Net Epic Forums reorganization
 Post subject: Net Epic Forums reorganization
PostPosted: Mon Nov 10, 2014 2:14 pm
Cybershadow has kindly reorganized the forums for us!
The posts from net epic core and backgrounds will be placed in the general threads section of these forums and that will end the reorganization.
It should be easier to find stuff now. :)
If there are threads you wish for me to move around let me know.
 Post subject: Re: Net Epic Forums reorganization
PostPosted: Mon Nov 10, 2014 5:13 pm
Not sure I like that we don't have separate army sections :-\
PostPosted: Mon Nov 10, 2014 7:41 pm
I believe that was the consensus, to leave army lists to specific threads in the appropriate folder. ;)
PostPosted: Fri Nov 14, 2014 12:56 pm
I like the changes a lot.
We never used to have them before, so it's back to how things were.
The reality is that there are not enough posts or topics to justify separate boards for each army. It's much better just having them all as part of the NetEpic Gold section.
Primarch, just to clarify. All rules questions about confusion/misunderstanding the current (Gold) rules thus go in this board, while all proposals to modify the Gold rules, go in the NetEpic Gold board. Is this correct?
SoƱando con una playa donde brilla el sol, un arco iris ilumina el cielo, y el mar espejea iridescentemente.
PostPosted: Fri Nov 14, 2014 5:39 pm
Yes. Anything specifically gold relating should go in the gold section. Things related to alternate rule sets go in that section (with platinum having its own subsection).
Everything else goes strait into the general net epic section without going into wither alternative or gold.
