AP stand, Command Termite __ stand _ - _ 1 __ 39
_ Astropath:
Foot _____ Astropath stand ___________________ stand _ - _ 1 __ 37
Bike _____ Astropath Bike stand ______________ stand _ - _ 1 __ 49
Horse ____ Astropath Horse stand _____________ stand _ - _ 1 __ 43
Speeder __ Astropath Speeder _________________ stand _ - _ 1 __ 68
Chimera __ Astropath stand, Command Chimera __ stand _ - _ 1 __ 51
Chimedon _ Astropath stand, Command Chimedon _ stand _ - _ 1 __ 49
Chimerax _ Astropath stand, Command Chimerax _ stand _ - _ 1 __ 47
Chimerro _ Astropath stand, Command Chimerro _ stand _ - _ 1 __ 48
Rhino ____ Astropath stand, Command Rhino ____ stand _ - _ 1 __ 51
Gorgon ___ Astropath stand, Command Gorgon ___ stand _ - _ 1 __ 78
Valkyrie _ Astropath stand, Command Valkyrie _ stand _ - _ 1 __ 80
Termite __ Astropath stand, Command Termite __ stand _ - _ 1 __ 47
_ Confessor:
Foot _____ Cf stand ___________________ stand _ - _ 1 __ 83
Bike _____ Cf Bike stand ______________ stand _ - _ 1 _ 107
Horse ____ Cf Horse stand _____________ stand _ - _ 1 __ 95
Speeder __ Cf Speeder _________________ stand _ - _ 1 _ 128
Chimera __ Cf stand, Command Chimera __ stand _ - _ 1 __ 96
Chimedon _ Cf stand, Command Chimedon _ stand _ - _ 1 __ 95
Chimerax _ Cf stand, Command Chimerax _ stand _ - _ 1 __ 93
Chimerro _ Cf stand, Command Chimerro _ stand _ - _ 1 __ 93
Rhino ____ Cf stand, Command Rhino ____ stand _ - _ 1 __ 96
Gorgon ___ Cf stand, Command Gorgon ___ stand _ - _ 1 _ 123
Valkyrie _ Cf stand, Command Valkyrie _ stand _ - _ 1 _ 126
Termite __ Cf stand, Command Termite __ stand _ - _ 1 __ 92
_ Forward Observer:
Foot _____ 2 FO stands ___________________ 2 _ - _ 1 __ 85
Chimera __ 2 FO stands, Stealth Chimera __ 2 _ - _ 1 _ 107
Rhino ____ 2 FO stands, Stealth Rhino ____ 2 _ - _ 1 _ 105
_ Inquisitor:
Foot _____ Inq stand ___________________ stand _ - _ 2 _ 199
Bike _____ Inq Bike stand ______________ stand _ - _ 3 _ 266
Horse ____ Inq Horse stand _____________ stand _ - _ 2 _ 232
Speeder __ Inq Speeder _________________ stand _ - _ 3 _ 326
Chimera __ Inq stand, Command Chimera __ stand _ - _ 2 _ 213
Chimedon _ Inq stand, Command Chimedon _ stand _ - _ 2 _ 211
Chimerax _ Inq stand, Command Chimerax _ stand _ - _ 2 _ 209
Chimerro _ Inq stand, Command Chimerro _ stand _ - _ 2 _ 210
Rhino ____ Inq stand, Command Rhino ____ stand _ - _ 2 _ 212
Gorgon ___ Inq stand, Command Gorgon ___ stand _ - _ 2 _ 240
Valkyrie _ Inq stand, Command Valkyrie _ stand _ - _ 2 _ 243
