Titan Data Sheets For Alternative Rules
 Post subject: Titan Data Sheets For Alternative Rules
PostPosted: Fri Nov 01, 2013 7:13 am
Hi,
I've lost track of where we are with the templates I've designed on Excel for Titan Data Sheets so have set up a seperate thread. I know they aren't exactly pretty but they hopefully will be functional.
Note that these templates contain sections / notes which refer to the new Titan Plasma rules created by Primarch, while the Damage Tables are those created by Dwarf Supreme.
As usual, I can't post Excel files to the forum, but anyone who requires these can email me asking for a copy of the Excel versions at: thebissler@gmail.com
I'd really appreciate it if anyone was available to proof-read these as when I put these together over a series of nights when I was having trouble sleeping! Any changes required can easily be rectified!
Ok, first up the Imperial Titans. Note that they all use the same damage table so it is a case of running a copy of that one off no matter which class of Titan you are fielding in battle.
Warhound Titan Data Sheet.pdf [178.05 KiB]
Downloaded 602 times
Reaver Titan Data Sheet.pdf [178.98 KiB]
Downloaded 584 times
Warlord Titan Data Sheet.pdf [179.01 KiB]
Downloaded 573 times
Imp. Titan Damage Tables.pdf [276.23 KiB]
Downloaded 532 times
 Post subject: Re: Titan Data Sheets For Alternative Rules
PostPosted: Fri Nov 01, 2013 7:23 am
Eldar Revenant Titan Sheets
Revenant Titan Data Sheet.pdf [261.45 KiB]
Downloaded 788 times
Revenant Titan Damage Tables.pdf [280.13 KiB]
Downloaded 519 times
PostPosted: Fri Nov 01, 2013 7:26 am
Phantom & Warlock Titan Sheets. The damage tables are identical for both.
Phantom Titan Data Sheet.pdf [263.28 KiB]
Downloaded 534 times
Phantom Titan Damage Table.pdf [276.14 KiB]
Downloaded 521 times
Warlock Titan Data Sheet.pdf [267.76 KiB]
Downloaded 556 times
Warlock Titan Damage Table.pdf [276.14 KiB]
Downloaded 512 times
PostPosted: Fri Nov 01, 2013 7:27 am
Ork Gargant Data Sheet (Damage table and Slasher Gargant forms to follow in due course).
Gargant Data Sheet.pdf [179.44 KiB]
Downloaded 554 times
PostPosted: Fri Nov 01, 2013 10:37 pm
Nice work, Bissler!
PostPosted: Fri Nov 01, 2013 11:48 pm
Dwarf Supreme wrote:
Nice work, Bissler!
I concur! Great stuff!!
Hey, DS, got an ETA for bio-titans damage tables and chaos?
PostPosted: Sat Nov 02, 2013 12:46 am
Nice work, Bissler!
Yes, as soon as I get off my lazy a**! :D I'll try to get to them this weekend.
PostPosted: Sat Nov 02, 2013 1:43 am
Nice work, Bissler!
Lol! ;D
PostPosted: Sat Nov 02, 2013 7:25 am
Take your time DS. Because when you post 'em, I'll have to get off my lazy arse and do the Excel spreadsheets! ;D
Glad you both liked the sheets, I wasn't and still am not sure if they are good enough. If nothing else, they provide a starting point for anyone wanting to do a prettier version!
