Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Points formula values for NE Gold Marines
 Post subject: Re: Points formula values for NE Gold Marines
PostPosted: Sat Sep 06, 2014 7:09 am
The base values for the Razorback are slightly lower here as I seem to have forgotten to apply the 'linked' modifier to its weapons until now. Sigh.
Note that applying the changes that affect it breaks the Rapier as a usable formation. I'm not sure how to fix this.
Net Epic Coordinator
PostPosted: Sat Sep 06, 2014 4:54 pm
Could you go in to this a little bit more? I want to make sure I understand the issue, before suggesting a fix.
Thanks!
PostPosted: Sat Sep 06, 2014 7:41 pm
Presuming you mean the Rapier. I'm only looking at model values in this post.
In the basic run, the Rapier has a value of 18. This comes from:
Light Artillery (value of 3) times Move of 10cm (value of 2) times Move type (value 1) (3*2*1) equals 6
CAF of -3 times 4 equals -12
Laser Destroyer: 1 shot (4) to 50cm (1) 4+ (1.5) & TSM-3 (4) equals (4*1*1.5*4) 24
Thus 6 -12 +24 = 18
Tweaking the direct-fire weapons adjusts the Rapier's weapon as:
Laser Destroyer: 1 shot (1) to 50cm (1) 4+ (1.5) TSM-3 (4) equals (1*1*1.5*4) 6
Thus model cost is 6 (move) -12 (CAF) +6 (weapon) for a net cost of zero. Broken.
Tweaking the CAF just makes it worse, looking at column F.
Since the CAF tweak converts the base cost into Unit Type + Move value + Move type-1, the new cost per point of CAF for a Rapier is (3 +2 +1 -1) 5. It's CAF of -3 times 5 equals -15. Thus 6 (move) -15 (CAF) +6 (weapon) equals -3.
Having a zero value is bad enough, but having a negative one is just unworkable. I suppose this really shows just how bad the stats are on the Rapier.
The only "easy" fix that I can think of would be to establish a minimum value allowed for any model. Probably somewhere around one to three points.
PostPosted: Sun Sep 07, 2014 12:32 am
Thus 6 -12 +24 = 18
Thanks for the explanation. :)
I see two work a rounds.
One you have mentioned of a "minimum value".
The other is re-working the stats to make it more appealing.
I suspect quite a few units will be revisited to question/redo their stats or role based on current efficacy.
It is kind of odd that for a similar unit, the tarantula is so much better. So perhaps a reworking of the rapier is what is needed.
PostPosted: Sun Sep 07, 2014 1:38 am
I'm going to suggest waiting until I can get a few more lists worked up and posted to see if this happens much before we seriously think about adjusting stats on things.
Still, that said, probably all that would be needed would be reducing the CAF penalty from -3 to -2. Whether we'd want to only adjust the Rapier or all of the Light Artillery in such a way is another issue.
PostPosted: Thu Jan 08, 2015 8:42 am
Tweaked values adjusted for recent revision to Transport formula costs and methodology.
