HQ:s shooting at a charging unit.
 Post subject: HQ:s shooting at a charging unit.
PostPosted: Fri May 09, 2008 8:50 am
The rules say:
2) Firing at a charging unit: If an enemy charges straight at you, you have time to get off one last, desperate shot. If a unit is on First Fire Orders and is the target of a charge, it may be activated to Snap Fire at the charging unit without the normal ?1 To-Hit penalty.
If a HQ has moved and is later charged. Can he then fire at the unit that charged him as snapfire or FF. Or does it mean that a moved HQ can not fire if he is charged if he previously moved?
Thanks in advance
/Pete
"Take me to the Brig. I want to see the "real Marines". " Major General Chesty Puller, USMC
PostPosted: Sat May 10, 2008 3:52 am
Well, if it was a HQ unit then it couldn't have First Fire if it moved so no.
If you meant Command, then yes if you play the standard version of Command, and it depends on how far it moved if you play the optional version.
Fire bad, tree pretty - Buffy
PostPosted: Sat May 10, 2008 7:34 am
This is funny. Me and my friends have allways played HQ:s as being able to charge and then fire in the FF segment. (perhaps a very old rule)
This forum is G-reat.
What is your adress Zap if I wanna send you some flowers? (or stalk you)  :p
/Pete
PostPosted: Sun May 11, 2008 10:45 pm
Sorry Pettan, Orc nobs are HQ AND Command units...
PostPosted: Mon May 12, 2008 1:52 am
Hehe....yes, I learn stuff here all the time too :)
PostPosted: Mon May 12, 2008 5:13 am
Yep Johan. I realized that yesterday evening.. ;)
Not a techmarine though.. I guess we have to check for each HQ if they are Command or not..
/Pete
