Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
Epic War! Campaign Marines v Eldar 20,000 points
 Post subject: Re: Epic War! Campaign Marines v Eldar 20,000 points
PostPosted: Sun Mar 10, 2013 9:46 pm
And updated army lists for the end of turn 2
So at the end of turn 2 it stands at:
Marines: 75 VPs
Eldar: 111 VPs
It may seem strange that so many points are on the board already (bear in mind the campaign target is 200 VPs), but it's worth bearing in mind that 4 out of the 7 armies for each side locked horns this turn!
Marine Army Lists End Turn 2.pdf [211.28 KiB]
Downloaded 412 times
Eldar Army Lists End Turn 2.pdf [223.86 KiB]
Downloaded 407 times
PostPosted: Sun Mar 10, 2013 10:03 pm
Turn 3 Map & Updated army lists...
Turn 3.pdf [188.11 KiB]
Downloaded 402 times
Marine Army Lists End Turn 3.pdf [211.32 KiB]
Downloaded 436 times
Eldar Army Lists End Turn 3.pdf [223.89 KiB]
Downloaded 408 times
PostPosted: Mon Mar 11, 2013 10:19 pm
Turn 4...
So it's war in the woods again - and this time I have the right forces to deal with the Eldar miscreants!
Battle report can be found here: viewtopic.php?f=85&t=24796
Note: Post-battle Marine Campaign VPs are currently understated by 9 VPs (see end of battle report for a fuller explanation as to why this is the case).
Turn 4.pdf [189.56 KiB]
Downloaded 444 times
Marine Army Lists End Turn 4.pdf [212.06 KiB]
Downloaded 394 times
Eldar Army Lists End Turn 4.pdf [224.74 KiB]
Downloaded 509 times
PostPosted: Mon Apr 01, 2013 7:50 am
Turn 5:
A battle on hilly terrain for a campaign objective.
Battle Report 6 can be found here;
viewtopic.php?f=85&t=24873&p=471543#p471543
You may want to read that first before viewing the updated Campaign Rosters...
Turn 5.pdf [193.53 KiB]
Downloaded 426 times
Marine Army Lists End Turn 5.pdf [214.93 KiB]
Downloaded 575 times
Eldar Army Lists End Turn 5.pdf [234.13 KiB]
Downloaded 467 times
PostPosted: Mon Apr 01, 2013 7:55 am
Spoiler alert: If you are following the campaign but haven't read battle report 6 yet and don't want to know the state of play, please read no further!
Campaign VP update and note:
Marines: 105 VPs
Eldar: 141 VPs
Marine Campaign VPs have actually reduced since Turn 4. This is because they lost the Campaign Objective and broke next to nothing in Battle 6.
PostPosted: Mon Apr 01, 2013 8:04 am
The vast majority of forces have been tested in battle and both players are aware that the campaign is now coming to closing stages, and neither want to make mistakes (particularly the Marine player who is lagging behind in the VP stakes). This uneasiness is reflected on the campaign map this turn as both players order several of their armies to use the "Fortify" order and start building defences.
Turn 6.pdf [187.76 KiB]
Downloaded 378 times
PostPosted: Mon Apr 01, 2013 8:21 am
Turn 7 is another turn where no battles are instigated. However, this uneasy peace will not last much longer!
Turn 7.pdf [187.8 KiB]
Downloaded 391 times
PostPosted: Sat Apr 13, 2013 11:37 am
And it doesn't! Two city battles are insitgated in Turn 8!
Turn 8.0.pdf [187.16 KiB]
Downloaded 433 times
PostPosted: Sun May 19, 2013 7:39 am
Turn 8 sees battles across two cities!
For anyone who missed them, you can find battle reports 7 & 8
here (7): viewtopic.php?f=85&t=25106
and here (8): viewtopic.php?f=85&t=25145
Spoiler alert: If you are following the campaign but haven't read these battle reports yet, look away now if you don't want to know the results!
Marines: 174 VPs
Eldar: 180 VPs
With the campaign threshold being 200 VPs, the next battle will almost certainly see the campaign end! Which side will be victorious? Or will it end in stalemate?
Turn 8.pdf [187.16 KiB]
Downloaded 417 times
Marine Army Lists End Turn 8.pdf [219.7 KiB]
Downloaded 434 times
Eldar Army Lists End Turn 8.pdf [236.91 KiB]
Downloaded 466 times
PostPosted: Mon May 20, 2013 12:28 am
I hope that the Eldar can hang on to that lead, and take the victory. It's going to be very close though. It has been a really enjoyable campaign, and I'm looking forward to reading the final battle.
PostPosted: Sun May 26, 2013 12:00 pm
Absolutely a senior pro war system that provide the players to create an entire war in Epic space marine system.
A really good work!
Orkonia: http://goo.gl/j6Q3v
PostPosted: Tue Jul 09, 2013 4:23 am
It's high time I brought everyone up to speed...
Despite winning the battle for the campaign objective 2 on E15 during the previous turn, the Marines elected to break down their battered army. This left the objective open for the Eldar's fresh army E8 to move in and take control.
Turn 9.pdf [187.66 KiB]
Downloaded 404 times
PostPosted: Tue Jul 09, 2013 4:26 am
Turn 10: The Marines make a tactical error by advancing upon a nearby city and attempting to capture a campaign objective. Unfortunately for them, the fresh Eldar army made up from reserves is on charge and engages them in battle!
Turn 10.pdf [188.43 KiB]
Downloaded 400 times
PostPosted: Tue Jul 09, 2013 4:27 am
Battle report will follow tomorrow night and bring the campaign to its Epic conclusion!
PostPosted: Wed Jul 10, 2013 11:33 am
Battle Report #9 can be found here; viewtopic.php?f=85&t=25547
***Spoiler alert: If you are following the campaign but haven't read battle report 9 yet and don't want to know how things ended, please read no further!
Ok, for those still with us, here is the final Victory Points tally;
Marines: 189 VPs
Eldar: 209 VPs
Having broken the 200VP target, this means victory to the Eldar army!
A further breakdown of how the VP tally added up for each army;
Marines:
4 campaign objective markers held = 20 VPs
Total VPs for broken enemy units across campaign = 151 VPs
Additional VPs awarded for battle outcomes = 18 VPs
Total = 189 VPs
Eldar:
Total VPs for broken enemy units across campaign = 172 VPs
Additional VPs awarded for battle outcomes = 17 VPs
Total = 209 VPs
And after the dust has settled, here are the final army lists;
Marine Army Lists End Turn 10.pdf [220.75 KiB]
Eldar Army Lists End Turn 10.pdf [239.86 KiB]
Downloaded 418 times