________________
__ Space Marine Formations
_Company _ value post Tweaks and Transport revision
Veteran ____ 735
Terminator _ 845
Tactical ___ 470
Assault ____ 655
Devastator _ 470
Battle _____ 525
Scout ______ 475
Land Raider_ 360
Bike _______ 330
_Special: [all Infantry with accompanying Transport are Command vehicles]
Apothecary: __________ 70 (Rhino or Razorback)
Apothecary on Bike: __ 80
Chaplain: ___________ 110 (Rhino or Razorback)
Chaplain on Bike: ___ 150
Chapter Master: _____ 160 (Rhino or Razorback)
Chapter Master Bike:_ 210
Forward Observer: ____ 90 (Rhino (Infiltrate) only)
Grey Knight: ________ 255
Inquisitor: _________ 210 (Rhino or Razorback)
Inquisitor on Bike: _ 265
Legion of the Damned: 215
Librarian: __________ 100 (Rhino or Razorback)
Librarian on Bike: __ 115
Ordo-Malleus Inq: ___ 155 (Rhino or Razorback)
Ordo-Malleus on Bike: 205
Techmarine: __________ 70 (Rhino or Razorback)
Techmarine on Bike: __ 80
Drop Pods: __________ 205
Marine Dropship: ____ 490
Warhound hull: ______ 610
Reaver hull: ________ 705
Warlord hull: _______ 780
_Support:
Assault:___________ 225
Devastator: _______ 160
Flamer: ___________ 160
Scout: ____________ 115
Tactical: _________ 160
Terminator: _______ 270
Terminator Assault: 295
Veteran: __________ 260
Attack Bike: ____________ 160
Land Speeder (5): _______ 225
Land Speeder Tornado (3): 145
Land Speeder Tornado (5): 220
Land Speeder Typhoon (3): 150
Land Speeder Typhoon (5): 225
Marine Bike: ____________ 130
Combined Dreadnought:
- 4x Contemptor Mk1: __ 110
- 4x Deredeo: __________ 90
- 4x Furibundus: _______ 80
Mutilator Dreadnought: _ 100
Destroyer: ______________ 85
Punisher/Contemptor Mk2: 125
Robot: _________________ 190
Scatolo Combat (Flamer): 135
Scatolo Assault (AC): ___ 85
Scatolo Heavy (ML & Lc):_ 75
Hunter AA: __ 80
Land Raider: 145
LR Crusader: 150
LR Helios: _ 175
Predator: ___ 90
Razorback: _ 105
Rhino: ______ 70
Sabre: ______ 65
Vindicator: _ 90
Mole Mortar: 25
Rapier: ____ -5
Tarantula: _ 40
Thudd Gun: _ 20
Whirlwind: 90
Marauder: __ 430
Thunderbolt: 575
Thunderhawk: 335
_ Marine models
Model: ___ value post Tweaks and Transport revision
Apothecary: _______________ 49.5
Apothecary on Bike ________ 69.5
Assault HQ: ______________ 104.5
Assault: __________________ 41.5
Chaplain: _________________ 85
Chaplain on Bike _________ 133
Chapter Master: __________ 127
Chapter Master on Bike ___ 187
Devastator: _______________ 25
Flamer: ___________________ 25.5
Forward Observer: _________ 64.5
Grey Knight: _____________ 122.3
Inquisitor: ______________ 174
Inquisitor on Bike _______ 234
Legion of the Damned: _____ 95
Librarian: ________________ 74.5
Librarian on Bike ________ 102.5
Marine HQ: ________________ 68.5
OM Inquisitor: ___________ 122
OM Inquisitor on Bike ____ 182
Scout: ____________________ 35.5
Scout HQ: _________________ 52.75
Tactical: _________________ 25
Techmarine: _______________ 49.5
Techmarine on Bike ________ 69.5
Terminator CA: ____________ 86
Terminator HQ: ___________ 121.3
Terminator: _______________ 75.2
Veteran: __________________ 46
Veteran HQ: _______________ 88
Attack Bike: ______________ 45
LS Tornado: _______________ 61
LS Typhoon: _______________ 62
Land Speeder: _____________ 62
Marine Bike: ______________ 36.25
Marine Bike, Command: _____ 69.38
Contemptor Mk1: ___________ 45.34
Deredeo: __________________ 38.34
Furibundus: _______________ 33.84
Punisher / Contemptor Mk2:_ 51.34
Venerable: ________________ 58.91
Robot: ____________________ 33.5
Scatolo Combat: ___________ 57.21
Scatolo Assault: __________ 36.34
Scatolo Heavy Support: ____ 30.84
Hunter AA: ________________ 34
Land Raider: ______________ 61 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
LR, Command: ______________ 92 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
