Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
New Set of Questions
 Post subject: New Set of Questions
PostPosted: Mon Dec 21, 2009 6:52 pm
Just rewarming this topic a bit.
TSM:
what is the current state of the added TSM modifiers.
if it would not add up there is no point in the benefit of an automatic hit, since your chance to  score 2 hits is bigger than to miss entirely.
the scatter issue:
it is again not clearly ruled out to derivate. but there is always the question how the "tremor" which comes from a quake would scatter down? even the up scatter is really odd, since some titans/praetorians just dont't have legs which would logically explain this.
yes it is a logical explanation and since we are following the road to just play what is written and nothing more or less, we are bound to our board leaders wisdom to deny or accept our propositions.
Buildings:
Does the imperator titan count as building (X+ Save on 2D6) regarding the tremor cannon and therefore suffer a -6 TSM?
"Imperator Titan Armor Saves: All armor saves are made on 2D6, as buildings. Yes, Imperators are incredibly difficult to damage."
and if not, what about the other hot discussed topic "doom weaver vs. imperator titan". there is nothing written which prohibits the doomweaver from destroying a imperator titan other than the "count as building" thesis.
PostPosted: Tue Dec 29, 2009 11:13 pm
It cans logically scatter down if you consider that if it does, it means that the "quake" is not enough intensive to worry a well builded titan/praetorian/... It cans scatter up if you consider that the vibrations are not enough intensive to worry the legs/Wheels/... of the titan/Praetorian/... but the weaker systems that are just above.
In such a case, the scatter doesn't mean that the quake hit the damaged zone like a laser shot for exemple. But the scatter indicates wich zone is the most affected by vibrations that shake the whole titan.
Biel el'Jonson
