Death Wheel and Decimator
 Post subject: Death Wheel and Decimator
PostPosted: Thu Jul 12, 2007 4:25 am
It was suggested we develop rules for the Chaos Death Wheel and Decimators for NetEpic (seeing decent proxies might become available :) ) and submit them to Incoming. ?So who's up on what they should be like?
Decimator = Baneblade type capabilities...maybe H-Bolters instead of the backup Lascannons? ?Slightly higher CAF and 2+ armour maybe, but still Superheavy.
Death Wheel - is this a Superheavy or is it Praetorian class? ?High CAF, maybe an upgraded Deathroller ability (destroy vehicle class and below on a 3+?), mobile, must always make a full advance move, firepower maybe equal to 2 Baneblades?
Fire bad, tree pretty - Buffy
PostPosted: Thu Jul 12, 2007 6:10 am
I've not seen or heard of the Decimator, so that sounds pretty good.
As to the Death Wheel, I'm not a fan of it myself.  It frankly seems a bit goofy for Chaos to me, something I could see the Orks doing but not Chaos.  If you do decide to include it, then make it a small Praetorian (like the Plague Tower).  It looks like its about that size.
You know, if you can sort of muscle your way past the gag reflex, all kinds of food possibilities open up!
PostPosted: Fri Jul 13, 2007 2:33 am
With Void Shields and "firepower" attacks apparently.  I'm thinking small Praetorian, Void shields, modified Death Roller etc. ?  Front Template is going to be simple :)
PostPosted: Fri Jul 13, 2007 2:22 pm
I agree that Praetorian class would be appropriate. I forget, do they have Void Shields in E:A?
PostPosted: Sun Jul 22, 2007 10:13 pm
Ahem... please remember that Land Train has void shields too. And it isn't a praetorian. The size of a model can't be used to judge its class. Consider cramming a whole company of guard models into a Leviathan model.   Or 5 stands of Berserkers into a land train battlecar for that matter. :D
Death Wheel does have DC4 in E:A while Warhound has DC3, true. But Baneblade has DC3 as well and it isn't a praetorian.  :;):
PostPosted: Mon Jul 23, 2007 3:08 am
OK, good point Mojarn.  Just a Superheavy with a couple of Void shields then do you think?  Would make it heaps simpler.  Off the top of my head (and consciously avoiding any special rules):
Doom Wheel   25cm  1+  CAF 8   Lascannon 75cm 2 5+ -2, Hvy Bolter 25cm 4 5+ 0
- Superheavy, Void Shields (2), Deathroller, Fear
Special Card (standard Chaos list)  Morale -, break 1, VP3, Cost 250.  (or we could up the firepower and make it more expensive)
Decimator 5cm 1+ (All round) CAF 6  Decimator Cannon 100cm 1 4+ -3 *, Hvy Bolter 25cm 4 5+ 0 **
- Superheavy, *Penetrating(1), **Turret
Support card (Standard Chaos list) Morale 3, break 1, VP2, Cost 200.
How's that sound?
PostPosted: Mon Jul 23, 2007 3:45 pm
Those stats look good to me. Mojarn does have a valid point: superheavy is fine by me.
PostPosted: Tue Jul 24, 2007 10:11 am
(zap123 @ Jul. 23 2007,05:08)
How's that sound?
Sounds good.
I'm just wondering whether both should be 2 per card like Warhounds.
PostPosted: Tue Jul 24, 2007 2:36 pm
(Mojarn Piett @ Jul. 24 2007,05:11)
Since they're Superheavies, I say keep them as one per card, unless you can think of a fluffy reason why they would normally operate in pairs.
PostPosted: Wed Jul 25, 2007 12:24 am
I agree with DS, as Standard list units they'd be more likely to be one per card due to the irregular nature of the "LatD" type list.  Though we could do a Special card for the Black Legion with 2 Death Wheels perhaps?
I'll talk to OzTenaka and might see if we can put out a 5.3 Chaos army book in anticipation of the Gold book?
PostPosted: Wed Jul 25, 2007 2:13 am
Super heavy, with shields.
PostPosted: Sun Jul 29, 2007 12:28 am
OK, ran them on Friday (will post a full report when I get some Bandwidth back on Wednesday).
Didn't get to see much of the Decimator as it missed its' first shot then got vapourised by Magnus (war in Hell), but I think it looks fairly conservative but still a useful and useable addition to Chaos.
The Death Wheel is seriously under-done though.  Compare to a Warhound with TLD and VMB for the same points and it just wouldn't get played.  So, we came up with two possible options (staying special card at 250 points):
1 (big shooter):  Doom Wheel   30cm  1+  CAF 8   Lascannon 75cm 4 4+ -2, Hvy Bolter 25cm 4 5+ 0
2: (alrounder): Doom Wheel   30cm  1+  CAF 10   Lascannon 75cm 2 5+ -2, Autocannon 50cm 4 5+ -1
Option 1 is a slightly detuned "Warhound with twin TLDs" long range shooter type unit.  Chaos can always use some of these.  Option 2 is sort of a beefed up Questor Scout Titan.  I think either would be fine.....votes?
Also we thought perhaps the Black Legion list could get a Company Card of 3 of them?
PostPosted: Wed Aug 01, 2007 3:03 pm
I think fear is a little too much...chaos titans do not cause fear but are terrific too...
Fair players live longer
Epic40k.fr Techpriest
PostPosted: Thu Aug 02, 2007 12:24 am
I think a 12 metre high wheel rolling toward me might make me a little aprehensive :D.