Termite __ Inq stand, Command Termite __ stand _ - _ 2 _ 209
_ Ordo-Malleus Inqstr:
Foot _____ OMI stand ___________________ stand _ - _ 1 _ 137
Bike _____ OMI Bike stand ______________ stand _ - _ 2 _ 204
Horse ____ OMI Horse stand _____________ stand _ - _ 2 _ 170
Speeder __ OMI Speeder _________________ stand _ - _ 3 _ 327
Chimera __ OMI stand, Command Chimera __ stand _ - _ 2 _ 213
Chimedon _ OMI stand, Command Chimedon _ stand _ - _ 2 _ 211
Chimerax _ OMI stand, Command Chimerax _ stand _ - _ 2 _ 209
Chimerro _ OMI stand, Command Chimerro _ stand _ - _ 2 _ 210
Rhino ____ OMI stand, Command Rhino ____ stand _ - _ 2 _ 212
Gorgon ___ OMI stand, Command Gorgon ___ stand _ - _ 2 _ 240
Valkyrie _ OMI stand, Command Valkyrie _ stand _ - _ 2 _ 243
Termite __ OMI stand, Command Termite __ stand _ - _ 2 _ 209
_ Battilion Command:
Foot _____ Major stand, 5 Tactical stands _____________ Major _ 3 _ 1 __ 56
Bike _____ Major on Bike, 5 Imperial Bike _____________ Major _ 3 _ 1 __ 73
Horse ____ Major on Horse, 5 Rough Rider ______________ Major _ 3 _ 1 __ 95
Speeder __ Major in Speeder, 5 Land Speeders __________ Major _ 3 _ 1 __ 83
Chimera __ Major stand, 5 Tactical stands, 3 Chimera __ Major _ 3 _ 1 __ 73
Chimedon _ Major stand, 5 Tactical stands, 3 Chimedon _ Major _ 3 _ 1 __ 80
Chimerax _ Major stand, 5 Tactical stands, 3 Chimerax _ Major _ 3 _ 1 __ 76
Chimerro _ Major stand, 5 Tactical stands, 3 Chimerro _ Major _ 3 _ 1 __ 77
Rhino ____ Major stand, 5 Tactical stands, 3 Rhino ____ Major _ 3 _ 1 __ 72
Gorgon ___ Major stand, 5 Tactical stands, Gorgon _____ Major _ 3 _ 1 __ 78
Valkyrie _ Major stand, 5 Tactical stands, 3 Valkyrie _ Major _ 3 _ 1 _ 119
Termite __ Major stand, 5 Tactical stands, 3 Termite __ Major _ 3 _ 1 __ 73
_ Regimental Command:
Foot _____ Colonel stand, 5 Tactical stands _____________ Colonel _ 2 _ 1 __ 93
Bike _____ Colonel on Bike, 5 Imperial Bike _____________ Colonel _ 2 _ 1 _ 113
Horse ____ Colonel on Horse, 5 Rough Rider ______________ Colonel _ 2 _ 1 _ 136
Speeder __ Colonel in Speeder, 5 Land Speeders __________ Colonel _ 2 _ 1 _ 124
Chimera __ Colonel stand, 5 Tactical stands, 3 Chimera __ Colonel _ 2 _ 1 _ 113
Chimedon _ Colonel stand, 5 Tactical stands, 3 Chimedon _ Colonel _ 2 _ 1 _ 120
Chimerax _ Colonel stand, 5 Tactical stands, 3 Chimerax _ Colonel _ 2 _ 1 _ 115
Chimerro _ Colonel stand, 5 Tactical stands, 3 Chimerro _ Colonel _ 2 _ 1 _ 117
