Post new topic Reply to topic  [ 165 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 11  Next
NetEpic Errata
 Post subject: NetEpic Errata
PostPosted: Mon Aug 27, 2007 11:58 pm
Tau :
  • Some units have a save noted "3+f, 2+" instead of the usual "2+/3+f".
    Slann :
  • Titan DragonKing is 25VP / 2000Pts which is surprising. Intended or typo ?
  • some "suarus" instead of "saurus".
  • some "Nemeses" instead of "Nemesis".
  • There are stats for a Warleader, but no army card use it.
  • There are 2 different salamander units, it seems that vehicle version is unused.
    Eldar :
  • Exodite rangers have no stats.
  • There are some already reported confusion about the various Pulse Laser (ToHit, number of hits).
  • Some unit save have an additional (a) (example : Raven interceptor).
  • That Avatar is said to have the Command ability, but do not receive order...
  • Great Harlequin has a ToHit of "4+f".
  • The Dark Eldar Talos isn't used on army cards.
  • Top
    PostPosted: Mon Aug 27, 2007 11:59 pm
    Adeptus Mechanicus :
  • Rhino, Inquisitor and OrdoMalleusInquisitor have stats but are not used.
  • The Tactical platoon is missing (and is used by the Titan Defense Company).
  • The "Tech-Guard Leman Russ Company" VP and cost don't match. Error or intended ?
  • Some "Sqaudron" instead of "Squadron".
  • The Adeptus Mechanicus Team card says "2 Adeptus Mechanics" (a missing 'u').
  • Is the recon Land Speeder subjetc to cohenrecy with the titan ? And if yes, with which range (6 or 25 cm) ?
    Adeptus Ministorum :
  • The Predator Squadron has a Moral of 4 which is surprising.
  • The Predator Annihilator stats are missing.
  • The Purifier unit has both a Template attack and 1 dice to shoot.
  • The "Canoness (Punisher)" has stats but is unused.
    chaos :
  • Rhino have an unusual moral value of 4.
  • Vindicator Squadron cost is missing.
  • Altar of Slaanesh : moral or VP is missing.
  • Cultist Fanatic have "jump pack" and only 10cm (most or all jump pack units have 15cm).
  • Forward Observer, Robot, Off-Board Barrage and Dreadclaw have stats but are not used.
  • Leman russ (sometime called "Leeman Russ") and Rhino gain a bolter compared the the usual versions.
  • Rapier probably have 5cm move only.
  • Sorcerer stats are missing.
  • Top
    PostPosted: Wed Aug 29, 2007 2:05 am
    Great summaries! Get these to zap for cross referencing and final editing.
    Thanks!!
    PostPosted: Thu Aug 30, 2007 1:57 am
    Got 'em :)
    Fire bad, tree pretty - Buffy
    PostPosted: Wed Sep 05, 2007 3:48 pm
    Eldar Army Book:
    Page 33
    Company Card:
    Spirit Host: Wraithguard Detachment and Wraithlord Detachment
    but at Support Cards there is just listed a Wraithguard Host and a Wraithlord Squadron.
    Compareing the "Exarch" with "Revenant Scout Titans" I started to wonder if the points cost are right here! Exarches are to expensive and Revenants too cheap I suggest.
    Page 34
    Why are the Knights listed here if they obviously are Knights?
    Why is the Phoenix Bomber so expensive? Shouldn?t be there two per Support Card. Esspecially when the Flyer Rules are to be changed!
    Why are there no other Super Heavy Squadrons? Compared with the Imperials there should be. May be it?s a good idea to create an extra Company Card  "Engines of Vaul" too.
    Page 27 Psychic Lance: there is a T-Hit roll, which should be a To-Hit roll
    PostPosted: Mon Sep 10, 2007 5:25 pm
    12B : Smurf
    p5 : "commend"
    p6 : Do Smurfartillery combine Barrage or not ?
    12C : Alpha Complex
    p8: VP of Costs xx50 are rounded below (ex : Cost 350 -> 3VP)
    12E : Exodites
    p8 : Towering Destroyer Host cost/VP
    Phoenix Bomber stats missing
    PostPosted: Thu Nov 20, 2008 11:51 pm
    Ork Army Book
    page 9-10
    madboyz
    If you roll a 4 on the madboy table, the effect is that the boyz play dead, and can't be attacked by the enemy. Problem: a new roll on the chart is only required if they suffer any more losses. As they can't be attacked, that will never occur.
    page 14+43
    pulsa rokkits
    The Pulsa Rokkit description says that buildings receive hits if under the template, but in the unit summary in the back of the document it isn't stated that the rokkit damages/destroys buildings. although a lot of times such things are just summarized as "special" on the list, maybe add this - and/or use the term in the unit description to prevent irritation
    PostPosted: Fri Dec 12, 2008 6:12 pm
    morning,
    there seems to be something wrong with the orc flyers in orc codex ver5D:
    Bomma and Fighta Bomma:
    The unit description states the kustom cannons of the flyboys have a -2 TSM.