LR Crusader: ______________ 61.9 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
LR Helios: ________________ 73.51
Predator: _________________ 36.5
Razorback:_________________ 29.5 [Transport 1 slot: Inf 1/1; 1 LA no slots]
Razorback, Command: _______ 54.75 [Transport 1 slot: Inf 1/1; 1 LA no slots]
Rhino: ____________________ 29.38 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
Rhino, Command: ___________ 54.88 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
Rhino, Command (Infiltrate) 74.88 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
Sabre: ____________________ 26.5
Vindicator: _______________ 37
Mole Mortar: ______________ 11.25
Rapier: ___________________ -3
Tarantula: _________________ 9.5
Thudd Gun: _________________ 9
Whirlwind: ________________ 38
Thunderbolt: _____________ 239
Marauder: ________________ 178.5
Thunderhawk: _____________ 279 [Transport 6 slots: Inf 1/1 or W 2/3 or LA 1/2]
Dropship: ________________ 512 [Transport Company: Inf, LA, W, V] *
Warhound hull: ___________ 543
Reaver hull: _____________ 630
Warlord hull: ____________ 695
Drop Pod Assault: _________ 43.5 [Transport 2 slots: Inf 1/1 or W 1/2 or LA 1/2]
Drop Pod Support: _________ 42.75
Drop Pod Deathwind: _______ 36.75
___________________
* The Dropship is an odd model. It is listed as holding 18 stands or 6 vehicles. 18 stands is enough to carry an Infantry-based Marine Company IF they leave their HQ stands behind, which one never would. 6 vehicles is only enough for 2 detachments. I've gone ahead and valued this one as if it can carry a full Company. This means that the "maximum" number of stands it can carry would now be 20 (three detachments of six stands, plus two HQ stands) or ten Vehicles (three detachments of three, plus a HQ). It is my opinion that this is less of a stretch than restricting it to only holding two detachments of anything, partly because this adjustment makes it more useful for it's intended role and partly because this model never existed during 2nd edt / TL so I have no attachment to it. If anyone has a serious objection, please say so and why.
Last edited by MagnusIlluminus on Fri Feb 27, 2015 8:30 pm, edited 2 times in total.
PostPosted: Thu Jan 08, 2015 7:46 pm
I have a bunch of those dropships, and offer no objection to the recommendation.
PostPosted: Thu Jan 08, 2015 10:26 pm
Found and fixed an error with Drop Pod values.
PostPosted: Sun Feb 01, 2015 11:18 pm
I would suggest changing the text entry for the Dropship (in your "with Errata" document) to reflect the change to it's capacity above. It would probably be best to specify the exact number of stands (IE 20 Infantry or Light Artillery) or models (IE 10 Walker or Vehicle) it can carry as opposed to saying "one Company", as saying the latter would imply it is limited to carrying Companies which I doubt is true.
PostPosted: Mon Feb 02, 2015 12:09 am
Will do. I have several other things being pointed out to change as well.
PostPosted: Fri Feb 27, 2015 8:36 pm
Updated for errata and I left off a couple of things. Specifically:
Marine Bike HQ CAF & HQ.
Grey Knights Morale.
Added a bit to the cost of the Librarian's Psychic Powers to account for Force Dome (Psychics cost now 30, still a bit arbitrary).
Added Special Characters on Bike to models listing to show exactly how much difference it makes. Note also that under the Points Formula upgrading these to Bike or Jump (oops, haven't done Jump yet) should not be free.
PostPosted: Sat Mar 14, 2015 2:06 am
Updated values for NetEpic Gold pdf formations for tweak2. This post only covers models and formations in the current pdf and those that can be directly extrapolated from them (mainly Special characters with alternate transport options).