Rhino ____ Colonel stand, 5 Tactical stands, 3 Rhino ____ Colonel _ 2 _ 1 _ 111
Gorgon ___ Colonel stand, 5 Tactical stands, Gorgon _____ Colonel _ 2 _ 1 _ 117
Valkyrie _ Colonel stand, 5 Tactical stands, 3 Valkyrie _ Colonel _ 2 _ 2 _ 162
Termite __ Colonel stand, 5 Tactical stands, 3 Termite __ Colonel _ 2 _ 1 _ 112
_ Support Formations
_ No Transports
Assault Squad ____ 5 Assault stands ___ 3 ____ 4 __ 1 __ 62
Assault Platoon __ 6 Assault stands ___ 3 ____ 4 __ 1 __ 61
Beastmen: _______ 10 Beastmen stands __ 5 ____ 4 __ 1 _ 104
Engineer: ________ 5 Engineer stands ___ 3 ___ 4 __ 1 __ 51
Heavy Squad ______ 5 Heavy stands _______ 3 __ 4 __ 2 __ 54
Heavy Platoon ____ 6 Heavy stands ________ 3 __ 4 _ 1 __ 53
Ogryn: ___________ 4 Ogryn stands _________ 2 _ 3 _ 1 __ 91
Ratling: _________ 4 Ratling stands _______ 2 _ 4 _ 3 _ 266
Storm Trooper: ___ 6 Storm Trooper stands _ 3 _ 3 _ 1 __ 85
Tactical Legion _ 10 Tactical stands ______ 5 _ 4 _ 1 __ 40
Tactical Platoon _ 6 Tactical stands ______ 3 _ 4 _ 1 __ 26
Tactical Squad ___ 5 Tactical stands ______ 3 _ 4 _ 1 __ 27
_ Mechanized: Chimera
Assault Sq __ 5 Assault stands, 3 Chimera __ 4 _ 4 _ 1 __ 92
Assault Plt _ 6 Assault stands, 3 Chimera __ 5 _ 4 _ 1 _ 113
Beastmen ___ 10 Beastmen stands, 5 Chimera _ 8 _ 4 _ 2 _ 182
Engineer ____ 5 Engineer stands, 3 Chimera _ 4 _ 4 _ 1 __ 83
Heavy Sq ____ 5 Heavy stands, 3 Chimera ____ 4 _ 4 _ 2 __ 85
Heavy Plt ___ 6 Heavy stands, 3 Chimera ____ 5 _ 4 _ 1 _ 104
Storm Trooper _ 6 ST stands, 3 Chimera _____ 5 _ 3 _ 1 _ 144
Tactical Lgn _ 10 Tactical stands, 3 Chimera _ 8 _ 4 _ 1 _ 118
Tactical Plt __ 6 Tactical stands, 3 Chimera _ 5 _ 4 _ 1 __ 74
Tactical Sq ___ 5 Tactical stands, 3 Chimera _ 4 _ 4 _ 1 __ 63
_ Mechanized: Chimedon
Assault Sq __ 5 Assault stands, 3 Chimedon __ 4 _ 4 _ 1 _ 107
Assault Plt _ 6 Assault stands, 3 Chimedon __ 5 _ 4 _ 1 _ 130
Beastmen ___ 10 Beastmen stands, 5 Chimedon _ 8 _ 4 _ 2 _ 209
Engineer ____ 5 Engineer stands, 3 Chimedon _ 4 _ 4 _ 1 __ 98
Heavy Sq ____ 5 Heavy stands, 3 Chimedon ____ 4 _ 4 _ 1 _ 100
Heavy Plt ___ 6 Heavy stands, 3 Chimedon ____ 5 _ 4 _ 1 _ 121
Storm Trooper _ 6 ST stands, 3 Chimedon _____ 5 _ 3 _ 2 _ 162
Tactical Lgn _ 10 Tactical stands, 3 Chimedon _ 8 _ 4 _ 1 _ 145
Tactical Plt __ 6 Tactical stands, 3 Chimedon _ 5 _ 4 _ 1 __ 91
Tactical Sq ___ 5 Tactical stands, 3 Chimedon _ 4 _ 4 _ 1 __ 78
_ Mechanized: Chimerax
Assault Sq __ 5 Assault stands, 3 Chimerax __ 4 _ 4 _ 1 __ 97