    Stats:
    Bomma Range: 75 cm Save: 2+ CAF: +1 Cost: 300
    Rokkits       25 cm   2-10 BP   Varies   -1
    Kustom Shoota 25 cm   2-10      5+       -1
    Big Shootas   25 cm   4         5+       -1
    Fighta-Bomma Range: 100 cm Save: 3+ CAF: +3 Cost: 200
    Rokkits       25 cm   2-10 BP   Varies   -2
    Kustom Shoota 25 cm   2-10      5+       0
    cheers
    sanjuro
    PostPosted: Thu Mar 26, 2009 12:49 am
    Hello again,
    I'm trying to keep the army cards up to date, which makes me read carefully the various army book.
    Some remarks :
    Choose between "Flyer" and "Flier", and stay coherent.
    04A : Adeptus Titanicus
    Ordo-Malleus Inquisitor description missing (what does "Special" mean in stats section ?)
    P13 : Vulcan and Volcano inverted (regarding alphabetical order, which seems to be used)
    p31/32 :
    Ordo-Malleus Inquisitor missing some notes (Command, Elite, ...) ?
    Assault HQ : "Jump" instead of "Jump Pack"
    Baron/Lancer : "Power Lance" should have a CC range instead of 15cm.
    Missing Terminator stats for Corvus Assault Head/Pod
    Missing stats for Psy-Titan
    04C : Adeptus Militaris
    Do Forward Observer really have +2 CAF ?
    Warlord stats instead of Revear
    04D : Adeptus Ministorum
    Sisters Repentia break value ?
    Arbites can't be both Special and Support card...
    Which Arbites type come in the Arbitrator Detachment ?
    Exorcist Company VP/cost (6 / 450) ?
    Justifier Squadron VP/cost (4 / 300) ?
    Exorcist Squadron VP/cost (3 / 150) ?
    Predator Cleanser Squadron VP/cost (3 / 200) ?
    Useless Adeptus Mechanicus stats
    Ordo-Malleus Inquisitor miss the Elite & Command abilities
    05 : Chaos
    Missing Leviathan and Warlord stats
    07 : Eldar
    "Vampire" instead of "Vampyre" ?
    "Dracon, Incubi stand, & Command Raider" (too much comma)
    "Helions Cadre", every other cadre is singular written
    "Archite, Wyches stand, Combat Barge" : last "Wyches" instead of "Wych"
    Eldar knights say "Squadron" instead of "Squad" ? I used "Squadron" everywhere.
    Some surprising plural in Exodites cards ("6 Warriors stands", anywhere else it would be "6 Warrior stands")
    "3 pentasaur" without plural ;-)
    There is no "Scatter Laser" card, but the unit exists
    Hæmonculus use which template ?
    War Walker Squadron costs 200 for Eldar Knights instead of 150 for other armies. Intended ?
    Bright Lance Travois alone in detachment looks like a mistake. Maybe the Starcannon Travois was concerned.
    Carnausor as support card : typo or intended change ?
    Dragoon has an "Exodite Shock Lance" instead of a "Laser Lance"
    08 : Squat
    Mortar Battlecar : 6BP 6+ ??
    Observation Balloon is really flyer and not floater ?
    14 : Chaos Squat
    Road Raider Raider Company VP/cost 3/400 ?
    Tanker stats missing
    15 : Necron W40K by Kotrin
    Wraith with 30cm movement ??
    PostPosted: Thu Mar 26, 2009 7:00 am
    Quote: (Ulmo @ 25 Mar. 2009, 23:49 )
    Hello again,
    Some remarks :
    p31/32 :
    05 : Chaos
    07 : Eldar
    08 : Squat
    14 : Chaos Squat
    - Flyer is used consistently.  Has been corrected in edited books.
    04A - Ordo description added and "Jump Pack" fixed.
    04C - Do Forward Observer really have +2 CAF ? - Apparently they do.
    04D -
    Sisters Repentia break value ? Read the description.
