Tau Flyers and Imperial Guard Hydras
 Post subject: Tau Flyers and Imperial Guard Hydras
PostPosted: Mon Nov 07, 2011 6:40 am
Hello,
What is the movement on the Tau Flyers? It simply says "Special" on the chart - there are movement rates on the cards, should I assume that we simply use the ones on the cards and there is nothing "Special" about them?
In the Imperial Guard book, there are no mention of Hydras, yet there is a card for them. Are they allowed to use them or not?
Thanks!
Jake
 Post subject: Re: Tau Flyers and Imperial Guard Hydras
PostPosted: Tue Nov 08, 2011 11:25 am
Hi,
i've just checked the 5.2 Tau codex (I do not have the link to the Gold Codex) but all Tau flyers have a movement in the stats table
An old old old missing unit in the codex since years ago...still missing in the Imperial Guard Gold Codex whereas it has a description entry. Just pick the hydra stats & cost in Adeptus Mechanicus codex and replace morale value "3" by standard IG morale "4".
PostPosted: Tue Nov 08, 2011 5:15 pm
Hello,
Thank you for the info - where do you find the 5.2 Tau Codex -or indeed any updated codices that are more recent than the ones posted on this page:
http://www.netepic.org/netepic.html
Thank you again!
PostPosted: Tue Nov 08, 2011 5:21 pm
Gold codex are the latest up-to-date ones.
For 5.2 codex, they can be found on the Wikiwikiwar of the board here.
PostPosted: Wed Nov 09, 2011 7:16 am
Note that some of the published Gold Codex appear to not have had all edits applied.