Assault Plt _ 6 Assault stands, 3 Chimerax __ 5 _ 4 _ 1 _ 118
Beastmen ___ 10 Beastmen stands, 5 Chimerax _ 8 _ 4 _ 2 _ 191
Engineer ____ 5 Engineer stands, 3 Chimerax _ 4 _ 4 _ 1 __ 88
Heavy Sq ____ 5 Heavy stands, 3 Chimerax ____ 4 _ 4 _ 1 __ 90
Heavy Plt ___ 6 Heavy stands, 3 Chimerax ____ 5 _ 4 _ 1 _ 109
Storm Trooper _ 6 ST stands, 3 Chimerax _____ 5 _ 3 _ 2 _ 150
Tactical Lgn _ 10 Tactical stands, 3 Chimerax _ 8 _ 4 _ 1 _ 127
Tactical Plt __ 6 Tactical stands, 3 Chimerax _ 5 _ 4 _ 1 __ 79
Tactical Sq ___ 5 Tactical stands, 3 Chimerax _ 4 _ 4 _ 1 __ 68
_ Mechanized: Chimerro
Assault Sq __ 5 Assault stands, 3 Chimerro __ 4 _ 4 _ 1 _ 100
Assault Plt _ 6 Assault stands, 3 Chimerro __ 5 _ 4 _ 1 _ 122
Beastmen ___ 10 Beastmen stands, 5 Chimerro _ 8 _ 4 _ 2 _ 196
Engineer ____ 5 Engineer stands, 3 Chimerro _ 4 _ 4 _ 1 __ 91
Heavy Sq ____ 5 Heavy stands, 3 Chimerro ____ 4 _ 4 _ 1 __ 93
Heavy Plt ___ 6 Heavy stands, 3 Chimerro ____ 5 _ 4 _ 1 _ 113
Storm Trooper _ 6 ST stands, 3 Chimerro _____ 5 _ 3 _ 2 _ 154
Tactical Lgn _ 10 Tactical stands, 3 Chimerro _ 8 _ 4 _ 1 _ 133
Tactical Plt __ 6 Tactical stands, 3 Chimerro _ 5 _ 4 _ 1 __ 83
Tactical Sq ___ 5 Tactical stands, 3 Chimerro _ 4 _ 4 _ 1 __ 71
_ Mechanized: Rhino
Assault Sq __ 5 Assault stands, 3 Rhino __ 4 _ 4 _ 1 __ 92
Assault Plt _ 6 Assault stands, 3 Rhino __ 5 _ 4 _ 1 _ 112
Beastmen ___ 10 Beastmen stands, 5 Rhino _ 8 _ 4 _ 2 _ 175
Engineer ____ 5 Engineer stands, 3 Rhino _ 4 _ 4 _ 1 __ 83
Heavy Sq ____ 5 Heavy stands, 3 Rhino ____ 4 _ 4 _ 1 __ 85
Heavy Plt ___ 6 Heavy stands, 3 Rhino ____ 5 _ 4 _ 1 _ 103
Storm Trooper _ 6 ST stands, 3 Rhino _____ 5 _ 3 _ 1 _ 143
Tactical Lgn _ 10 Tactical stands, 3 Rhino _ 8 _ 4 _ 1 _ 112
Tactical Plt __ 6 Tactical stands, 3 Rhino _ 5 _ 4 _ 1 __ 73
Tactical Sq ___ 5 Tactical stands, 3 Rhino _ 4 _ 4 _ 1 __ 62
_ Mechanized: Gorgon
Assault Sq __ 5 Assault stands, Gorgon ____ 3 _ 4 _ 1 _ 106
Assault Plt _ 6 Assault stands, Gorgon ____ 4 _ 4 _ 1 _ 127
Beastmen ___ 10 Beastmen stands, 2 Gorgon _ 6 _ 4 _ 2 _ 204
Engineer ____ 5 Engineer stands, Gorgon ___ 3 _ 4 _ 1 __ 93
Heavy Sq ____ 5 Heavy stands, Gorgon ______ 3 _ 4 _ 1 __ 95
Heavy Plt ___ 6 Heavy stands, Gorgon ______ 4 _ 4 _ 1 _ 118
Storm Trooper _ 6 ST stands, Gorgon _______ 4 _ 3 _ 2 _ 160
Tactical Lgn _ 10 Tactical stands, 2 Gorgon _ 6 _ 4 _ 1 _ 141
Tactical Plt __ 6 Tactical stands, Gorgon ___ 4 _ 4 _ 1 __ 87
Tactical Sq ___ 5 Tactical stands, Gorgon ___ 3 _ 4 _ 1 __ 73
_ Mencahized: Valkyrie
