Post new topic Reply to topic  [ 111 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
Unit Summary Tables on Excel?
 Post subject: Re: Unit Summary Tables on Excel?
PostPosted: Tue Oct 15, 2013 7:20 pm
Yes.
It looks like you solved it.
And I think you are right. It depends on the version of excel that I am using.
I use excel 2008 for Mac, and I have to admit it often gives me some problems.
It looks like the version of excel you are using is able to recognize merged cells, which my version of excel appears unable to. I am guessing the original tables have a lot of merged cells.
I also found that copying the tables from the pdf's takes a long time, before my computer responds and I am able to paste anything in excel, but I just thought that my computer is old and slow.
If you can copy from the army statistics tables in the pdf's to an excel spreadsheet, I would like copies of the resulting excel-files.
Would you be able to post them here on the forum?
Thanks.
PostPosted: Tue Oct 15, 2013 7:27 pm
HAL9000 wrote:
Yes.
Thanks.
Yes you can upload files and make them available as part of your post.
So as not to incur in redundant labor. Which book(s) you tackling?
PostPosted: Wed Oct 16, 2013 2:07 pm
primarch wrote:
This worked for me. I think I can proceed quickly now.
On a separate note does anyone know how to make an army builder in excel or open office. I have seen some nifty things done with it (I have dirtside 2 one thats very nice) and I wondered if anyone had the now how on how to do it.
I have done something in excel using drop down boxes and look up tables. First version just uses the formation data, but I have been thinking about seeing if I can do it with the full stats as well.
NetEpic Space Marine Army List Creator.xls [83 KiB]
Downloaded 508 times
You just select the boxes under the formation heading for each formation you want and it brings up the info. If you don't want anything, then select the bottom option in the list to fill the box as blank.
Titans have to be constructed in the boxes at the bottom. As with the formation selection, it uses to drop down boxes to bring up the various weapon options. Select the "None" option to not put anything in that slot.
Matt
PostPosted: Sat Oct 19, 2013 4:04 pm
Matt
Wow!
This is exactly what I meant!
Once all the excel files are done can you do this for all the army lists?
Awesome. ;D
PostPosted: Sat Oct 19, 2013 5:44 pm
I am sure I can knock them up for the rest.
PostPosted: Sat Oct 19, 2013 7:00 pm
I have completed a straight "copy paste" from the books to separate spreadsheet files.
I will now make them look pretty and update the information where necessary to reflect what has been discussed so far.
Once this is done I will forward them to you so you can make those builder files. :)
PostPosted: Sun Oct 20, 2013 6:59 pm
Finished!
Attached are all the spreadsheet files with updated information and stats (not all of them, but quite a few). I have already include many of the recommendations across the different army discussions.
Also I eliminated all the mentions of "optional". that was done when these were new. That was 10 years ago. So all units are "standard".
You can work you magic now Mattman! ;)
Tyranids.xls [21.5 KiB]
Downloaded 476 times
Tau.xls [32 KiB]
Downloaded 502 times
Squats.xls [34 KiB]
Downloaded 533 times
Space Marine.xls [54.5 KiB]
Downloaded 484 times
Orks.xls [37.5 KiB]
Downloaded 475 times
Imperial Guard.xls [55 KiB]
Downloaded 514 times
Eldar.xls [57 KiB]
Downloaded 489 times
Chaos.xls [61.5 KiB]
Downloaded 505 times
Adeptus Ministorum.xls [33.5 KiB]
Downloaded 493 times
Adeptus Mechanicus.xls [28 KiB]
Downloaded 548 times
PostPosted: Sun Oct 20, 2013 8:50 pm
Excellent work on the Excel tables my friend. Look forward to seeing what Matt does with them.
I'm sure these will prove to be an incredibly valuable resource for the Net Epic community.
PostPosted: Sun Oct 20, 2013 9:18 pm
I'll update these regularly as more changes additions are made.
I think having Mattman's nice army builder excel files will be really useful. I wanted something like that for a long while. :)
PostPosted: Mon Oct 21, 2013 8:26 pm
Perfect. Brilliant work. Thanks a million. This is exactly what I was after.
Thank you so much for putting these together.
With a bit of luck I can start a war off the shoulder of Orion before Christmas. I promise to post photos and a battle report once it happens :)
PostPosted: Mon Oct 21, 2013 8:30 pm
Once Mattman does the army builder files off of these then we'll have the "Full Monty". ;) ;D
PostPosted: Mon Oct 21, 2013 8:41 pm
Great news, it sounds like Xmas will be coming early this year! Can't wait! :)
PostPosted: Mon Oct 21, 2013 10:25 pm
Don't think you want to see me doing the Full Monty :o
PostPosted: Mon Oct 21, 2013 10:54 pm
If that will help getting those files done, yes, yes I would. ;) ;D
PostPosted: Tue Oct 22, 2013 10:41 am
Not sure it would help, would most probably drive players away ;D
