ADEPTUS MECHANICUS LIST Errata
 Post subject: ADEPTUS MECHANICUS LIST Errata
PostPosted: Wed Mar 14, 2007 10:38 am
The following changes will be made to this list
Pg 3 - Change "Coxed" to "Codex"
Pg 4 - In Sample Army List change Warhounds #2's  second weapon from Laser Blaster to a second Vulcan Mega Bolter
and Warhound #4's second weapon to Inferno Gun.
Only way to give valid weapons and keeping sample list at 6000 pts unless someone wants to completly redesign sample army
Pg 5 - Astropath Guidance Power.
Replace last 2 sentences (that start with If both conditions ....) with "The artillery may fire as if they had Line of Sight to the target to be fired at. All other rules for the artillery piece still apply."
Previous version made it more complex than it needed to be.
Pg 5 - Make the Baron Description say "Command, Elite and HQ" (instead of just Elite and HQ) to match its description in stats and how other units are listed.
pg 6 Hellhound change "on a 4+" to "on a 5+"
pg 7 - Ordinatus Armageddon
2nd Paragraph 1st Sentence add "(as per the table on page 19)"
pg 11 - Vortex Missle
change "moves 2d6" to "moves 2d6cm" in result 5-6 box
pg 18 Imperial Dropship template
Change "Transport 60 pts of stuff" to "Transport 60 points of units (see description on pg 7)"
Thats it for the moment if there is anything else that you think I missed let me know.
PostPosted: Thu Mar 15, 2007 1:14 am
They all seem very reasonable to me.
PostPosted: Thu Mar 15, 2007 9:12 am
I did particularly like the "Transport 60pts of stuff"  :laugh:
PostPosted: Fri Mar 16, 2007 2:20 am
(OzTenaka @ Mar. 15 2007,03:12)
Sometimes after editing and writing things for netepic after 10 years, "stuff" seems to be a likelier words to use.....  :;):
PostPosted: Fri Mar 16, 2007 10:06 pm
This list all corrected
PostPosted: Wed Mar 28, 2007 11:35 am
Further addition
I have noticed that the Hunter (both on this list and the SM list) has their weapon listed in the description as "this is equipped with rapid-fire anti-aircraft guns. "
However in the stats line it is listed as having SAM launchers.
I can't recall the mini so can someone enlighten me as to its weapon fit out?
PostPosted: Wed Mar 28, 2007 12:16 pm
(OzTenaka @ Mar. 28 2007,11:35)
Hunter is an Epic Armagedon vehicle, uses a variation of the Whirlwind (which is sold with a hunter turret as well as the whirlwind one).
EA calls the weapon a "Hunter-killer", firing hunter missiles.  Both used as AA and against ground units (but thats true of many EA AA guns).  So it is a kind of SAM launchers.  Don't know where the "rapid-fire" "guns" thing came from.
PostPosted: Wed Apr 04, 2007 1:57 am
Not necessarily an Errata but a clarification on how the Knight Lancer Power Lance works.  It is "an attack in the Combat Phase, before Close Combat dice are rolled".  So....is this a shot?  If I charge a shielded Warhound and I hit with the Power Lance, do I knock down a shield, or do I hit the titan itself.  If (b, and also if the Titan had no shields, does the attack scatter on the template, or automatically hit the desired target?
Fire bad, tree pretty - Buffy
PostPosted: Wed Apr 04, 2007 2:50 am
(zap123 @ Apr. 03 2007,20:57)
As it occurs in close combat it happens inside the shields, so it hits the titan, no scatter.
To be reasonable it hits a location the model could physically read, so I don't think if it assaulted a warlord certain higher up places could not be hit.
PostPosted: Wed Apr 04, 2007 4:26 am
Fair enough.  Make the Lancers quite decent...good reason for them being the same cost as Paladins now.
PostPosted: Thu Apr 05, 2007 2:30 am
(zap123 @ Apr. 03 2007,23:26)
Actually the main reason for taking them IS their anti-titan, anti-praetorian role.
They are good at this...
..assuming they live to get that close.....  :;):
PostPosted: Thu Apr 05, 2007 2:57 am
Yeah, I have noticed that the anti-swarming rule has dramatically increased the value of knight class units.  In the old days thay were just a funny sort of tank, but now they have a clear difference and greater utility.
PostPosted: Thu Apr 05, 2007 11:14 am
Hi,
I posted this in the Mechanicus issues, but it doesn't look like it was looked at, so here it is again:
No support card (p29) listed for the tactical platoon.  I assume there should be one, as the Tech-Guard Titan Defense Company has 3, and doesn't specify their composition.
Netepic 4 lists them as 6 stands per platoon in  the company, but doesn't list a support card; 6 per platoon would fit the 500pt cost of the Titan Defense Company.
A support card would be 150.  A little cheap compared to Eldar Guardians(1 less morale pt), but 200 seems far too expensive.
PostPosted: Thu Apr 05, 2007 9:19 pm
I have already added it loofnick - sry if I didn't reply confirming it but as it was a clear omission I just added it in
PostPosted: Thu Apr 05, 2007 11:07 pm
:)   Fair enough.   Thanks Oz!!