Assault Sq __ 5 Assault stands, 3 Valkyrie __ 4 _ 4 _ 2 _ 209
Assault Plt _ 6 Assault stands, 3 Valkyrie __ 5 _ 4 _ 2 _ 243
Beastmen ___ 10 Beastmen stands, 5 Valkyrie _ 8 _ 4 _ 4 _ 390
Engineer ____ 5 Engineer stands, 3 Valkyrie _ 4 _ 4 _ 2 _ 200
Heavy Sq ____ 5 Heavy stands, 3 Valkyrie ____ 4 _ 4 _ 2 _ 202
Heavy Plt ___ 6 Heavy stands, 3 Valkyrie ____ 5 _ 4 _ 2 _ 234
Storm Trooper _ 6 ST stands, 3 Valkyrie _____ 5 _ 3 _ 3 _ 287
Tactical Lgn _ 10 Tactical stands, 3 Valkyrie _ 8 _ 4 _ 3 _ 327
Tactical Plt __ 6 Tactical stands, 3 Valkyrie _ 5 _ 4 _ 2 _ 204
Tactical Sq ___ 5 Tactical stands, 3 Valkyrie _ 4 _ 4 _ 2 _ 180
_ Mechanized: Termite
Assault Sq __ 5 Assault stands, 3 Termite __ 4 _ 4 _ 1 __ 92
Assault Plt _ 6 Assault stands, 3 Termite __ 5 _ 4 _ 1 _ 112
Beastmen ___ 10 Beastmen stands, 5 Termite _ 8 _ 4 _ 2 _ 153
Engineer ____ 5 Engineer stands, 3 Termite _ 4 _ 4 _ 1 __ 83
Heavy Sq ____ 5 Heavy stands, 3 Termite ____ 4 _ 4 _ 1 __ 85
Heavy Plt ___ 6 Heavy stands, 3 Termite ____ 5 _ 4 _ 1 _ 103
Storm Trooper _ 6 ST stands, 3 Termite _____ 5 _ 3 _ 1 _ 143
Tactical Lgn _ 10 Tactical stands, 3 Termite _ 8 _ 4 _ 1 __ 90
Tactical Plt __ 6 Tactical stands, 3 Termite _ 5 _ 4 _ 1 __ 73
Tactical Sq ___ 5 Tactical stands, 3 Termite _ 4 _ 4 _ 1 __ 62
_ Mechanized: Mole
Assault Sq ____ 5 Assault stands, Mole __ 3 _ 4 _ 1 __ 90
Assault Plt ___ 6 Assault stands, Mole __ 4 _ 4 _ 1 _ 108
Beastmen _____ 10 Beastmen stands, Mole _ 6 _ 4 _ 1 _ 149
Engineer ______ 5 Engineer stands, Mole _ 3 _ 4 _ 1 __ 76
Heavy Sq ______ 5 Heavy stands, Mole ____ 3 _ 4 _ 1 __ 78
Heavy Plt _____ 6 Heavy stands, Mole ____ 4 _ 4 _ 1 __ 99
Storm Trooper _ 6 ST stands, Mole _______ 4 _ 3 _ 1 _ 139
Tactical Lgn _ 10 Tactical stands, Mole _ 6 _ 4 _ 1 __ 81
Tactical Plt __ 6 Tactical stands, Mole _ 4 _ 4 _ 1 __ 68
Tactical Sq ___ 5 Tactical stands, Mole _ 3 _ 4 _ 1 __ 56
PostPosted: Tue Mar 03, 2015 8:32 pm
I just realized that all of the costs for "... on Bike", "... on Horse", and "... in Speeder" are a bit off. I'm not going to change them above, as that is really just to show you where I'm going with formations.
The Company formations will most likely follow the same format as the Support ones listed above.
PostPosted: Tue Mar 03, 2015 8:34 pm
Let me know how you want them to look like and I will "parse out" the appropriate sections into a stand alone PDF and leave the original formations as you determine they should be laid out in the Gold book.
Thanks!
