Listing of converted Mecha, alphabetical by class.
Entry descriptions: _ First line is the game designation for the model. This is usually the sub-model given for the type of Mech represented by the model, as detailed on sarna dot net. _ Second line is the name of the model in MWDA and the set designator & number for that model. _ _ DA### is Dark Age _ _ FE### is Fire for Effect _ _ DFA### is Death From Above _ _ LI### is Liao Incursion _ Third line is Move, Save, CAF, model Special Abilities; and Firing Arc (if different than standard) _ Fourth and subsequent lines are Weapons, listed as: _ _ Weapon name: Range, # Attacks, to Hit, TSM, SA _ Last line included is the Points Formula based cost and Formation type suggested for this model. All formations of Mecha are single model formations, and thus have a BP of Model. Included in parenthesis is the Morale value for this model. Note that while no Company Formations are suggested, they may be created if desired.
Light Mecha
ABL-4 (Arbalest; FE073) 20cm, 2+, +1, ECM 3, Wounds 4; FArc 270 Missiles: 10cm-70cm, 2, 3+, -5, Streak 3 Lascannon: 30cm, 1, 3+, -1 353.25 Support (3)
ABL-5 (Arbalest; FE075) 15.5cm, 3+, +2, Reactive 2, Wounds 4; FArc 270 Las Destroyer: 40cm, 2, 4+, -3 Missiles: 15cm-70cm, 1, 4+, -3 176.38 Support (1)
AG-5M1 (AgroMech MOD; DA087) 14cm, 4+, +3, Wounds 4 Autocannon: 15cm-50cm, 1, 4+, -3 Power Saw 93.12 Support (3)
AG-5M2 (AgroMech MOD; DA088) 15.5cm, 5+, +4, Wounds 3 Autocannon: 20cm-60cm, 1, 6+, -4 Power Saw 81.45 Support (2)
AG-6M (AgroMech MOD B; FE067) 14cm, 3+, +4, Heavy 1, Wounds 4 Assault Cannon: 15cm-60cm, 1, 4+, -3 Chainfist (Thresher) 135.17 Support (3)
AG-8M (AgroMech Mk2 MOD; FE065) 15.5cm, 3+, +2, Wounds 3 Flamer: SmTear, 6+, -4, Ignore Cover Chainfist (Thresher) 112.57 Support (2)
CH-4 (Crimson Hawk; DFA094) 19.5cm, 3+, +1, ImpTarget 1, Jets 2, Wounds 4 Flamer: SmTear, 3+, -4, Ignore Cover Las Destroyer: 50cm, 1, 3+, -3 Lascannon: 50cm, 2, 3+, -2 255.57 Support (3)
CH-4A (Crimson Hawk; DFA095) 17.5cm, 3+, +2, Decoy 1, Jets 2, Wounds 4; FArc 270 Flamer: SmTear, 4+, -4, Ignore Cover Las Destroyer: 10cm-60cm, 1, 4+, -3 Lascannon: 10cm-60cm, 2, 4+, -2 230.17 Support (2)
CH-5 (Crimson Hawk; LI101) 16.5cm, 2+, +2, Jets 2, Wounds 4 Las Destroyer: 60cm, 2, 5+, -3, Alpha Strike 1 116.82 Support (3)
CH-6 (Crimson Hawk; LI103) 15.5cm, 2+, +3, Heavy 4, Jets 2, PD(4), Wounds 4; FArc 270 Autocannon: 50cm, 1, 5+, -1 186.39 Support (2)
CH-SF392-90D (Crimson Hawk - Katsu Moriyama; FE087) 15.5cm, 0+, +6, Change Orders 1, Hard 1, Heavy 2, HQ, Jets 2, Wounds 4; FArc 270 Las Destroyer: 50cm, 2, 4+, -4 394.03 Special (--)
CON-8-1 (ConstructionMech; DA075) 15.5cm, 4+, +8, Wounds 3 Fist (Backhoe) Fist (Lifter) 111.4 Support (3)
CON-8-2 (ConstructionMech; DA076) 15cm, 4+, +8, Wounds 3 Fist (Backhoe) Fist (Lifter) 120.3 Support (2)
CON-8H-M (ConstructionMech Mk2 MOD; DFA089) 13cm, 3+, +1, Wounds 3; FArc 270 Autocannon: 10cm-50cm, 1, 5+, -4 Fist (Lifter) 80.8 Support (3)
CON-8H1 (ConstructionMech Mk2; DFA085) 13.5cm, 3+, +2, Wounds 3 Fist (Lifter) Fist (Lifter) 87.42 Support (3)
CON-8H2 (ConstructionMech Mk2; DFA086) 16cm, 4+, +10, Wounds 3 Fist (Lifter) Fist (Lifter) 123.42 Support (3)
CON-8H3 (ConstructionMech Mk2; DFA088) 18cm, 4+, +10, ImpTarget 1, Infiltrate, Wounds 3 Fist (Lifter) Fist (Lifter) 210.5 Support (1)
CON-9M-B (ConstructionMech MOD-B; DFA083) 15.5cm, 3+, +5, Wounds 3; FArc 270 Autocannon: 10cm-60cm, 1, 2+, -3, AP 2 Fist (Lifter) 218.67 Support (2)
