Snap Fire Charging Chaos Daemon
 Post subject: Snap Fire Charging Chaos Daemon
PostPosted: Fri Jun 13, 2008 1:01 am
What, you mean these:
:D
There are 3 types of rider in the Exodite list.  I'll be using these conversions, the actual small GW Exodite rider for the second, and hopefully the EW Bounty Hunter for the third....just waiting on these guys to finish a decent list.
By Pushover, I mean the Exodite list looks pretty weak to me.  They don't have much in the way of really large companies to absorb damage and not a huge amount of firepower.  None of this matters though, it will still be heaps cool to put an exodite army on the table!  It is also good to have a weaker army you can use against newer players so they are in with a hunt.  I think both the Exodites and the Frateris are good candidates for this.
Fire bad, tree pretty - Buffy
PostPosted: Fri Jun 13, 2008 6:31 am
Hey Zap.
Wow!...  :p
So how many times did you need to un-glue your fingers after such fine converting? Nice painting too.
Hard hitting and past moving light units can be a tough nut to crack if you have the wrong type of units facing them. I always include some form of cavalry in my armies (Except PDF.) Now I know what to do with all my extra Slaanesh Beast Riders, Cheers...
I've been trying to find the time to give the site the attention it deserves and spotted an old Trade page of yours. Are tou still looking for an Eldar Phantom Titans Head? If so I have one extra you are welcome to.
My head is full of War...
PostPosted: Sat Jun 14, 2008 1:07 pm
The rank and file riders are actually a fairly simple conversion that only require cutting bits off the original Beast Rider and a few swipes with a file.  If you have a good set of side cutters you can crank 'em out.  Happy to give pointers to anyone who wants to make some.
I am still after a Phantom head and desperate for a Heat lance.
PostPosted: Sat Jun 14, 2008 1:37 pm
Hey Zap,
I'll hold you to that nearer the time. :D  At the minuet Exodites are a far distant point on the horizon. Too much going on.
The Phantom Head is yours and I'll check for Heat Lance but I need to be reminded what it looks like  :blush: I tried using the EpiCollector site but it only shoed Eldar Titans. Probably not using it right.
Anyway, if you can post a picture of it here I'll look for you. I know I have a spare Eldar Power Fist I wanted to mod with an Avatar sword so I may be able to exchange it with one of the other Titans. (Do I need to conduct this conversation on the Trade pages now or something?)  :confuse:
PostPosted: Sun Jun 15, 2008 8:49 am
Hi Guys, I had a brain fart while painting and have been gnawing at this one since it was answered. (I know I had missed something out!) :glare:
The old rules stated that units engaged in close combat by Chaos Daemons could not fire in the First Fire phase as they were frozen in horror at being attacked by something so frightening.
Now units on First Fire can Snap Fire at units charging them in the Movement phase as long as they haven't moved (HQ's etc.)
So what happens if the unit charging is a Chaos Daemon?
1) Does the defender fail to Snap Fire as it's being charged by a Chaos Warp Horror (Fluff) just like before...
Or
2) Does the unit get to Snap Fire even though its being attacked by a Chaos Daemon.
It's number one, you can't snap fire.
Snap fire is an extension of first fire, not its own separate order, so there is no real contradiction. Even though it occurs in the movement phase.
Ok, so that applies to the unit being charged by the Daemon but what about nearby units who are not being charged by the Daemon... rules state...
Snap Fire (NetEpic v4.1)
Snap Fire is a special attack utilized to interdict enemy movement.  Since Snap Fire involves tracking moving targets and is less efficient than normal fire.
1. Snap Fire may only be performed by units on First Fire orders.
2. Snap Fire may interrupt an opponent?s unit movement at any point during the unit?s movement. Players are not allowed to Snap Fire at stationary targets.
3. Snap Fire imposes a -1 penalty to hit. Units classed as AA do not incur this penalty.
4. You may not interrupt another player?s Snap Fire (since these troops are stationary you can not fire at them in the first place).
5. Units cannot Snap Fire and make a pop-up attack. The unit must already have LOS in order to make use of Snap Fire.
6. Command units that Snap Fire are not allowed to move during the same turn, nor are Command units allowed to snap fire after they have moved.
7. Artillery units may not Snap Fire. This also extends to Titan/Praetorian weapons that are armed with barrage/artillery weapons (other non-artillery/barrage weapons on a Titan/Praetorian may Snap Fire).
(I can't download v5 from The Nexus and my printed copy is around somewhere but not to hand. :( )
However from the above information you could in an indirect manner get around the Daemon Snap Fire Rule by Snap Firing with a nearby unit not being directly engaged. This for me puts the whole ordinary units being able to Snap Fire rule in the bin. AA units and units described as able to Snap Fire (Tarantulas etc) can still do this but normal units can not. Unless I have missed something out of course...  :(
PostPosted: Mon Jun 16, 2008 7:26 am
You are correct, so separate units other than that being charged could fire on the GD.
