Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Barrage Weapons and Titans
 Post subject: Re: Barrage Weapons and Titans
PostPosted: Tue Oct 22, 2013 1:06 am
The Bissler wrote:
Or maybe just not offer the D3 hits at all to flamer template weapons?
Just to titans, they don't affect the actual building structure.
PostPosted: Tue Oct 22, 2013 1:14 am
primarch wrote:
ForgottenLore wrote:
How do we determine which of the adjacent boxes get hit? Attackers choice? defenders choice? roll the targeting dice? Roll a single targeting die (which one)?
I'm willing to leave it up to "attackers choice" after the initial scatter. For those more randomly inclined roll a d6 and let luck decide.
Another vote for "attacker's choice."
Another change I'd like to see for barrage weapons in general is a game mechanic utilized in E:A which speeds up play. Instead of rolling to hit each unit separately, in E:A you count up the number if units and roll that many dice all at once. If you have a mixed formation, say Marines and Rhinos, you roll for all the Marines together and then all the Rhinos together.
PostPosted: Tue Oct 22, 2013 1:19 am
I've been doing that for years. ;)
PostPosted: Tue Oct 22, 2013 1:20 am
In that case in the future I'll do the exact same thing! It really does speed up play.
PostPosted: Tue Oct 22, 2013 1:22 am
I'll be thinking of this kind of thing when I rewrite it though. It time to get rid of these things which no longer reflect how the game is played.
PostPosted: Tue Oct 22, 2013 1:44 am
It does indeed sir! Like Primarch, I've been grouping dice for a long time now.
I always start every battle with 30 dice in hand (not literally, they're on the table) - there are three different colours, meaning there are 10 of each colour. Before I roll dice, I declare which dice represent which units/weapons; i.e. "6 red dice are for Land Raider Lascannon and require 5 or more for a hit, 3 purple dice are Point Defence and require 6 to hit".
Alternatively, if I have a unit splitting their fire across several different enemies, I'll use the colours to distinguish the targets; i.e. "Devastators fire their rocket launchers. 3 red dice at the Warlock Titan need 6's to hit because of witch sight, while 2 purple dice and a green dice will target 2 Wraithguard and that Guardian stand respectively - rolls of 5 or more required to hit with those..."
And so on! Once you start rolling dice this way, you never look back! :)
PostPosted: Tue Oct 22, 2013 1:54 am
Yup. I have hundreds of dice and just using different colors speeds up things. I haven't rolled on at a time in who knows how long.
PostPosted: Tue Oct 22, 2013 9:00 am
I think Flamer weapons should be included, whatever weird and wonderful flammable concoctions they use in the future I would expect to burn fiercely enough to potentially damage structures or at least set fire to the crap that is in the building which could eventually lead to it burning down.
Matt
PostPosted: Tue Oct 22, 2013 4:18 pm
Matt
As I wrote the response, I thought of this.
I would not be opposed. I think it is balanced by the fact that template weapons are such short ranged.
Do we want to add this to flame templates?
Thoughts?
PostPosted: Tue Oct 22, 2013 4:33 pm
I'm wary only because I saw how powerful a plasma driven Titan with Inferno Guns can be...
If the Net Epic community wills it, I will not actively oppose this. :-X
PostPosted: Tue Oct 22, 2013 4:35 pm
It sounds like this is the point where much playtesting is needed.
Thanks,
Troy
PostPosted: Tue Oct 22, 2013 5:15 pm
How did the plasma effect the inferno guns? They don't have any TSM.
The odds of being able to down a standard building (4+ save) with a flamer based weapon using the D3 hits rule comes in at about 16%, is that to high? And then you have the Structural Integrity checks at the end of the turn (though you will have torched most of the men inside anyway). Of course those flame template weapons with high saves (like the Nid Acid Spray) will have a pretty good chance at downing the building.
I don't know, I guess like FL says, might need to try it out and see how it plays.
Matt
PostPosted: Tue Oct 22, 2013 5:23 pm
The plasma rules allowed a Warhound to charge 50cm and first fire an inferno gun into a forest with an Ork mob. The D3 hits wouldn't have made much difference to that scenario, just that I'm incredibly wary of the power of inferno guns now...
PostPosted: Tue Oct 22, 2013 5:34 pm
Remember that net epic evolution is different from standard. I think it is far less of an issue in standard.
PostPosted: Tue Oct 22, 2013 5:37 pm
I think you need to specify what alternate rules you use. ;)
Bissler's talking about the effects under the combined activation system called net epic evolution.
His points don't carry over to net epic standard.
Whatever issues that rule set may have with changes Bissler and I will take care of. ;D
