Leviathans - fire out or not
 Post subject: Leviathans - fire out or not
PostPosted: Fri Sep 18, 2009 9:41 am
Hi,
i got a quick question, maybe somebody can help me with. Can companies transported by a leviathan
fire out of it, or is this only possible when riding a capitol imperialis?
cheers
sanjuro
PostPosted: Fri Sep 18, 2009 1:07 pm
Quote: (sanjuro @ Sep. 18 2009, 10:41 )
Hi,
cheers
sanjuro
As it's not stated in the rules, companies inside a Leviathan can not fire out anymore. Only infantry stands can fire out from a Capitol Imperialis. In the old SM/TL rules, even artillery companies inside a CI could fire out :p
Fair players live longer
Epic40k.fr Techpriest
PostPosted: Fri Sep 18, 2009 1:23 pm
thanks scream,
I wonder why anyone would want to put a company into the Leviathan then, though.
PostPosted: Fri Sep 18, 2009 1:31 pm
I don't know too...Maybe keeping some IG assault stands inside protection to disembark them for the 2nd or later turn ?
PostPosted: Sat Sep 19, 2009 9:12 am
If it hadn't been for the brilliant idea of sorting the regimental Command ability of the Leviathan then this would be yet one more sucky doesn't work much item on the long list of crap to be avoided. The transport thing does not work, don't believe otherwise. You'll only regret it when you try it for yourself.
My head is full of War...
PostPosted: Sat Sep 19, 2009 2:38 pm
I too think that Leviathans should get a rule that troops could shoot out from it
perhaps not a full company, I guess someone could make something like the pointdefence for all transport vees that says how many shots might be fired out of the transport (if any). Would add another dynamic to the game ^_^
PostPosted: Sat Sep 19, 2009 3:34 pm
Well, I just upped the weapons to overkill mode! I like them just fine now. my opponents hate em' but I treat them as a Regimental Command in all things. So only one per army. Same with the Imperialis.
However, I've been thinking of using the Imperialis and maybe the Leviathan as a mobile airbase ever since reading Abnetts Double Eagle and some of the Tanith series. Hmmm?  :cool:  :flyboy:
PostPosted: Sun Sep 20, 2009 12:34 am
I don't think I've ever seen a Leviathan used as anything other than a huge gun fortress by IG players.  It is smashingly awesome at it under NE rules, while in the old TL days it just used to get swarmed by Jetbikes etc and destroyed.
I have seen Squats use the Ironbreaker one as a slow transport for the Berserkers.
Fire bad, tree pretty - Buffy
PostPosted: Sun Sep 20, 2009 12:38 am
But surely they could have walked further quicker,, even with their stumpy little legs and their arses dragging along.
EDIT: It says it fits up to a company in the rules. Nothing about aircraft not allowed. Unless there was some sort of special bonus, it wouldn't make much difference what was inside these things anyway.
PostPosted: Sun Sep 20, 2009 12:21 pm
I have used the iron-breaker on a couple of occasions. For me the reason was getting the leviathan on a company card instead of special card and also just trying it out.
I would welcome a * rule about the leviathan making them and the transported items not loose any movement when debarking. Now its plain silly unless you see the leviathan a way of protecting your troops.
Berserkers move 20 cm on change. So with the leviathan push it would become 10+20-5-5=20 Impressive eyy?
/Peter
"Take me to the Brig. I want to see the "real Marines". " Major General Chesty Puller, USMC
PostPosted: Sun Sep 20, 2009 1:20 pm
You have the same problem with the gorgon and landtrain
I am not available for that cognition on my part :D
PostPosted: Sun Sep 20, 2009 2:06 pm
In the case of the landtrain (and also hellworm) I spot this in the rulebook.
Hellworm
Carrier Battle car: Transport 10. The Battle car must be open to disembark troops, but the Engine does
not lose any movement when they get off. May fire 4 of its Heavy Bolters when closed, and all 8 if open.
Landtrain
Berserker Battle car: This carries numerous weapons as well as a detachment of Squat Berserkers. They
are a separate unit and must be given their own orders. They may leave the Battle car and lose 5 cm of movement as per leaving a transport, but the Engine does not lose any movement for their getting off.
I agree in the case on the gorgon somewhat but the gorgon can actually charge. So it still gives the infantry a 10 cm push. (still crappy yes) The leviathan only has 10 cm move.
I have never seen a landtrain on charge cause then it cant shoot but I guess that its not used for transporting troops to the fray either.
A solution to this could be that superheavies and pratorians in general do not loose movement if troops disembark. Not sure if this would be good though.
/Peter
PostPosted: Sun Sep 20, 2009 3:32 pm
I upped the Gorgon to 15cm (at no additional points cost) as anything lower isn't effective for any assault transport no matter how well protected. Otherwise in assaults you will be lucky to get near to the front lines before the game is called due to time.
For the Land Train, I toyed with the idea of when it gets to a certain size, say above 4 carriages then it becomes a Praetorian for orders, point defence, movement etc but has no damage table. (Just like the Dominatrix it has a save, depending on what part is targeted... although I have made a damage table for my Dominatrix but that's another issue). When the engine gets destroyed or when there are only four carriages or less it reverts back to being a superheavy unit. Surely an increase in size is what dictates the size class. Just saying.
I think the Iron Breaker Leviathan should get some sort of sensor boost that it shares with the other Praetorians in the Company. Something to allow them to use it's LOS for artillery targeting or something. Like a Data-Link or Network. The guard have fitted a command suit so it makes sense. Oh, goody. Another crazy idea.
PostPosted: Sun Sep 20, 2009 4:33 pm
I like this. :)
I have used the train a few times but I have very few times actually seen it being destroyed. Not sure I like this idea. Giving it an extra power for the same cost. I mean its still a great unit.
Not sure what you mean here. There is only one praetorian in the company card. There could be more praetorians though from other cards. The idea of spotting for each other sounds fair enough. Maybe like a forward observer cutting scattering to half. To me this ability sounds quite likely in all vehicles that are praetorian & titan. I mean there must be dozens of crewmen there, cant anyone of them wear a radio like a forward observer. They should have advanced equipment in there. But on the other hand, I cant really say that anything about it is broken now sooo. If it aint broken - Dont fix it.
/P
PostPosted: Sun Sep 20, 2009 8:41 pm
Whoops, it's been a while since playing Squats. I forgot the Iron Breaker is the Infantry/Praetorian combo. I was meaning the Leviathan and Cyclops company, please disregard.
The Landtrain is easy meat when hit by Gutbusters or similar. It's just a superheavy with some shields. I always find it to be unwieldy and hard to get into range without being picked on.
