Noob queries - targeting and casualties
 Post subject: Noob queries - targeting and casualties
PostPosted: Sun Mar 10, 2013 10:02 pm
Noob questions:
When a unit shoots, can it split fire at different enemy detachments as long as you have LOS, the wording in Netepic seem to say so but I wanted to check?
The shooter then assigns attack dice to every individual unit it wants to i.e. if you were shooting 12 dice at 6 stands you could put 12 shots on one stand or 2 on each?
Presumably if you were to assign 12 shots to one stand and it failed 10 saves, the first fail would kill it, and the remaining 9 be wasted?
And the same goes for snap firing, you assign attack dice before the enemy move?
Thanks
 Post subject: Re: Noob queries - targeting and casualties
PostPosted: Sun Mar 10, 2013 10:10 pm
Exactly right Fredster. The one thing I'd add to that is that occassionally I split fire unevenly, but it's usually if I want to direct a few more shots at a superheavy tank or a Titan.
The one other thing to point out is that you can't fire at HQ units unless they are the closest unit to you (or you have a unit that can target HQs such as Eldar Scouts).
PS Welcome to the boards and hope you enjoy your first battles! Please feel free to share pics of your battles in the Battle Reports section! Look forward to hearing how you get on!
