Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
Dwarf Supreme Alternate Damage tables
 Post subject: Re: Dwarf Supreme Alternate Damage tables
PostPosted: Thu Oct 24, 2013 6:31 pm
The Bissler wrote:
Thanks - to make this more obvious, do you want me to put a note about this on the damage sheets?
Yes!
I forget stuff all the time, we must make are playing aids "old man friendly". ;)
PostPosted: Thu Oct 24, 2013 6:44 pm
primarch wrote:
Yes!
Since I did the same thing, I feel your pain! *Looks for pipe and slippers*
PostPosted: Thu Oct 24, 2013 10:41 pm
Mattman wrote:
For cumulative damage, why not use the current rules for damaged locations:
Page 46 Core Rulebook
If a location is hit more than once, roll for damage normally but the second and following hits add a cumulative +1 to the roll. Any result above 6 should be treated as a 6.
The damage bonus is permanent and relates to the exact hit-location that has been hit.
Would still work with these tables.
I created these tables with this exact rule in mind. I thought it was still being used.
PostPosted: Fri Oct 25, 2013 3:36 am
Great!
It seems only me an Bissler don't read the rules. ;)
PostPosted: Fri Oct 25, 2013 4:18 am
Mattman wrote:
If a location has been destroyed or blown off, the shot will hit the hull (if that wouldn’t make sense, choose another logical location) with an additional -1 TSM.
This rule caused me a measure of confusion for a while. I haven't looked all that closely at the various Titans and Praetorians, but there don't seem to be all that many that actually have a hull location. This was very confusing.
If you don't end up changing the rules for this, then it needs to be clarified that the rule is referring to a particular hit location and I would recommend the damage tables for each praetorian/titan label the location that is meant to be default.
First we have to decide exactly how the rules are supposed to be working however.
Thanks,
Troy
