New units for NetEpic
 Post subject: New units for NetEpic
PostPosted: Sun Feb 22, 2009 1:57 pm
I present you others creations but they are in french. I will translate them later.
Node Tau
Land Raider Terminus Ultra
Mog
PostPosted: Sun Feb 22, 2009 2:09 pm
Wow, you really make them look professional. The models and cards look immense. I like the Tau Node stats but it's one of the armies I don't have yet so have no real knowledge of their stats or need for a ground based gun platform.
The Land Raider Terminus Ultra seems to be more like a Superheavy Tank than an MBT. If that's the intention then I would try them as they are just now but if they prove not as tough as the IG Superheavy Tanks I would consider a 1+ save and a damage table since they are 200 points each and a special card too. I will have to wait for the translation, I did try but... *shrug?* to know just how the laser system works.
My head is full of War...
PostPosted: Mon Feb 23, 2009 1:17 am
My French is unfortunately non-existant.  The Tau Node probably needs to be more expensive or possibly Unique or otherwise restricted (the similar and evil Ork Soopagun is a Mekboy unit for example).
The Terminus Ultra looks cool.  Points look ok, or perhaps slightly too high.  I'd probably suggest 550 and then playtest them to see how they go.
Any chance you could put them somewhere else too...local ISPs think Snapdrive is a den of evil file sharers and I need to do "interesting things" to see the files.
Fire bad, tree pretty - Buffy
PostPosted: Mon Feb 23, 2009 1:43 am
I don't understand everything but I should not use Snap drive ?  :sigh:
In this case; i translate. :smile:
Land Raider Terminus Ultra (special card : 600Pts only for SM)
effective : 3 LR Terminus
Mvt : 20 cm
Svg : 2+
CAF : +2
Weapons/Range/Attack dice/to-hit/TSM
Twin-linked Lasgun/75 cm/3/4+/-2
Lasgun/75 cm/2/4+/-1
Notes : PD(1), Overload
Overload : Roll dices separately for each vehicle, if you get at least four 1 as results, the internal systems of the tank suffer overload.
The Terminus Ultra is hit automaticaly with a TSM -3, resolved after his firing have been completed.
See you later for Tau Node.
PostPosted: Mon Feb 23, 2009 1:44 am
sorry...just edited while you were posting :)
Perhaps, "roll a D6 for each lascannon fired.  If you get 4 or more 1 results, the Terminus Ultra overloads and...."
