need feed back on a new mini
 Post subject: need feed back on a new mini
PostPosted: Sat Dec 20, 2008 5:12 pm
hi i am on holiday and is again in the rule creator mode what i am working on is a seige recker and i need some ideas for stats and ordinary feed back
Fire Drake
the sl-245 fire bug has been in the imperial engineering core from the great crusade its a STC design for a pile driver that uterlise a magnetic rail system to the drive piles in the ground under the 2465 day scitari siege og argorwat in the end days of the herosy where the 35 meter thick adamatium walls around the citadel of argorwat made a stalvemaite that had no prospekt of a solution in the next 2000 years the scitari commander in his desparation loaded a adematiom pile in a fire buge and didn’t rise the drive tower but placed it against the wall cranked the drive system up to full power and lanched the pile int the wall with a spectacular result the pile smashet a 8 meter with hole in the wall continiud  860 meters in to the citadel and effective broke the siege thus the sl-245a fire drake was born.
the fire bug is a rather specialist pice of equipment and is realy used by combat formations but it is sometime found among engeniring heavy formations like the death korp or some scitari formations the commander there is lucky enough to have a fire bug in his maintanens pool and find him self in a seige is a happy commander it is simpel prosidier to convert a fire bug to a fire drake
ps sorry a am still dyslectic
sun tsu the art of war
PostPosted: Sun Dec 21, 2008 7:32 am
Make it a vehicle with crap stats (15cm move, 0 CAF, 0 Armour).  1 barrage, 3cm range (so the template just clears the vehicle), 2BP, -6TSM.  Destroys Buildings.
Fire bad, tree pretty - Buffy
PostPosted: Sun Dec 21, 2008 2:38 pm
thanks for the input big help
Users browsing this forum: No registered users and 77 guests
