Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Adeptus Mechanicus book proof reading
 Post subject: Re: Adeptus Mechanicus book proof reading
PostPosted: Sat Apr 24, 2010 3:48 am
Fair point.
WMN, how hard would it be to copy these across from the Core rulebook to the AMTL book?
PostPosted: Sat Apr 24, 2010 10:24 am
That would depend on exactly where you want them :) If you can copy the exact paragraph here and tell me where you want it I'll see what I can do . Adding them to the titan damage tables themselves may prove tricky though, as those are pretty tightly packed already.
PostPosted: Sun Apr 25, 2010 2:59 am
Page 17: Legend that states what the letters stand for and is below the weapon cost chart. I almost didn't see it. Maybe change color and/or font size up to make it noticeable ?
Page 24: "Warhound Scout Titan Template". If the graphic behind cannot be altered easily how about dropping the "Scout" word so that it fits within the graphic behind it ?
PostPosted: Mon Apr 26, 2010 9:44 am
to whom ever did the warhound titan on page 12...
Im going to steal that idea of putting marines on the base, it looks realy good! ^_^
PostPosted: Mon Apr 26, 2010 9:46 am
also if its possible to make the titanweapons fit on 1 page (page 18 + 19) that would help alot too
PostPosted: Mon Apr 26, 2010 2:03 pm
I just realized something about netEPIC gold that...
One of the most "used" features in the new 40k codex:es for me is the Page markings!
Its going to be a pain to do probably BUT it would be very good to have a "Page" column in the Unit summary so you can find the units special rules etc quickly!
PostPosted: Mon Apr 26, 2010 4:20 pm
That would be E&Cs excellently painted Small Walking Robot. O0
Just to addess a couple of your other points:
1) The weapon tables: This annoys me a bit as well. I've tried squeezing this in various ways. Unfortunately I cannot fit it into a single page if there's also to be enough space for the header. Downsizing the font may help a bit, but that would make it inconsistent with the other books. However in the printed book these two tables will be on the same page spread, so it is only if you want to print out the tables seperately it becomes an issue. Having a few units on a second page is less than ideal, but I've yet to find a good way to avoid it :)
2) It is a great idea, but again space is going to be a problem I'm afraid. Those tables are already squeezed a lot to fit everything in there, and again if this was to be done across all books for consistency's sake it would mean quite a bit of extra work. I think one has to assume that a player has a fair grasp of the most common special rules for his army and only need to look up a handfull of special rules during normal gameplay...well unless you're an ork player of course...in which case some page flipping is necessary ;D If someone can come up with an elegant solution that wouldn't require adding a new column to the tables and with minimum effort could be implemented across all books I'm all ears though.
Users browsing this forum: No registered users and 77 guests
