Pulsa Rokkit question
 Post subject: Pulsa Rokkit question
PostPosted: Mon Dec 05, 2011 9:56 am
In ork book : p16. The Pulsa Rokkit.
"If the template remains in play, replace it with the 6 cm barrage template before rolling on the table."
When we make this second roll ? Immediatly or in the final phase ?
"The template may remain in play for several turns but will not grow any larger."
We must make a roll in the pulsa table in each final phase ?
NetEpic-fr : http://netepic-fr.com/
Member of NetEpic Translation Committee.
"If you break my tea, I break your ass !" Grakor Urg Margor, the ork big boss who like tea !
(sea http://fbruntz.fr/lpt/regles/regles.html)
 Post subject: Re: Pulsa Rokkit question
PostPosted: Wed Dec 07, 2011 2:00 pm
I'd say:
- place the 3cm template where the rokkit lands
- roll in the rokkit table and then:
-> roll of 1: keep the 3cm template, roll to hit on minis under and then remove the template
-> roll of 6: keep the 3cm template, roll to hit on minis under and minis at 6cm from small template and then remove small template
-> roll of 2,3,4,5: remove the small template and place the 6cm template instead and roll to hit minis under
I would have been clearer if the template exchange sentence was been in the 2-5 result table.
PostPosted: Wed Dec 07, 2011 2:22 pm
Thanks ScREaM but I have a second question ;D
I understand it :
1) place the 3cm template
2) roll in the rokkit table and apply the result
3) if the template was not removed, replace it by the 6cm template.
4) make a new roll in the rokkit table and apply the result.
My questions :
1) If the result in rokkit table is 2-5 in the first roll, we apply it with the 3cm template or the 6cm template ? If I understand the rules, we apply it with the 3cm template.
2) When we replace the 3cm template ? Immediatly after apply the 2-5 result or in the final phase (like SM2/TL) ?
3) In the rules, we have
I understand : a new roll in the rokkit table is required in all subsequent final phases (like SM2/TL). Because if we don't roll again, the 6cm table can't be remove ^^.