CON-9M1 (ConstructionMech MOD; DA084) 15.5cm, 3+, +5, Wounds 3; FArc 270 Autocannon: 10cm-50cm, 1, 3+, -2 Missiles: 10cm-50cm, 1, 3+, -1 Fist (Lifter) 116.3 Support (3)
CON-9M2 (ConstructionMech MOD; DA085) 13cm, 2+, +4, Wounds 3 Autocannon: 10cm-50cm, 1, 5+, -1 Missiles: 10cm-50cm, 1, 5+, -1 Fist (Lifter) 109.74 Support (2)
DC331-98A (Panther - Fetanet Eryaman; DA107) 13cm, 3+, +2, Jets 3, Wounds 4 Missiles: 30cm, 1, 4+, -2 Plasma Gun: 10cm-60cm, 1, 4+, -3, AP 3 162.15 Special (--)
ED-X2M1 (ForestryMech; DA079) 17cm, 4+, +4, Camo 3, Wounds 3 Chainfist 108.23 Support (3)
ED-X2M2 (ForestryMech; DA080) 18cm, 4+, +7, Camo 3, Wounds 3 Chainfist 152.68 Support (2)
ED-X4B (ForestryMech B; LI084) 20.5cm, 4+, +6, CC Dodge 2, Hard to Hit 1, Wounds 3 Fist Ball 173.51 Support (1)
ED-X5M (ForestryMech MOD; DA090) 17cm, 4+, +5, Camo 3, Wounds 3 Autocannon: 10cm-60cm, 1, 4+, -2 Chainfist 130.81 Support (3)
FS-9H1 (Firestarter; FE076) 19cm, 4+, +2, Jets 2, PD(4), Wounds 4 Flamer: SmTear, 3+, -3, Ignore Cover Las Destroyer: 10cm-60cm, 1, 3+, -3 156.33 Support (3)
FS-9H2 (Firestarter; FE078) 17.5cm, 2+, +3, Jets 2, PD(4), Wounds 4 Flamer: SmTear, 3+, -3, Ignore Cover Lascannon: 15cm-50cm, 1, 3+, -1 226.28 Support (1)
KSH-3 (Koshi; DA093) 18.5cm, 3+, +1, Decoy 1, Forward Observer, Jets 3, Markerlights, Sniper, Wounds 4 Las Destroyer: 60cm, 1, 5+, -3 Fist 158.18 Support (3)
KSH-4 (Koshi; DA094) 20cm, 5+, +3, Forward Observer, ImpTarget 1, Jets 3, Markerlights, Sniper, Wounds 5 Las Destroyer: 40cm, 2, 2+, -3 Missiles: 30cm, 1, 2+, -1 208.53 Support (2)
LCT-5M2 (Locust; DFA100) 24.5cm, 6+, +1, Hard to Hit 3, Wounds 3 Lascannon: 50cm, 1, 5+, -2 Las Destroyer: 30cm, 2, 5+, -4 82.13 Support (1)
MD-5 (MiningMech; DA073) 11.5cm, 3+, +6, CC Dodge 3, Wounds 3 Chainfist Chainfist 161.44 Support (3)
MD-8M1 (MiningMech MOD-B; FE070) 12cm, 2+, +2, Heavy 2, Wounds 3 Autocannon: 40cm, 1, 5+, -1 Missiles: 40cm, 1, 5+, -1 Power Ram 122.21 Support (3)
MD-8M2 (MiningMech MOD-B; FE071) 14.5cm, 3+, +5, Heavy 1, Wounds 3 Autocannon: 40cm, 1, 5+, -1 Missiles: 40cm, 1, 5+, -1 Power Ram 120.21 Support (2)
MD-8M3 (MiningMech MOD-B; FE072) 13.5cm, 2+, +5, Wounds 3; FArc 270 Autocannon: 40cm, 1, 5+, -2 Missiles: 40cm, 1, 5+, -2, AP 3 Power Ram 155.12 Support (1)
SDR-8R (Spider; DA096) 22cm, 4+, +3, CC Dodge 1, Jets 2, Wounds 3; FArc 270 Lascannon: 30cm, 1, 3+, -2 82.13 Support (3)
ULR-C (Uller; DFA108) 21.5cm, 4+, +3, Hard to Hit 1, PD(2), Sniper, Wounds 4 Scatter Guns: 40cm, 1, 3+, -4, AtPr 2 Lascannon: 40cm, 2, 3+, -2 171.64 Support (1)
ULR-E (Uller; LI100) 19.5cm, 3+, +2, Reactive 3, Wounds 5; FArc 270 Plasma Gun: 40cm, 1, 4+, -3 Missiles: 15cm-70cm, 1, 4+, -3, AP 3 239.3 Support (1)
ULR-I1 (Uller; DFA105) 15.5cm, 3+, +0, ECM 2, Heavy 3, PD(2), Wounds 5 Las Destroyer: 40cm, 1, 5+, -3 Plasma Gun: 60cm, 1, 5+, -3 147.91 Support (3)
ULR-I2 (Uller; DFA106) 18cm, 3+, +0, Reflective 1, PD(2), Wounds 5 Las Destroyer: 40cm, 1, 4+, -3 Plasma Gun: 70cm, 1, 4+, -4 127.85 Support (3)
ULR-W (Uller; DFA107) 19.5cm, 4+, +2, ImpTarget 2, Infiltrate, Wounds 4 Las Destroyer: 40cm, 1, 3+, -3, Pulse 2 Las Destroyer: 70cm, 1, 3+, -4 195.88 Support (2)
WSP-3L (Wasp; LI094) 20.5cm, 5+, +0, Decoy 2, Wounds 3; FArc 270 Missiles: 60cm, 1, 5+, -4, AP 3 Lascannon: 30cm, 1, 5+, -2 131.6 Support (2)
_________________ Net Epic Coordinator
Last edited by MagnusIlluminus on Sat Sep 24, 2016 8:03 pm, edited 1 time in total.