_Company _ tweak2
Veteran ____ 719
Terminator _ 861
Tactical ___ 444
Assault ____ 625
Devastator _ 494
Battle _____ 514
Scout ______ 349
Land Raider_ 389
Bike _______ 290
Apothecary: __________ 66 (Rhino)
Apothecary: __________ 67 (Razorback)
Apothecary Jump ______ 66
Apothecary on Bike: __ 67
Chaplain: ___________ 104 (Rhino)
Chaplain ____________ 105 (Razorback)
Chaplain Jump _______ 122
Chaplain on Bike: ___ 125
Chapter Master: _____ 156 (Rhino)
Chapter Master: _____ 157 (Razorback)
Chapter Master Jump _ 180
Chapter Master Bike _ 187
Forward Observer: ____ 86 (Stealth Rhino only)
Grey Knight: ________ 251
Inquisitor: _________ 212 (Rhino)
Inquisitor: _________ 213 (Razorback)
Inquisitor Jump _____ 236
Inquisitor on Bike: _ 243
Legion of the Damned: 211
Librarian: ___________ 94 (Rhino)
Librarian: ___________ 95 (Razorback)
Librarian Jump _______ 97
Librarian on Bike: __ 102
Ordo-Malleus Inq: ___ 150 (Rhino)
Ordo-Malleus Inq: ___ 151 (Razorback)
Ordo-Malleus Inq Jump 174
Ordo-Malleus on Bike: 181
Techmarine: __________ 66 (Rhino)
Techmarine: __________ 67 (Razorback)
Techmarine Jump ______ 66
Techmarine on Bike: __ 67
Drop Pods: __________ 206
Marine Dropship: ____ 496
Warhound hull: ______ 578
Reaver hull: ________ 647
Warlord hull: _______ 715
_Support:
Assault:___________ 214
Devastator: _______ 170
Flamer: ___________ 154
Scout: ____________ 116
Tactical: _________ 150
Terminator: _______ 272
Terminator Assault: 289
Veteran: __________ 253
Attack Bike: ____________ 148
Land Speeder (5): _______ 216
Land Speeder Tornado (3): 139
Land Speeder Tornado (5): 209
Land Speeder Typhoon (3): 140
Land Speeder Typhoon (5): 211
Marine Bike: ____________ 113
- 4x Contemptor Mk1: __ 107
- 4x Deredeo: __________ 99
- 4x Furibundus: _______ 88
Destroyer: ______________ 93
Punisher/Contemptor Mk2: 105
Robot: _________________ 196
Scatolo Combat (Flamer): 151
Scatolo Assault (AC): ___ 86
Scatolo Heavy (ML & Lc):_ 83
Hunter AA: ___ 103
Land Raider: _ 157
LR Crusader: _ 158
LR Helios: ___ 209
Predator: ____ 103
Razorback: ___ 104
Rhino: ________ 65
Sabre: ________ 67
Vindicator: ___ 98
Mole Mortar: 51
Rapier: _____ 7
Tarantula: _ 97
Thudd Gun: _ 43
Whirlwind: _ 106
Marauder: __ 473
Thunderbolt: 583
Thunderhawk: 365
_ Marine models
Model: ___ Tweak run 2
Apothecary: _______________ 48
Apothecary Jump ___________ 58.5 [15cm Jump]
Apothecary on Bike ________ 60 [Cavalry 30cm]
Assault: __________________ 40
Chaplain: _________________ 82
Chaplain Jump ____________ 109 [15cm Jump]
Chaplain on Bike _________ 112 [Cavalry 30cm]
Chapter Master: __________ 128
Chapter Master Jump ______ 161 [15cm Jump]
Chapter Master on Bike ___ 167 [Cavalry 30cm]
Devastator: _______________ 29
Forward Observer: _________ 63
Grey Knight: _____________ 120.6
Inquisitor: ______________ 177.9
Inquisitor Jump __________ 211 [15cm Jump]
Inquisitor on Bike _______ 216.9 [Cavalry 30cm]
Legion of the Damned: _____ 94
Librarian: ________________ 73
Librarian Jump ____________ 86.5 [15cm Jump]
Librarian on Bike _________ 91 [Cavalry 30cm]
OM Inquisitor: ___________ 122.5
OM Inquisitor Jump _______ 156 [15cm Jump]
OM Inquisitor on Bike ____ 161.5 [Cavalry 30cm]
Tactical: _________________ 24
Techmarine: _______________ 48
Techmarine Jump ___________ 58.5 [15cm Jump]
Techmarine on Bike ________ 60 [Cavalry 30cm]
Terminator CA: ____________ 81
Terminator HQ: ___________ 122.6
Terminator: _______________ 74.4
Veteran HQ: _______________ 89
Attack Bike: ______________ 41
LS Tornado: _______________ 58
LS Typhoon: _______________ 58.5
Land Speeder: _____________ 60
Marine Bike: ______________ 31.5
Marine Bike, Command: _____ 64.75
Contemptor Mk1: ___________ 44.68
Deredeo: __________________ 41.18
Furibundus: _______________ 36.68
