Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4  Next
Army List: Squats
 Post subject: Re: Army List: Squats
PostPosted: Sat Sep 28, 2013 10:28 pm
Ah! That would explain it! I took it to mean 2 x Hearthguard (stands) & 1 Berserker Squad. Mystery over! Thanks chaps! :D
PostPosted: Mon Sep 30, 2013 7:09 am
The Bissler wrote:
True enough... Every cloud, eh? :D
And if you want some very good infantry, check the bodyguards special cards ;)
Leviathans are not HQ in Squat List. They may be Regimental HQ in Imperial Guard army if the IG player wants.
Leviathan, Colossus, Cyclop and all Praetorians follow the Praetorian rules from the NetEpic Standard Rules:
"Orders: ...Praetorians are Command vehicles for purposes of movement and firing...
Firing: ...Superior fire control systems permit praetorians to always fire in the First Fire Segment..."
PostPosted: Mon Sep 30, 2013 8:55 am
Cheers Scream! You are a gentleman and a scholar! ;)
PostPosted: Sat Nov 09, 2013 2:51 pm
I have a question to the squat army book, but I think my question is relevant for all Praetorians.
Yesterday I tried the NetEPIC rules for the first time (a battle report with photos will follow soon). My opponent purchased the Cyclops. After knocking down all shields on the Cyclops I fired again and got a hit on the hull. After scattering, and he failing his save, I rolled for damage on the hull and got a 6. I hit the cyclops on the front, so the it looks like the bridge is hit.
The damage table says:
"Bridge or engine hit: bridge if the front half of the vehicle, engine if the rear. Any points over 6 are bonuses to the second roll."
We couldn't work out how to interpret this. Could someone please let me know what the appropriate action would be if following the NetEPIC Gold rules? Re-roll for damage on the bridge damage table? (this is what we ended up doing). Unfortunately, this just gave a 2.
I tried to look for the White Dwarf magazine that has rules for the Cyclops. But I don't have this issue. If anyone has this issue (no. 170, february 1994), and can share the details about the Cyclops I would be very grateful.
I can see in the Squat NetEPIC army book, that damaging the hull in other praetorians results in a similar wording, and also in the Mars Ordinatus and other Imperial Praetorians.
It might be worth rephrasing this part of the damage tables in a a future vers. of NetEPIC to make it easier to understand what to do in case you roll a 6.
Thanks in advance for your help on this.
PostPosted: Sat Nov 09, 2013 5:24 pm
The procedure would be as follows:
1. if the roll on the hull table is a 6 (as in your case) you get to add any bonuses (such as weapon penetration) to the second roll. So if you hit the hull with a weapon with penetration +2, you get that +2 on the roll for the bridge or engine.
2. The defense of the hull goes down 1 point. Meaning the hull becomes weaker and easier to damage.
So as far as I can tell you did the right thing by rolling on the bridge table. You may have not added any bonuses if you had them.
I agree this is badly worded and needs to be re-written to be clearer.
By the way, damage tables for praetorians are a net epic invention, the original rules have no damage tables. :)
I do have that issue of WD (I have all issues with epic in them), so the only real change is the damage tables net epic added.
PostPosted: Sat Nov 09, 2013 5:55 pm
Ok, slightly different question. If the hull is hit with a penetration +2 weapon you get +2 to the damage roll. If you roll a 5, +2 makes a 7. Is the subsequent roll to the bridge or engine suppose to be at +1, +2, or +3?
+1 because that is what you rolled over the 6 for the hull damage
+2 because the weapon is pen(2)
Or +3 from both, which has the effect of the penetrating special rule counting twice
Thanks,
Troy
PostPosted: Mon Nov 11, 2013 5:30 pm
Excellent question......I have the same problem
does pen. bonus count for further damages like the 6 on the hull and then for the roll on bridge/reactor?
PostPosted: Mon Nov 11, 2013 11:29 pm
In your example it would be +1, since it went over 6 by 1 point.
I think is too fiddly however and would just use the same penetration modifier as the first roll.
PostPosted: Wed Nov 13, 2013 11:11 am
I did it this way and I think it´s fine.
Will use it in future battles too.
PostPosted: Tue Apr 22, 2014 7:44 pm
I have a suggestion for the next version of the NetEpic squat army list.
A company card with 3 Praetorians.
E.g. a company card with 3 cyclops, or a company card with 3 colossus, or a company card with 3 Leviathans, or a company card with 3 land trains. Or perhaps even a company card with a mixture of different 3 praetorians.
I think this would be a nice match to the company cards the other armies can purchase with 3 titans - e.g. the Eldar Phantom titan host.
What do you think?
PostPosted: Tue Apr 22, 2014 8:43 pm
Squats have the doomanvil company, 2 cyclops + 1 colossus.
PostPosted: Tue Apr 22, 2014 9:40 pm
I'm thinking the newer formation rules will allow for a few variations of this theme. :)
PostPosted: Wed Apr 23, 2014 10:57 am
I like the idea of variations. I have one Cyclops and am sure there probably aren't too many people who have two (obviously not yourself Primarch!).
PostPosted: Wed Apr 23, 2014 6:26 pm
The goal of platinum, besides the new units, is to make formation construction more friendly to the realities of collecting epic models in current times.
So baseline formation will be smaller and there will be a greater ability to add additional models to a formation in ways net epic gold does not allow.
PostPosted: Thu Apr 24, 2014 8:38 am
Yep.
Guess making the Doom Anvil Squadron more generic and something along the lines of 2-4 Praetorians with costs associated with each different type.
Matt
