Squat tanks
 Post subject: Squat tanks
PostPosted: Tue Dec 02, 2014 2:51 pm
Tinkering with some miniature designs. I was wondering how you would imagine the Iron Hammer is armed:
The Heavy Thunderer - Is this roughly the same weapon as seen on a Space Marine Vindicator? And if so, would the 2 attack dice mean that it is supposed to be twin barrelled?
 Post subject: Re: Squat tanks
PostPosted: Tue Dec 02, 2014 3:26 pm
Not really ... in the old SM1 days we called that a Grade 2 weapon. You rolled 2d6. For example, the standard Eldar plastic Falcon Mk.I had a Grade 2 Las-cannon, but only one barrel. 8)
PostPosted: Tue Dec 02, 2014 5:20 pm
Actually At/SM1 called them "barrels", sort of a misnomer. Since it did not physically need to have more than one. The attack die were based on the amount of "barrels". Very confusing wording.
PostPosted: Tue Dec 02, 2014 5:34 pm
Such strange timing for this subject as the other day my nephew mentioned about Squats being able to take Land Raiders and previously I hadn't noticed this. When I checked out the rules I also discovered about the Iron Hammer and also the Iron Shield vehicles. Just goes to show that when I went to Gold I never really read the rules through for the army lists, I always just looked for stats and rules for stuff that I had!
Anyway after that meandering story about nothing at all, I'll leave you with a question (or two): I can see there are minis used in the Gold book. Where are they from? If no one is sure, is there a proxy anyone uses?
PostPosted: Tue Dec 02, 2014 6:48 pm
The models used for the Iron Hammer and Iron Shield in the Squat book are from Exodus Wars. They are the Guild Achilles and Guild Hector respectively. Though I don't think it matters what models you use, we are in a world of proxies given the game is OOP.
Matt
PostPosted: Tue Dec 02, 2014 6:59 pm
With regards to what the heavy/mega thunderer is like, it could be similar to the Thunderer/Demolisher Cannon, or just a bigger battle cannon.
The game has gone way past linking AD to number of barrels. Maybe the gun has a quick reload capability or maybe its shells cause an explosion that could hit multiple targets, but doesn't really work like a barrage weapon? Who knows.
PostPosted: Tue Dec 02, 2014 7:12 pm
Based on the description of the Iron Hammer (and despite the picture) I imagine this vehicle having a turret that is almost larger (in length & width, but not height) than the tank's body. Think of a Land Raider with a Vindicator as a turret. No, not a Land Raider. Perhaps a Leman Russ with a Thudd Gun as a turret.
Net Epic Coordinator
PostPosted: Tue Dec 02, 2014 9:23 pm
Since GW never made any "tanks", only praetorian sized vehicles, there is a lot of latitude in designing a "squat" tank.
I think the more poignant question is, how should squat vehicles look like over all.
What makes a tank say, "yeah, squats built this"?
I'm not really sure of an answer.
PostPosted: Fri Dec 12, 2014 2:32 pm
Just trying out something different based on Magnus' suggestion: Here's a quick mock up for a big blocky turret.
PostPosted: Fri Dec 12, 2014 5:18 pm
I like this better. The look is more "distinct".
PostPosted: Fri Dec 12, 2014 7:17 pm
Nice!
PostPosted: Fri Dec 12, 2014 7:56 pm
Ah, I see you went with a Baneblade with a Vindicator as a turret. Good choice, that looks really appropriate for Squat. Hmm, should we upgrade that vehicle to Super Heavy status? Probably not really, just define it at about 75% to 80% of the size of a Baneblade and we should be good.
PostPosted: Fri Dec 12, 2014 11:20 pm
Naw. Keep the stats as they are. The idea is to build a model that fits the stats and not the other way around. Otherwise a lot of playtesting would have been wasted :)
PostPosted: Wed Mar 11, 2015 3:54 pm
Hypothetically speaking:
If a set of Squat vehicles were to be produced, how many would you want of each type?
From a production standpoint, a mould casts a number of models with each spin, so if several unit types are to be included, one needs to take into account expected sales of each type, to get the ratio right.
Iron Hammer MBT
Iron Shield APC
Retributor Assault Tank
Grudgekeeper Artillery
I'm guessing a rather even distribution of the 3 regular tanks, and relatively fewer of the Grudgekeepers. Perhaps a 1/3 ratio (Eg. 3 Iron Hammers, 3 Iron Shields, 3 Retributors and 1 Grudgekeeper in a single mould - depending a bit on how many will fit in one)
Miniature availability has been a limiting factor for Squat armies so far, but if there were no limitations, how many would you pick for your average army?
PostPosted: Wed Mar 11, 2015 4:41 pm
Ragnarok tank minis don't get a lot of love. Perhaps they could make a good proxy for a Squat heavy tank.
I do like Warmaster Nice's tank. Stuff like that might move me to do some Squats one day.
