IMPERIAL MACHARIUS HEAVY TANK
 Post subject: IMPERIAL MACHARIUS HEAVY TANK
PostPosted: Thu Apr 21, 2011 8:22 am
does anyone created Netepic stats for those pretty nice models?
 Post subject: Re: IMPERIAL MACHARIUS HEAVY TANK
PostPosted: Fri Apr 22, 2011 8:54 pm
I do not remember if Duz.Holger (or a closed pseudo) made some profiles for his DKOK list.
Else, something close to standard SHT:
move: 10cm
save: 2+
CAF: +5
side sponsos: PD(2) or PD(4)
front dual guns: 1x 50cm/1/5+/-2 or 2x50cm/1/5+/-1
for turrets:
- twice vanquisher cannons (should the most expensive variant)
- dual stubbers: 2*50cm/4+/-1 (or -2) (or just find the malcador profile and double the turret weapon)
- dual heavy bolters: 25cm/8/5+/0 ?
For the cost, less expensive than SHT, more expensive than malcadors. I don't have the time to check where we place the malcador profiles :|
PostPosted: Fri Apr 22, 2011 11:54 pm
Is it in the optionals thread? If not, it probably should be :)
PostPosted: Wed May 04, 2011 8:12 am
Here is the proposition for Macharius variants I've just posted on Epic french board:
Macharius Company:
Contents: 3x Macharius heavy tanks
Cost: 450 | Moral:3 | VP:5
Move: 10cm | Save: 2+ | Caf: +6 | Notes: Superheavy, PD(4)
Weapons:
- Name: Heavy Stubbers | Range: 75cm | Attack Dices: 2 | To-Hit Roll: 4+ | TSM: -2 | Notes:Turret
- Name: Stubbers | Range: 50cm | Attack Dices: 2 | To-Hit Roll: 5+ | TSM -1
- Name: Heavy Bolters | Range: 25cm | Attack Dices: 2 | To-Hit Roll: 5+ | TSM: 0
Macharius Vanquisher Company:
Contents: 3x Macharius Vanquisher heavy tanks)
Cost: 500 | Moral:3 | VP:5
Weapons:
- Name: Vanquisher | Range: 100cm | Attack Dices: 2 | To-Hit Roll: 5+ | TSM: -2 | Notes:Turret, Penetrating(+1)
Macharius Vulcan Company:
Contents: 3x Macharius Vulcan heavy tank
Cost: 400 | Moral:3 | VP:4
Weapons:
- Name: Vulcan heavy bolter | Range: 25cm | Attack Dices: 8 | To-Hit Roll: 4+ | TSM: 0 | Notes:Turret
PostPosted: Wed May 04, 2011 8:32 am
Sounds nice to me
especially the weapon stats are fine
though the super hevay makes the heavy stubber variant a cheap baneblade
maybe just remove the super heavy from all three variants
and keep the point costs as they are
If they are no super havy tanks there could be a CO. with 10 tanks
1 det.(3 tanks) of each variant+ anyone command macharius tank
for hmm 1300 points?
PostPosted: Wed May 04, 2011 9:00 am
If SHT is removed, they would be the same class than malcadors...And with the size of the minis, being SHT seems logical.
Yes, Macharius could become a cheap Baneblade but it's Caf is worse, less armor, far less PD. Imho, it's the Baneblade that have a problem, not the Macharius. Baneblade should have a front demolisher weapon in its profile but that's another debate ;)
PostPosted: Wed May 04, 2011 9:06 am
I looked through the FW range and you are right
the Macharius is more a SH tank
Some good points here
yes the baneblade is a bit underpowered ;D
PostPosted: Wed May 04, 2011 10:28 am
I've never taken Baneblades, if I want to dig in and hold an objective I use Stormhammers, if I want to take out titans or super heavy tanks then its all about the Shadow Sword.
Tom Webb
PostPosted: Wed May 04, 2011 12:03 pm
Baneblades battlecannon can be usefull when all your standard AA is broken/destroyed but the tank suffers its polyvalence: not good in a particular compartment.
PostPosted: Wed May 04, 2011 8:50 pm
I like Baneblades, the models
but netepic is right compared to all other Sh tanks they are underpowered
PostPosted: Mon Mar 30, 2015 8:02 pm
Replace one Battlecannon with a 75cm Demolisher cannon hitting at 4+ and having a TSM -3 ignoring Cover
there you have your usefull Baneblade ;D
up
PostPosted: Tue Mar 31, 2015 3:49 am
Re: Baneblade, Demolisher variant
The Points Formula values for that are:
Company: 344
Support: 180
Standard Baneblade is:
Company: 330
Support: 173
Thus their values are vary similar, though not quite identical. For NetEpic Gold or 2nd edition values, they would probably be the same.
Net Epic Coordinator
