Snap fire at Pop-up targets
 Post subject: Snap fire at Pop-up targets
PostPosted: Mon Jun 05, 2006 11:01 pm
Wow..We just played our very first game of Netepic :8:  Simply Smashing! to say the least...right...now,we had a little confusion on the popup rule and snap fire working at the same time.
I saw it as if you are "popping-up" you are no longer "stationary"( rule stating that to pop-up you must be under "First fire" order),even though yuor "first fire" order says that you are?? confusion here.
We had to roll the die,I won. So my hypothesis prevailed-I was able to snap fire at his popping up wave serpent.
What say any of you.
Thanks from Wisconsin. PS Netepic rules! :laugh:
... there is nothing like the smell of bolter burned wraithbone armour in the morning....it smells like...like Victory!
PostPosted: Tue Jun 06, 2006 7:17 am
Pop up is a special case of the First Fire order. The thingy has to move in order to be able to pop up (it's pretty hard to, say, get to the level of a rooftop without moving) and, thus, can be snap fired.
So I'd say you did it the right way.  :)
Oh, and welcome to Net Epic.
PostPosted: Tue Jun 06, 2006 12:28 pm
Quote (Mojarn Piett @ 06 June 2006 (07:17))
So I'd say you did it the right way. ?:)
I concur with the esteemed gentleman above.  I've always counted pop up attacks as being snap fireable at.
I am become death the destroyer of worlds.
PostPosted: Tue Jun 06, 2006 2:43 pm
Quote (Enderel @ 06 June 2006 (12:28))
I concur with the esteemed gentleman above. ?I've always counted pop up attacks as being snap fireable at.
Ditto. I play it that way as well.
PostPosted: Tue Jun 06, 2006 8:44 pm
Thanks fella's. Another question do you allow simultaneaus damage?i.e. popup and first firer,possibly doing each other in?
PostPosted: Tue Jun 06, 2006 8:49 pm
I've always assumed that the snap fire occurs before the pop up attack
PostPosted: Tue Jun 06, 2006 10:38 pm
Quote (Dwarf Supreme @ 06 June 2006 (20:49))
Now I would say that seeings how both are on "first fire" orders,that they could both possibly do each other in. Assuming popping up takes several seconds to aquire target,one would assume likewise for an overwatch to pick up a momentary target...
PostPosted: Wed Jun 07, 2006 8:23 am
I've always thought of snap fire being a rapid reaction rather than a considered shot as an overwatch one implies.
My take on it is you've got a highly wired unit just waiting to see something to move into line of sight and when it does the finger is already on the trigger...
Remember the whole process of the fire fire stage could be undermined by your choice!  Surely all weapons on first fire are firing at the same time or similar times could they also not have mutual self destruction options?
Then again the rules are guidelines and if your interpretation is that they would both fire at the same time then just agree that with your opponent before hand.  :D
PostPosted: Wed Jun 07, 2006 10:14 pm
Quote (Mojarn Piett @ 06 June 2006 (02:17))
Sorry for the delay, been out for a few days.
Your interpretation is correct. Pop up targets CAN be snap fired.
PostPosted: Wed Jun 07, 2006 10:16 pm
As DS said snap fire occurs BEFORE pop up fire. So if snap fire destroys pop up fire units they cant fire back.