Way back in the day I too was a little concerned about the re-introduction of Snap fire, but practical experience has shown that most people use it quite sparingly.  Sure, you can go on a wholesale Snap Firing exercise in the movement phase ensuring all your units get to shoot, but the -1 penalty to hit is quite huge so you are in effect denying yourself a lot of hits.  In this case all those units you Snap at the Daemon with have a harder time to hit, it'll probably save anyway and even if it fails it just chucks a card.  All those shots probably would have fired on the GD anyway, just without the -1 to hit....so you would have stripped out a lot more cards.  Around here you generally only see someone use Snap Fire to a) shoot down an aircraft, b) stop fast units flanking you, and c) to protect really high value units against fast basers.
The mechanic is pretty useful from a realism perspective too.  We make sure we trace paths offering the most cover when we move, rather then just taking the shortest path.
[edit] oh yeah, lots of snap fire at Skimmers doing pop-ups too.  If you take away Snap Fire the skimmers become invulnerable.....
PostPosted: Mon Jun 16, 2008 8:08 am
Snap Firing Skimmers has always been the way from when I started playing so it's kind of ingrained now. This rule has worked independently before this new Snap Fire rule upgrade was introduced so I wouldn't dream of changing it. (honest)
...In this case all those units you Snap at the Daemon with have a harder time to hit,
I know what you're saying but not sure if I would be able to stop myself from expending First Fire units shots to save the target of a Daemon Charge. If that was to happen against John (Chaos Player) I think we would have an... argument which the potential to spoil the whole day. (Scottish tempers run hot, all that red hair.)  :laugh:
This has merit. Good point. But as many of the games I play are against Chaos I can't see how I can use it without annoying a player. (Very bad mojo.)
PostPosted: Tue Jun 17, 2008 4:46 am
I guess the best thing to do would be to talk it through before the game.  If your friend feels strongly that other units shouldn't be able to Snap-fire against a charging GD I figure that house rule is worth it if you get to keep an opponent :) .  Perhaps introduce it like that and once you see the rule used in play I'd think he'd come around.
Strange, I thought the "Skimmers drop back down immediately" rule got introduced at the same time as the reintroduction of the Snap Fire rule.  Interesting.
I usually don't use the close combat oriented GDs much as they rarely pay for themselves for me, but if I did manage to get a charge in against a high value target I'd be happy for my opponent to blow a bunch of Snap Fire on him....I can always keep him around if it's worth it, and it probably means the GD will actually get hit less.
PostPosted: Tue Jun 17, 2008 7:15 am
Ah, the reasonable approach to gaming...
unfortunately 'reasonable' is an alien concept known only to some and a far distant speck on the horizon to others. They know that it exists but can't fathom why. They see it as a sign of weakness that invites attack. (This could be true as I find a swift boot in the nads can do wonders for making most people more reasonable. :laugh: )
That's funny 'cause I'm sure on SM2 units on First Fire got to shoot back. This was later changed in NetEpic v4.1 to accommodate the unit activation rule so only an enemy unit on First Fire activated immediately after an enemy Pop-Up attack could return fire.
I will check this later but that is as I understood it to be. Has it changed again!?!
I know I would be blazing away at a disadvantage and this most probably would be a tactical blunder but they are scary monsters. I usually find I'm forced to play 'hunt the Greater Daemons' while they hide behind stuff until ones close enough to charge in. Greater Daemons are all bad news but The Shopping Trolley of Khorne (LOB) is a pain in the southern regions and no mistake.
PostPosted: Tue Jun 17, 2008 8:00 am
Never heard it called the Shopping Trolley of Khorne...nice....must use that one.  I usually run mine with 2 ranged weapons...I figure Khorne has enough CC experts so I might as well make use of some firepower.
The old "charge 'em with a GD then hit them with Reward cards to force another morale check when they break" trick never gets old, but I usually play Tzeentch or Slaanesh these days and they just aren't in the same class as Angron or a 'Thirster.
PostPosted: Tue Jun 17, 2008 9:41 am
I usually get my head and extremities handed back to me when John breaks out the Tzeentch Horde, he's lethal. I prefer Slaanesh, just can't buy enough Subjugators or Knights...  :p Soo good... must spend all my money... sorry where was I?
Khorne ranged attacks?! Are you sure?.. It'll never catch on you know. Isn't that what the other slaves are for?
Ah yes the Shopping Trolley of Khorne has been the cause of some slight amusement. closely followed by the Roller Skates of Khorne (Daemon Engines) and don't even get me started on Nurgle or the Chaos Reward Cards...
PostPosted: Tue Jun 17, 2008 2:46 pm
You should like the v5.2 Slaanesh list then :).  I love the House Devine knight companies too.
PostPosted: Tue Jun 17, 2008 3:23 pm
Wah? They do that now? Where can I down load this!.. (I do not have broadband... more kind of rubberband)
PostPosted: Wed Jun 18, 2008 2:16 am
It and all the updated V5 lists are on the NetEpic Yahoo group.  I can email it direct if you like.
