Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
netepic gold
 Post subject: netepic gold
PostPosted: Tue May 09, 2006 4:59 pm
Pics should be taken roughly from this angle for infantry:
PostPosted: Tue May 09, 2006 5:06 pm
...And this angle for vehicles.
The images has to be at least 150 dpi and preferably 300 dpi.
I would prefer if the actual miniature in the pic is at least 800 pixels wide.
Don't worry about background and all those sort of things. I'll fix that later on.
The pics should be taken in soft light ie. out of direct sunlight which will cause very dark shadows. Also you should try not to use flash.
Do not start upsizing the pics if they do not match these criteria. While you can easily downsize an image you cannot upscale it without it looking bad in print.
I know it sounds a bit complicated but no worries: most stuff will do just fine. It is just that images from the web cannot be used for printed stuff with good results.  :;):
PostPosted: Wed May 10, 2006 1:17 am
To all whom would like to contribute, the best thing is to contact WMN, since he knows best what he needs, and is in case of the photos, what the specifications are.
By the WMN, you could ask Doug to use some of the DRM pics, since some of his human forces are excellent proxies for some netepic models.
Enderel, contact WMN for any such editing/writing stuff you can contribute.
Thanks all!
PostPosted: Wed May 10, 2006 10:46 am
Which Thudd Gun version do you want?  The old metal one or the plastic Squat type?
I've PM'd Warmaster as well to see if I can help (thanks Primarch).
I am become death the destroyer of worlds.
