Post new topic Reply to topic  [ 186 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 13  Next
Army List: Space Marines
 Post subject: Re: Army List: Space Marines
PostPosted: Sat Nov 09, 2013 12:57 pm
The Achilles BPs don't combine, they don't have the @ symbol on their stats, so fire separately, hitting on 4+. Could potentially knock them to 4BPs.
PostPosted: Sat Nov 09, 2013 7:30 pm
Any thoughts to revising the points value or Razorbacks?
Could SM fliers just have the same stats as existing Navy fliers?
PostPosted: Sat Nov 09, 2013 8:00 pm
If you look further back in the topic we discussed the razorback and came to the conclusion of cutting their points so they are 6 vehicles for 200pts.
PostPosted: Sat Nov 09, 2013 9:03 pm
Correct, we tackled this one earlier. :)
PostPosted: Mon Nov 11, 2013 2:10 am
Some more items for discussion. Why is the armour save of bikes and land speeders worse than a normal marine? Was the improved marine save that was given to the rest not applied?
And I have always wondered why the bikes don't have +3CAF, they are meant to be assault marines and have their combat ability improved further by being on a bike!
Thoughts?
Matt
PostPosted: Mon Nov 11, 2013 4:10 am
Thoughts?
Matt
One of the many things that fell through the cracks.... ;)
Must update them.
PostPosted: Mon Nov 11, 2013 10:44 am
Thoughts?
Matt
Must update them.
I am guessing they should be 5+, anything more and they are as tough as Rhinos and bikes/speeders aren't that tough ::)
Matt
PostPosted: Mon Nov 11, 2013 5:12 pm
Mattman wrote:
Thoughts?
Matt
Must update them.
Matt
That sounds reasonable. :)
PostPosted: Mon Nov 11, 2013 5:27 pm
Thoughts?
Matt
Good points Matt
to be true the 5+ save for Marines feels too high
maybe just a 6+ or 6fixed
BTW Primarch is right, thats the D6 problem.
PostPosted: Mon Nov 11, 2013 11:31 pm
Thoughts?
Matt
Good points Matt
The d6 is just not granular enough to reflect changes in armor amongst units, so you are forced to have a lot of overlap. I'd keep the save the same or maybe 6+ fixed as Ulric suggests.
That's why a lot of people would have preferred using a d10 or 2d6. That opens a whole range of options.
PostPosted: Tue Nov 12, 2013 12:51 am
5+ is fine for marines, will use it for the bikes and speeders as well. We also have to remember that marine saves increased to 3+ in 40k some years ago.
I for one would not like to see d10s brought into the game, or multiples of d6s used outside of the few occasions we currently use them for.
Matt
PostPosted: Tue Nov 12, 2013 4:44 am
Matt
Believe me the amount of work to update to a different die type is so much that I's rather build a system from scratch. ;)
Mattman, once this list is done and "update" lets go down the line and update them all for the platinum version.
IG
Eldar
Chaos
Orks
Squats
Tyranids
Tau
Other.
PostPosted: Wed Nov 13, 2013 4:10 pm
Another item for discussion.
Should the Terminator Company be the same size as the others?
Obviously would increase the cost, but given what they are, they should only be rolled out rarely. Tying it in with the rest of the companies would be nice and it would allow easier implementation of the Land Raider Variants as transport upgrades (which is an option I am looking at for them).
Or maybe just re jig the numbers to make 2 detachments of 3 units rather than 3 detachments of 2?
Matt
PostPosted: Wed Nov 13, 2013 10:56 pm
I am fine with the size of the Coy
as long as I can use all those new LR variants .........and the Stormraven :)
PostPosted: Wed Nov 13, 2013 11:58 pm
Matt
If I recall the fluff, the terminator company is smaller than the others becuase:
1. Not enough terminator suits to go around
2. Only proven veterans get them.
I'd keep them the same number with added land raider variant choices.