Punisher / Contemptor Mk2:_ 43.68
Venerable: ________________ 59.83
Robot: ____________________ 35
Scatolo Combat: ___________ 63
Scatolo Assault: __________ 35.68
Scatolo Heavy Support: ____ 34.68
Hunter AA: ________________ 43
Land Raider: ______________ 65.51 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
LR, Command: _____________ 101 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
LR Crusader: ______________ 65.93 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
LR Helios: ________________ 87
Predator: _________________ 43
Razorback:_________________ 29 [Transport 1 slot: Inf 1/1; 1 LA no slots]
Razorback, Command: _______ 55.5 [Transport 1 slot: Inf 1/1; 1 LA no slots]
Rhino: ____________________ 26.89 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
Rhino, Command: ___________ 52.39 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
Sabre: ____________________ 28
Vindicator: _______________ 41
Mole Mortar: ______________ 21.38
Rapier: ____________________ 3
Tarantula: ________________ 23
Thudd Gun: ________________ 18
Whirlwind: ________________ 44
Thunderbolt: _____________ 243
Marauder: ________________ 197
Thunderhawk: _____________ 305 [Transport 6 slots: Inf 1/1 or W 2/3 or LA 1/2]
Dropship: ________________ 517 [Transport Company: Inf, LA, W, V] *
Warhound hull: ___________ 516.5
Reaver hull: _____________ 578
Warlord hull: ____________ 638
Drop Pod Assault: _________ 40.5 [Transport 2 slots: Inf 1/1 or W 1/2 or LA 1/2]
Drop Pod Support: _________ 46.5
Drop Pod Deathwind: _______ 34.13
PostPosted: Sat Mar 14, 2015 2:09 am
Cool let me know when all the tweaks are done to make my pdf. :)
PostPosted: Sat Mar 14, 2015 2:20 am
Next I will be posting the expanded formations I have come up with for Gold. However, before I do, I want to give a quick warning. Some of these formations break certain conventions held through 1st, 2nd, and NetEpic, and some people may have a strong negative reaction to them. Keep in mind that all formations posted in the next few posts (aside from those that repeat standard formations) are entirely OPTIONAL and may only be used with the consent of all players involved in the battle.
Please keep an open mind when reading through these. I am not trying to destroy any fluff, I'm just trying to present options. I like fluff. And options.
Point A: Some of these I almost did not post, but then I had the thought: "What if there was a Marine Chapter out there that had no (or nearly no) Land Raiders but still needed to mobilize their Terminators? Well, they would just have to use Rhinos."
Point B: As far as Gold is concerned, Infantry is Infantry and anything that is listed as being able to carry Infantry can carry any Infantry stand. Gold does not have a "Bulky" ability or anything like it.
Point C: Just to repeat, all of these are optional. If you don't like them, don't use them. Nobody will force you to.
PostPosted: Sat Mar 14, 2015 2:23 am
New models for expanded Marines
Scout HQ stand
_ This group of Marine leaders have decided to forego using their Tactical armor and instead wear the lighter Scout armor so they can remain with their Scout bretheren on the battlefield.
Scout HQ _ Infantry _ 10cm _ 6+ _ +2 _ Bolt Pistol _ 25cm _ 1 _ 5+ _ 0 _ Command, Elite, HQ, Infiltration, Inspirational
Jet Bike
_ These are relics from the First Founding and few Chapters have many of them remaining. No known Chapter has enough of them to outfit even a detachment of troops and would not even if they did as they are irreplaceable. However, a few Chapters sometimes allow special heroes the use of these for a time.
_ Any model described as "... on Jet Bike" looses their Infantry type and Move value and gain the Cavalry type, a Move of 30cm, and the Skimmer quality.
