Post new topic Reply to topic  [ 4600 posts ]  Go to page Previous  1 ... 255, 256, 257, 258, 259, 260, 261 ... 307  Next
 Post subject: Re: Onslaught Miniatures
PostPosted: Fri May 23, 2014 10:17 am
Sorry. I will shut up and let you do the typing. Over and out.
Epic 40,000: Exodites, Necrons, Dark Eldar, Sisters of Battle, Tau
BLOG: Epic 40,000
BLOG: Warmaster
Toco's Mod: Allied HeroQuest
PostPosted: Fri May 23, 2014 10:56 am
I think the dozer blade should stay on as it adds som bulk to the overal look of the miniature. Which I think is neccesary if it is to be the sisterhoods MBT. I think I would drop the side turrets though.
PostPosted: Fri May 23, 2014 1:40 pm
I'd lose the Dozer blade, but if it's an optional add-on, then to each his/her own.
I agree that the smaller turrets look off somehow. How about flattening them a bit, and moving them forward and inwards, and dropping the front twin turret to make room? You could add a pintle-mount gun on the top of the main turret to represent added anti-infantry firepower... Plus, pintle-mounts just look cool.
PostPosted: Fri May 23, 2014 2:05 pm
Nitpick and Toco - Take 'er easy.
Toco, it's dangerous to evoke the name of the company that shall not be spoken - bad things happen...."shutter"
OK - I agree guys, cramming all this firepower onto this chassis without making it look tacked on is proving difficult - how about these options?
A. Dropped the side turrets and just replaced the secondary one with a cannon turret.
B. Added "wings" to the sides, which still allow maximum fire arcs to each side turret.
C. Remove flak cannon turret, add two small cannon turrets up top, moved cockpit to center.
D. Added lower side "wings" and integrated turrets into the hull - reduced fire arcs in the process.
PS - The dozer blade is optional on all Sisterhood tanks.
PostPosted: Fri May 23, 2014 2:10 pm
Without doubt D nails it! :spin
PostPosted: Fri May 23, 2014 2:20 pm
I like D as well!
PostPosted: Fri May 23, 2014 2:30 pm
D, love it! Is this the same size hull as the current transport and missile tank? I ask because if it is I'd go for the sloped front from C (i.e. no hull weapon) with the rest of it being D.
Current EA Armies:
Steel Legion (6k+)
Orks (6k+)
Iron Warriors (Currently Building)
Daemons
My Commission Website: http://hulksmashstudios.webs.com
My Languishing Blog that will soon host some Epic stuff: http://hulksmash-homeplace.blogspot.com
PostPosted: Fri May 23, 2014 2:47 pm
Yes its the same sized hull. What do you say guys - keep the small flak turret, or drop it?
PostPosted: Fri May 23, 2014 2:53 pm
I vote drop the flakk turret with that info :)
I'm assuming we might see some alternative weapon options on this tank? Like and anti-infantry platform to go with this anti-tank platform?
Current EA Armies:
Steel Legion (6k+)
Orks (6k+)
Daemons
PostPosted: Fri May 23, 2014 2:55 pm
While I appreciate the proxy utility of the sponsons, I think they look very WWI'ish. Could they be optional add-ons? The B and D variants looks like they could be made to plug onto the side doors?
PostPosted: Fri May 23, 2014 3:05 pm
Cool AFVs !! :spin
PostPosted: Fri May 23, 2014 3:11 pm
I think option D could would well but having the sponsons slope down before going out looks awkward. If you went that route I'd suggest making the top of the sponson be a flat extension from the hull with some plates over it or some adjustments to blend better with hull. Could even be as simple as two braces over the top of the sponson.
-Vaaish
PostPosted: Fri May 23, 2014 3:15 pm
I agree.