    Arbites can't be both Special and Support card...:Sure they can
    Which Arbites type come in the Arbitrator Detachment ? Fixed
    Exorcist Company VP/cost (6 / 450) ? Cheap but precious.
    Justifier Squadron VP/cost (4 / 300) ? Fixed
    Exorcist Squadron VP/cost (3 / 150) ? Fixed
    Predator Cleanser Squadron VP/cost (3 / 200) ? Fixed
    Useless Adeptus Mechanicus stats - Gone
    Ordo-Malleus Inquisitor miss the Elite & Command abilities - Fixed
    07 -
    There is no "Scatter Laser" card, but the unit exists - Not anymore
    Hæmonculus use which template ? Fixed
    War Walker Squadron costs 200 for Eldar Knights instead of 150 for other armies. Intended ? Fixed...no one would ever buy them at 200....no one buys them at 150  :vD
    Bright Lance Travois alone in detachment looks like a mistake. Maybe the Starcannon Travois was concerned.:  No mistake.  Cheap unit.
    Carnausor as support card : typo or intended change ?: Deliberate I think...will check.
    Dragoon has an "Exodite Shock Lance" instead of a "Laser Lance" - Fixed
    08 : Squat
    Mortar Battlecar : 6BP 6+ ?? - Currently says -3....is this a problem?
    Observation Balloon is really flyer and not floater ? - Floater, fixed
    14 : Chaos Squat
    Road Raider Raider Company VP/cost 3/400 ? - Fixed
    Tanker stats missing - Fixed
    Thanks for the effort.  There are some nice catches!
    PostPosted: Thu Mar 26, 2009 9:24 am
    Humm, you're quick !
    Fine !
    Sisters Repentia break value ? Read the description. OK, sorry...
    Tanker stats missing - Fixed Allright, but I'm also interested in what you choosed, in order to keep the army cards up to date.
    Bright Lance Travois alone in detachment looks like a mistake. Maybe the Starcannon Travois was concerned.:  No mistake.  Cheap unit. I still find this surprising. AA units usually work alone, but plain shooting unit don't. Moreover, the limitation of 5 support cards make them rare.
    And at 125 for 3, they were was cheaper in previous version ;)
    Carnausor as support card : typo or intended change ?: Deliberate I think...will check. Please let me informed if it has to be updated.
    Mortar Battlecar : 6BP 6+ ?? - Currently says -3....is this a problem? I was not clear : 6BP should be 4+. Or something else but consistent.
    PostPosted: Thu Mar 26, 2009 11:30 am
    04C Adeptus Militaris:
    Maurauder destroyer stats:
    50cm 2/45+/-2
    50cm 4/+/-1
    should be:
    50cm 2/4+/-2
    50cm 4/5+/-1
    Fair players live longer
    Epic40k.fr Techpriest
    PostPosted: Thu Mar 26, 2009 6:28 pm
    Eldar:
    Probably allready fixed, but the newest eldar list I have (v5)
    page 27 the titan pulselaser hits on 3+ but in the weapon summary (p28) it hits on 2+
    PostPosted: Fri Mar 27, 2009 5:03 am
    Pulslaser fixed way back.  Grab 5.2 from the wikiwikiwar site here.
    Marauder Destroyer:  Nice catch, fixed.
    @Ulmo - I'll try and update all the lists in the Wiki as soon as I can.  Off the top of my head:
    Which Arbites type come in the Arbitrator Detachment ? Fixed - Riot
    Exorcist Company VP/cost (6 / 450) ? Cheap but precious. - left as is
    Justifier Squadron VP/cost (4 / 300) ? Fixed - 3/300
    Exorcist Squadron VP/cost (3 / 150) ? Fixed - 2/150
    Predator Cleanser Squadron VP/cost (3 / 200) ? Fixed - 2/200
    Road Raider Raider Company VP/cost 3/400 ? - Fixed - 4/400
    Hæmonculus use which template ? Fixed - Large Teardrop
    Tanker stats missing - Fixed - Tanker 25cm 1+/3+f +2 None
    And fixed the Mortar battlecar - Thanks again!
    PostPosted: Fri Mar 27, 2009 10:25 am
    In fact, the description says :
    "However, if the Sisters Repentia unit remains unbroken by the end phase of the forth game turn, the opponent is granted the full victory points for the unit."
    But I didn't find the Break value (But I imagine the usual 3 break for 6 stands).
    Users browsing this forum: No registered users and 81 guests