_ Expanded Marine Models:
Scout HQ ____________________ 74.5
Apothecary on Jet Bike ______ 74
Chaplain on Jet Bike _______ 148
Chapter Master on Jet Bike _ 167
Inquisitor on Jet Bike _____ 258.9
Librarian on Jet Bike ______ 107
OM Inquisitor on Jet Bike __ 203.5
Techmarine on Jet Bike ______ 74
Rhino, Command Scout_________ 72.39 [Transport 2 slots: Inf 1/1 or W 1/2; 1 LA no slots]
_ Expanded Formations:
_Formation Name _____ BP _ Morale _ VP _ Cost _ Contents
__Companies
Note that the Thunderhawk that accompanies the HQ model is NOT a Command model and must be given orders normally. It is included in the BP and VP of the Company as a whole.
_ Assault:
Footslogger _ 10 _ 2 __ 5 __ 468 _ Assault HQ stand, 3 Assault Foot detachments
Rhino _______ 15 _ 2 __ 6 __ 625 _ Assault HQ stand & Command Rhino, 3 Assault Rhino detachments
Razorback ___ 19 _ 2 __ 8 __ 757 _ Assault HQ stand & Command Razorback, 3 Assault Razorback detachments
Land Raider _ 15 _ 2 __ 8 __ 846 _ Assault HQ stand & Command Land Raider, 3 Assault Land Raider detachments
Thunderhawk _ 12 _ 2 _ 12 _ 1151 _ Assault HQ stand, Thunderhawk, 3 Assault Hawk detachments
Drop Pods ___ 15 _ 2 __ 7 __ 724 _ Assault HQ stand, Assault Drop Pod, 3 Assault Drop detachments
Teleport ____ 15 _ 2 __ 7 __ 703 _ Assault HQ stand, 3 Assault Teleport detachments
_ Devastator:
Footslogger _ 10 _ 2 __ 3 __ 335 _ Marine HQ stand, 3 Devastator Foot detachments
Rhino _______ 15 _ 2 __ 5 __ 494 _ Marine HQ stand & Command Rhino, 3 Devastator Rhino detachments
Razorback ___ 19 _ 2 __ 6 __ 631 _ Marine HQ stand & Command Razorback, 3 Devastator Razorback detachments
Land Raider _ 15 _ 2 __ 7 __ 715 _ Marine HQ stand & Command Land Raider, 3 Devastator Land Raider detachments
Thunderhawk _ 12 _ 2 _ 10 _ 1019 _ Marine HQ stand, Thunderhawk, 3 Devastator Hawk detachments
Drop Pods ___ 15 _ 2 __ 6 __ 594 _ Marine HQ stand, Assault Drop Pod, 3 Devastator Drop detachments
Teleport ____ 15 _ 2 __ 5 __ 503 _ Marine HQ stand, 3 Devastator Teleport detachments
_ Flamer:
Footslogger _ 10 _ 2 __ 3 __ 294 _ Marine HQ stand, 3 Flamer Foot detachments
Rhino _______ 15 _ 2 __ 5 __ 454 _ Marine HQ stand & Command Rhino, 3 Flamer Rhino detachments
Razorback ___ 19 _ 2 __ 6 __ 592 _ Marine HQ stand & Command Razorback, 3 Flamer Razorback detachments
Land Raider _ 15 _ 2 __ 7 __ 675 _ Marine HQ stand & Command Land Raider, 3 Flamer Land Raider detachments
Thunderhawk _ 12 _ 2 _ 12 __ 978 _ Marine HQ stand, Thunderhawk, 3 Flamer Hawk detachments
Drop Pods ___ 15 _ 2 __ 6 __ 553 _ Marine HQ stand, Assault Drop Pod, 3 Flamer Drop detachments
Teleport ____ 15 _ 2 __ 4 __ 442 _ Marine HQ stand, 3 Flamer Teleport detachments
_ Battle:
Footslogger _ 10 _ 2 __ 4 __ 356 _ Marine HQ stand, 1 Assault Foot detachment, 1 Devastator Foot detachment, 1 Tactical Foot detachment
Rhino _______ 15 _ 2 __ 5 __ 514 _ Marine HQ stand & Command Rhino, 1 Assault Rhino detachment, 1 Devastator Rhino detachment, 1 Tactical Rhino detachment
