Hellworm Engine...
 Post subject: Hellworm Engine...
PostPosted: Fri Dec 28, 2007 8:42 pm
can someone tell me which model can use for the hellworm engine and the belonging battle cars?
i am sure there are no official models existing, right?
PostPosted: Fri Dec 28, 2007 9:57 pm
Correct, there are no official minis for them.
PostPosted: Sat Dec 29, 2007 2:52 am
I've started on mine, but I need to buy in silicon and resin supplies to finish them.  I used the front of a well known medium sized tunneler mated to some plastic tube and detailed with Green Stuff as the engine, and same diameter tube to make the cars.  I'll post pics when I'm ready to start painting.
You could probably use the Khazari Mining machine tunneler as a good proxy for the engine and make cars out of suitable diameter tubing.
Fire bad, tree pretty - Buffy
PostPosted: Sun Dec 30, 2007 9:58 am
(zap123 @ Dec. 29 2007,01:52)
I've started on mine, but I need to buy in silicon and resin supplies to finish them. ?I used the front of a well known medium sized tunneler mated to some plastic tube and detailed with Green Stuff as the engine, and same diameter tube to make the cars. ?I'll post pics when I'm ready to start painting.
and which model to use for the Observation Balloon?
PostPosted: Sun Dec 30, 2007 11:53 am
The Man O'War Dwarf War Balloons.
PostPosted: Sun Dec 30, 2007 6:47 pm
(zap123 @ Dec. 30 2007,10:53)
a real matched model...i will tell our squat player, thanks
 Post subject: Re: Hellworm Engine...
PostPosted: Wed Apr 20, 2011 11:22 am
I'm keen on the Khazari getting a tunneling mining machine that will probably help you chaps out. It'll be soon after the Edenite Harvester.
http://urbanleadjunkie.blogspot.com/201 ... ourne.html
Tom Webb
PostPosted: Wed Apr 20, 2011 2:17 pm
Actually, the plastic 40K Ork Killer Kans has an awsome drill hand that is perfect for Epic. Unfortunately you only get one per box :(
If you are going to do a tunneler, can it be either a) like the Termite coming up out of the ground, only Mole sized or failing that b) a hollow (2 piece I'd imagine) tube with a seperate drill head? That would help immensely.
Oh, and outstanding necroposting :D
PostPosted: Wed Apr 20, 2011 2:24 pm
i like the dark age "drillhead" model for this
quite looking forward to seeing what SCP comes up with though
PostPosted: Wed Apr 20, 2011 2:51 pm
It took me three years to make a decision!
We already have the mining drill as a component. That might be a good match for you?
Tom Webb
PostPosted: Wed Apr 20, 2011 3:37 pm
My suggestions(cause I fell in love with the hellworm stats)
front and back(secondary engine) halved Mole or for rich people halved Hellbore tuneller
cars: as Zap mentioned tubes of the same diameter nicely decorated
conected with magnets
PostPosted: Wed Apr 20, 2011 10:26 pm
Skaard drillhead next to a Baccus worm range large tunneler
PostPosted: Wed Apr 20, 2011 11:38 pm
put them next to something Epic please.
PostPosted: Thu Apr 21, 2011 12:29 am
Rhino included. The Baccus worm tunneler is assembled in segments. You can vary its length by using less segments. See picture of one i have broken in half fyi. I dont know if they still sell it. The head is ugly or comical at least but could be fixed by a good paint job.
PostPosted: Thu Apr 21, 2011 6:09 am
Wow...big. Doesn't look like it's for sale anymore. Still, replace the head with a proppa drilla and add some weapons and that's one killer Hellworm.
