IG organization
 Post subject: IG organization
PostPosted: Sat Nov 21, 2009 1:58 am
hi after a long a deep dive in to the russian army's organization (IG is organized uncanny similar) i have come up with this chart (i know that division and corp can be a mix up by me but it is to make a death korps bigger)
what do you think and is it usable
sun tsu the art of war
PostPosted: Sat Nov 21, 2009 5:57 am
Yes, it is usable ... And that is not only valid for the Russians but most Armies.   Generally, an Army is 2-4 Corps, a Corps = 2-4 Divs., a Div = 3 Rgts or Bdes, a Rgt/Bde =  3-5 Bns, a Bn = 4-6 Co. and a Co. = 3-4 Plts.  It's not unheard of an Army having more then 4 Corps and a Corps having more than 4 Divs either.  A 2 Bn Rgt is rarer but it's not unheard of ... And as a matter of fact I based my IG on SM1 MTO&Es and each Bn there only has 2 companies + 4 Bn Spt units ...
PostPosted: Fri Nov 27, 2009 12:23 am
How many BN do you field in your SM1 MTO&Es Imperial Regiment?
I am not available for that cognition on my part :D
PostPosted: Fri Nov 27, 2009 12:47 am
In most of my IG Rgts I have 3 Bns  ...  My largest has 5 ...
PostPosted: Fri Nov 27, 2009 9:55 am
So 6-10 Comp./Regiment
In which way you include your SHtanks
for example:
a SHtank regiment copuld be formed out of 30 tanks
3=Comp.
2-5 Comps/BN
2-5BN/Regiment but I think its a bit silly this way
Maybe I will setup the SHtanks
like the germans WW2 Heavy Tank BN in 1944(Caen,Falaise)
where they had heavy tank Bn with Tiger and Tiger2 tanks
about 5 Comp./BN
so you have 15 SHtanks/BN
2 armoured and 1 Shtank BN may form a Regiment
Sounds that usefull for you guys?
PostPosted: Fri Nov 27, 2009 5:08 pm
Yes, we follow the SM1 TO&Es/Lists with a little of SM2, E40K, E:A added ...  So 6-10 Companies is correct ...   An Infantry Co. must have a minimum of 2 Infantry Detachments/Units as do Armor units. A Company may have up to 4 Detachments(Platoons)/Units ...   Heavy Tanks are handled as simply as an Armored Co. may have 2-4 MBT(Russes)Dets/Plts and 0-2 Hvy Dets/Plts. I have some Tank Cos. that have 2-4 MBT Dets/Plts. and the other Co. has 1-2 Hvy Dets.  This is simliar to early German Tiger 1 Cos. Where there were 2 Plts of MK.IIIs & 2 Plts of Tiger Is ...   Also a Rgt may have up to 8 Dets/Plts attached. So to simulate elements of a Separate Hvy Tank Bn(the way some Tiger I Bns were organized mid-War), you could have your Rgt supported by up to 8 Dets/Plts of Hvy Tanks (like Baneblade/Showdowswords etc.).
PostPosted: Fri Nov 27, 2009 8:38 pm
Did you mean with Hvy Tanks Dets/Plts 1 SHT  or 3
If you mean 1, I have to include them in my regiment as detachments
If you mean 3 I can use/set up an Armoured Comp.(LR) alongside with a super SHT Comp.
to form up 1 Comp.
Its a bit tricky because if I include 3 or more SHT Comp per regiment
I easily get more than 6-10 Comp.
