Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4  Next
Some Tau suggestions to the eldar reverants one
 Post subject: Re: Some Tau suggestions to the eldar reverants one
PostPosted: Tue Aug 10, 2010 11:57 am
Sorry, completely missed the fact that you dont use the weapons costing rules for titans. Wow.....that's a different way to do it. I assume everyone plays Titan Legions armies then.
However, pretty sure that's not the norm so dont use it as the basis of a comparison :-)
We always used Titan Legions as a part of an Imperial army
so most of the time it was a mix of warlords, Imperial guards units,
space marines and knights
It is pretty common for me to face such an force
if playing against my most played opponent :D
Yes you are right :D
we always upgraded the SM/TL rules with the NETEPIC rules
I am trying to adapt the way we play to the NETEPIC rules
but it will tkae its time
for the HHs and TRDC write out detachment size/cost and stats in the usual format + any special rules and I'll take a close look.
HH RailG. 20cm/+3/+2/35cm/2/+4/0 (BurstC.)
HH IonC. 20cm/+3/+2/50cm/1/+4/0 (missile Pods)
HH Missile Pods 20cm/+3/+2/50cm/1/+4/0 (missile Pods)
HH TL FusionB. 20cm/+3/+2/50cm/1/+4/0(missile Pods)
all units: size 2/morale+3/break point 1 costs 150 poins
HH TL PlasmaC. 20cm/+3/+2/50cm/2/+3/-2
HH TL BurstC. 20cm/+3/+2/50cm/4/+4/-1
Remora Drone Carrier
Carrier+4 Drones 300 points
brake point : carrier
Drone carrier: 60cm/+3/+1/
/35cm/2/+4/0(BurstC.)
/75cm/1/+4/-1 AA-seeker missile
Drones:120cm/+5(+6fixed)/+2/
/50cm/1/+4/-1 AA-seeker missile
special: drones
Notes: 2 drones operating
1 protecting TSDC
1 reserve
The drones will intercept any incoming fighters while on escort mission
or try to block incoming shots on +4
or shoot at the closest enemy fighter during advanced
The drone which is protecting the TSDC is always on a escort mission
hope thats all
best regards
ule
PostPosted: Mon Sep 13, 2010 9:07 am
Yes.  The Deflector Shields.  I've never really been happy with them.  I am very tempted to scrap the whole idea of them and just give any Tau unit that has Deflector currently a fixed save.  In the fluff, Tau shields DO NOT opperate like Ork r Imperial shields.  They don't absorb incoming fire.  They deflect it away from the unit.  As a such I am tempted to simply give Deflector Shielded units a Fixed 2+ or 3+ save to represent the shield and if the shield generators are damaged, they lose the shield save.  No keeping track of how many shields you have.
I have thought long about the deflector shields,
maybe I have found a solution
e.g. 4 shields +3fixed save
If tha manta is hit make an unmodified +3 save
if it fails its save, it looses one shield and the NEXT shield has to make an unmodified +3 save and so on
seems not too powerfull and not too bad
@Zap please look over the Hammerhead and Tigershark stats
if they are still too confused, :-\
I can rewrite them
thanks for looking
Ulric
PostPosted: Mon Sep 13, 2010 11:30 pm
The two new HH variants look fine to me. Not sure why there's a need to change secondaries on existing HHs, but I don't have a huge problem if the Tau players like the change. I would probably suggest not having missile pods as secondaries on the HH with missile racks just to avoid confusion though.
I think I'm ok with the Drone carrier, except that any Drone on escort shouldn't be able to also shoot.
PostPosted: Tue Sep 14, 2010 8:29 am
I meant if the drone has neither intercept incoming flyers nor blocked incoming shoots
it can shoot in advanced
but maybe you are right and its a bit too good
Its not for making any variant much better or worse
just to have the right secondaries on the HH
but not really important for me
If someone is asking:
I choosed a fixed save for the remora drones to represent thier stealth abillity
I figured tha the "hard-to-hit" abillity seems a bit too powerfull
thanks for looking
PostPosted: Thu Sep 23, 2010 6:54 pm
Remora stealth drone upgrade:
Every Tau flyer, floater or support craft can be upgraded with 1 or more Remora stealth drones on "escort mission"
50 points/model
The Remora stealth drone will only escort 1 single model per game
and is removed if the flyer ect. is destroyed
What do you think about it?
cheers
ulric
PostPosted: Fri Sep 24, 2010 12:20 am
As an upgrade to the Orca it might not be too abusive. No to all the other flyers though....or at least not at that cost.
PostPosted: Fri Sep 24, 2010 6:01 am
Maybe upgrade only super heavy Flyers
PostPosted: Fri Sep 24, 2010 6:23 am
Not at 50 points. Price for a Tigershark DC would need to be higher and for the AX-1-0 much higher. A fixed price upgrade doesn't work when the value of the upgrade varies according to the value of the unit it is protecting.
Like I said, having them as protection for an Orca might be conceivable and reasonable as it has no major offensive ability and is really there to deliver troops, though seeing the Orca Deepstrikes anyway, perhaps it's not of great use.
PostPosted: Fri Sep 24, 2010 7:49 pm
Not at 50 points
Hmm 100 points seems too much to me
But you are right 50 sounds cheap
maybe a support card 2 for 150 points
The shield drone upgrade is working exactly like that 100 points for a det. Fire warriors or 100 for a Boardside battlesuit unit
I see them similar as an escort for heavy flyers/floater
probably yes ::)
But the Remora drones are representing tha Tau´s way of fighting and are excellent models 8)
it would be nice to inlude them in the Tau codex or at least in the "optional rule book"
wait I paint some up :D
PostPosted: Sat Sep 25, 2010 5:03 am
You can put pretty much anything you like in the optionals book. A lot of the stuff in there is fairly marginal already....that's why it's there ;)
Sorry, not up on the fluff, but dont the Remoras need a controller anyway?
PostPosted: Sat Sep 25, 2010 7:01 am
Uh ah my arguments are not fluff based.
I do have no clue about the Tau fluff
except the stuff I read in the Tau codex
But the Tau have several drones so the Remora would be a nice addition
Now the Rulebook would be much nicer but you are such a toughie
if we negotiate for Tau stats
PostPosted: Sun Sep 26, 2010 5:39 am
I am pretty sensitive about airpower as it can be awfully unbalancing and the Tau are already very strong there. There is probably still some scope for Tau ground forces though.
PostPosted: Sun Sep 26, 2010 6:52 am
Are you talking about Vektor Knights? ;D
I have recognized that :)
In my next Tau game I will give the Tigershark remora drone carrier a try
maybe against Eldar?
PostPosted: Sun Sep 26, 2010 10:12 am
Some interesting suggestions here. However I'm afraid these will not go into the Tau army book at this point. The Tau book has been finished for some time, and as mentioned elsewhere, due to practical considerations when layouting, changes like new unit additions are not going to be added to the books one they've been layouted. Otherwise you (well, I) would constantly have to be reworking the layouts to make room for new unit additions and that is extremely bothersome tbh :p ;)
However they ARE very nice models, so by all means get those rules written and playtested, and we'll throw it in the optionals book ;)
PostPosted: Sun Sep 26, 2010 10:40 am
I understand that :-\
I will playtest them
since Zap123 agreed with the Hammerhead variants(hope so)
there is only the tigershark remora drone carrier left
I hope we find a solution ASAP
cheers
ulric
Users browsing this forum: No registered users and 111 guests