Razorback ___ 19 _ 2 __ 7 __ 650 _ Marine HQ stand & Command Razorback, 1 Assault Razorback detachment, 1 Devastator Razorback detachment, 1 Tactical Razorback detachment
Land Raider _ 15 _ 2 __ 7 __ 736 _ Marine HQ stand & Command Land Raider, 1 Assault Land Raider detachment, 1 Devastator Land Raider detachment, 1 Tactical Land Raider detachment
Thunderhawk _ 12 _ 2 _ 10 _ 1039 _ Marine HQ stand, Thunderhawk, 1 Assault Hawk detachment, 1 Devastator Hawk detachment, 1 Tactical Hawk detachment
Drop Pods ___ 15 _ 2 __ 6 __ 614 _ Marine HQ stand, Assault Drop Pod, 1 Assault Drop detachment, 1 Devastator Drop detachment, 1 Tactical Drop detachment
Teleport ____ 15 _ 2 __ 5 __ 534 _ Marine HQ stand, 1 Assault Teleport detachment, 1 Devastator Teleport detachment, 1 Tactical Teleport detachment
_ Seige:
Footslogger _ 10 _ 2 __ 4 __ 359 _ Marine HQ stand, 1 Assault Foot detachment, 1 Devastator Foot detachment, 1 Flamer Foot detachment
Rhino _______ 15 _ 2 __ 5 __ 517 _ Marine HQ stand & Command Rhino, 1 Assault Rhino detachment, 1 Devastator Rhino detachment, 1 Flamer Rhino detachment
Razorback ___ 19 _ 2 __ 7 __ 653 _ Marine HQ stand & Command Razorback, 1 Assault Razorback detachment, 1 Devastator Razorback detachment, 1 Flamer Razorback detachment
Land Raider _ 15 _ 2 __ 7 __ 739 _ Marine HQ stand & Command Land Raider, 1 Assault Land Raider detachment, 1 Devastator Land Raider detachment, 1 Flamer Land Raider detachment
Thunderhawk _ 12 _ 2 _ 10 _ 1043 _ Marine HQ stand, Thunderhawk, 1 Assault Hawk detachment, 1 Devastator Hawk detachment, 1 Flamer Hawk detachment
Drop Pods ___ 15 _ 2 __ 6 __ 617 _ Marine HQ stand, Assault Drop Pod, 1 Assault Drop detachment, 1 Devastator Drop detachment, 1 Flamer Drop detachment
Teleport ____ 15 _ 2 __ 5 __ 539 _ Marine HQ stand, 1 Assault Teleport detachment, 1 Devastator Teleport detachment, 1 Flamer Teleport detachment
_ Tactical:
Footslogger _ 10 _ 2 __ 3 __ 284 _ Marine HQ stand, 3 Tactical Foot detachments
Rhino _______ 15 _ 2 __ 4 __ 444 _ Marine HQ stand & Command Rhino, 3 Tactical Rhino detachments
Razorback ___ 19 _ 2 __ 6 __ 582 _ Marine HQ stand & Command Razorback, 3 Tactical Razorback detachments
Land Raider _ 15 _ 2 __ 7 __ 665 _ Marine HQ stand & Command Land Raider, 3 Tactical Land Raider detachments
Thunderhawk _ 12 _ 2 _ 10 __ 968 _ Marine HQ stand, Thunderhawk, 3 Tactical Hawk detachments
Drop Pods ___ 15 _ 2 __ 5 __ 543 _ Marine HQ stand, Assault Drop Pod, 3 Tactical Drop detachments
Teleport ____ 15 _ 2 __ 4 __ 426 _ Marine HQ stand, 3 Tactical Teleport detachments
_ Veteran:
Footslogger _ 10 _ 1 __ 6 __ 565 _ Veteran HQ stand, 3 Veteran Foot detachments
Rhino _______ 15 _ 1 __ 7 __ 733 _ Veteran HQ stand & Command Rhino, 3 Veteran Rhino detachments
Razorback ___ 19 _ 1 __ 9 __ 874 _ Veteran HQ stand & Command Razorback, 3 Veteran Razorback detachments
Land Raider _ 15 _ 1 _ 10 __ 968 _ Veteran HQ stand & Command Land Raider, 3 Veteran Land Raider detachments
