Compatibility Questions
 Post subject: Compatibility Questions
PostPosted: Fri Jun 14, 2013 12:10 am
Hi,
I was wondering if the other races lists like Necrons and Dark Eldar ect would be compatible with 2nd edition Epic space Marine?
Dean
 Post subject: Re: Compatibility Questions
PostPosted: Fri Jun 14, 2013 12:13 am
There's army books for all the above for the NetEpic Gold release
http://www.tacticalwargames.net/taccmd/viewtopic.php?f=14&t=16938
Since NetEpic is an evolution of SM2 rules it should be easy to (de)volve them into SM2 forms I expect.
PostPosted: Fri Jun 14, 2013 12:15 am
I would just play NetEpic. It's better than SM2.
PostPosted: Fri Jun 14, 2013 12:19 am
Exactly right Jimmy, there isn't too much changed in NetEpic from SM2 rules so you should be able to use the weapons stats and army lists provided in NetEpic Gold to play in SM2 battles. As someone who played the SM2 rules for some years, I can recommend the NetEpic Gold rules set, there's some excellent tweaks to the system, and those that are not to your liking you don't have to use. Well worth a look!
PostPosted: Fri Jun 14, 2013 12:30 am
I had planned on playing Epic 2 and 3 and probably net epic rules too depending on how the mood took me. lol
