Tunnelers that have surfaced
 Post subject: Tunnelers that have surfaced
PostPosted: Tue Jul 16, 2013 1:53 am
Hi, once a tunneler has surfaced and dismounted it troops can it remount the troops go back under the ground and reappear anywhere a turn later or does it only move its allocated movement underground? How do you represent its location underground if it can re-tunnel?
Bugger I hate it when that happens!
 Post subject: Re: Tunnelers that have surfaced
PostPosted: Tue Jul 16, 2013 2:01 am
No. As the current rules stand (and even the original ones), the tunneler ride is a "one way" event. Thus once dismounted you can not remount.
It would be an interesting variant rule though, but maybe tricky to balance.
PostPosted: Tue Jul 16, 2013 2:14 am
Thanks Primarch, so the movement rates given are for movement above ground if the tunneler chooses not to tunnel?
PostPosted: Tue Jul 16, 2013 2:52 am
Movement rates are for above ground movement, whether it tunnels or not. :)