Thunderhawk _ 12 _ 1 _ 13 _ 1303 _ Veteran HQ stand, Thunderhawk, 3 Veteran Hawk detachments
Drop Pods ___ 15 _ 1 __ 8 __ 819 _ Veteran HQ stand, Assault Drop Pod, 3 Veteran Drop detachments
Teleport ____ 15 _ 1 __ 8 __ 847 _ Veteran HQ stand, 3 Veteran Teleport detachments
_ Terminator:
Footslogger __ 7 _ 1 __ 6 __ 640 _ Terminator HQ stand, 3 Terminator Foot detachments
Land Raider _ 10 _ 1 __ 9 __ 861 _ Terminator HQ stand & Command Land Raider, 3 Terminator Land Raider detachments
Crusader ____ 10 _ 1 __ 9 __ 880 _ Terminator HQ stand & Command Land Raider, 3 Terminator Land Raider Crusader detachments
Rhino _______ 10 _ 1 __ 7 __ 717 _ Terminator HQ stand & Command Rhino, 3 Terminator Rhino detachments
Razorback ___ 13 _ 1 __ 8 __ 830 _ Terminator HQ stand & Command Razorback, 3 Terminator Razorback detachments
Thunderhawk __ 9 _ 1 _ 13 _ 1325 _ Terminator HQ stand, Thunderhawk, 3 Terminator Hawk detachments
Drop Pods ___ 10 _ 1 __ 8 __ 773 _ Terminator HQ stand, Assault Drop Pod, 3 Terminator Drop detachments
Teleport ____ 10 _ 1 __ 9 __ 914 _ Terminator HQ stand, 3 Terminator Teleport detachments
_ Terminator Close Assault:
Footslogger __ 7 _ 1 __ 6 __ 640 _ Terminator HQ stand, 3 Terminator Close Assault Foot detachments
Land Raider _ 10 _ 1 __ 9 __ 907 _ Terminator HQ stand & Command Land Raider, 3 Terminator Close Assault Land Raider detachments
Crusader ____ 10 _ 1 __ 9 __ 926 _ Terminator HQ stand & Command Land Raider, 3 Terminator Close Assault Land Raider Crusader detachments
Rhino _______ 10 _ 1 __ 8 __ 763 _ Terminator HQ stand & Command Rhino, 3 Terminator Close Assault Rhino detachments
Razorback ___ 13 _ 1 __ 9 __ 876 _ Terminator HQ stand & Command Razorback, 3 Terminator Close Assault Razorback detachments
Thunderhawk __ 9 _ 1 _ 14 _ 1375 _ Terminator HQ stand, Thunderhawk, 3 Terminator Close Assault Hawk detachments
Drop Pods ___ 10 _ 1 __ 8 __ 819 _ Terminator HQ stand, Assault Drop Pod, 3 Terminator Close Assault Drop detachments
Teleport ____ 10 _ 1 _ 10 __ 985 _ Terminator HQ stand, 3 Terminator Close Assault Teleport detachments
_ Standard Scout:
Footslogger _ 10 _ 3 __ 4 __ 364 _ Marine HQ stand, 3 Scout detachments
Rhino _______ 10 _ 3 __ 3 __ 346 _ Marine HQ stand & Command Rhino, 3 Scout detachments
Teleport ____ 10 _ 3 __ 4 __ 364 _ Marine HQ stand, 3 Scout detachments
_ Enhanced Scout:
Footslogger _ 10 _ 3 __ 4 __ 367 _ Scout HQ stand, 3 Scout detachments
Rhino _______ 10 _ 3 __ 3 __ 349 _ Scout HQ stand & Command Scout Rhino, 3 Scout detachments
Teleport ____ 10 _ 3 __ 4 __ 367 _ Scout HQ stand, 3 Scout detachments
__Bonus
Drop Pod Attack* _ 3 _ - _ 2 _ 169 _ 3 Support Pods, 3 Deathwind Pods
*This formation may be selected by any Company that includes Assault Drop Pods. This formation does not count against the limit of Special or Support formations. These pods must enter the board at the same time as those from the associated Company, but have their own Break Point and Victory Points and do not add to the associated Company.
