Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
Cards for NetEPIC V5
 Post subject: Cards for NetEPIC V5
PostPosted: Fri Aug 03, 2007 9:52 pm
Hi Ulmo,
Sorry I was a bit later then I said, for checking the Space Marine cards. It also took a lot longer than I thought, especially since the fronts and backs are so far apart, and you included all the non-standard stuff that I didn't know much about.  I don't think I'll check any others in the same detail.  Having said all that, my appreciation for the work you've managed on this is much much higher- seriously great work here!  :D
I downloaded the file on Wednesday (just in-case you changed anything since then).
Anyway.. errors first:
Morale is missing an 'e' on all cards
p4   2 warhounds should be 250 points
p5   Veteran Assualt Company only lists 1 detachment- should be 3
p6   Iron Hands Iron Father 150 points
p6   Ashigaru detachment should be a Support and not a Company card, and is missing from the support card section (back side of the card is the same)
p8   White Scar Terminator Company, please add 'White Scar' in front of the detachment names
p8   White Scar Bike Company as above
p14   Marine bikes shouldn't have fear
p18   Iron Father 2VPs
p21   Light and heavy Off-table Barrages have pinning classes :D I don't think they'll be needing those!
p20+25   Predator Jaghati Khan has wrong weapons
p22   Scatolo (assault) add 'ignores cover'
p22   Rapier -3 save modifier
I'm sure I'll have missed something, but I was fairly thorough (something I strongly advise for any insomniac!).  I haven't tried to print them properly yet, so that's yet to be tested, but I don't expect any problems.
Comments
1.  Please add version numbers '5.0' to both title of document, and the file name itself, so when it's updated later we know if it's up-to date.
2.  As people will use these as army selector on their own it would be useful to have a '*' marker to indicate the optional units.
3.  I would prefer the special cards to have the units name larger like the other cards, instead of the big 'special card' title.
Once the errors are changed, printing checked, and '5.0' added, then I would really like to this available for download with the netepic rules.  These cards are complete and usable, and excellent in everyway.  Also please give them a non-pdf version, so if you're busy then anyone who wants to do silhouettes or update to v5.1 can.
Much thanks to you Ulmo!!!
EDIT: Also picked up 4 errors in the SM army book itself while checking the cards, but I didn't add those above as there will be more to change to v5.1 anyway.
PostPosted: Sun Aug 05, 2007 11:57 am
(All cards have been updated)
First, much thanks for the times you put reading cards. And Space Marines is one of the worst army books.
I have reordered the pages so it should be more clear that the file should be double-face printed.
Then I have indicated optional units with parenthesis around their codex. example : Bike Company (Adeptus Astares)
instead of Bike Company *
Rapier TSM has been discussed, it is suspected to have been a typo since the very beginning, and should be taken to -2 in next version. Anyway I should keep the current -3 as I'm making 5.0 cards.
("Moral" : yet another french confusion)
Good idea :)
PostPosted: Sun Aug 05, 2007 1:25 pm
I wondered why you put parentheses around some and not others-  a note on the front page to explain, would be nice.    Your updated version looks good :) Though you missed a 't' in Astartes on the filename.
Your speed in making these astonishes me!  Or maybe it's just me that's slow.  Anyway, thanks again!
PostPosted: Sun Aug 05, 2007 8:45 pm
Start was slow, but I now have a standardized card, I just have to insert the data from the codex.
Filename corrected.
Funny, I never noticed it was "Astartes" and not "Astares". And text on cards was correct ! (happy copy/pasting).
PostPosted: Sat Aug 11, 2007 3:33 pm
Reviewed and corrected versions of :
Eldar
Ork
Squat
Tyranid
PostPosted: Sun Aug 12, 2007 5:14 am
Did I mention how awesome the cards and your help is? :D
Just in case! :;):
PostPosted: Tue Aug 28, 2007 12:25 am
(primarch @ Aug. 12 2007,05:14)
Just in case! :;):
Much thanks :)
I do not forget what's due to the NetEPIC team, now it's my time to try to be helpful.
PostPosted: Tue Aug 28, 2007 2:32 am
Ulmo, what program o you use to make the cards?
I would like to use your cards as a base for adding silouets.
I have MS Office2003 Pro and Adobe standard.
Gary
Wolf1
PostPosted: Wed Aug 29, 2007 2:04 am
Ulmo, soon all the books and army lists will be finalized. What do you need to finalize all army cards in remaining armies?
PostPosted: Wed Aug 29, 2007 1:11 pm
(gary_clark1946 @ Aug. 28 2007,02:32)
Gary
Hi,
I'm using LaTeX + some extensions (PGF). LaTeX is more or less a programming language, where you add textual commands like "write this as a title" and "put a blue square there". But if you just want to add silhouettes, you don't have to learn the whole stuff.
Still interested in ?
(primarch @ Aug. 29 2007,02:04)
If you're talking of the Smurf/Parano?a/Exodites/Undead/Ogre armies, what I need is the conviction that such armies are effectively played. And 2~3 more days.
I'm currently satisfied with the other army cards, but they probably still have some typos, and I'd like to add special rules to cards (in place of the single "special", when possible). So the possibility of updates would be a good point. If not, I'll make a final update for the 10th september.
PostPosted: Thu Aug 30, 2007 1:50 am
I have a full Horde of Evil army that I play from time to time.  Smurf actually looks proper, but I don't know anyone who plays.  Ogre list is broken.  Exodite is superceded by the official list.
Fire bad, tree pretty - Buffy
PostPosted: Thu Aug 30, 2007 2:43 am
No, just the standard armies, with the possible exception of exodites.
Send me a link or the army card files that are done to:
pramos10@cox.net
Thanks!
PostPosted: Tue Dec 04, 2007 11:54 pm
Bumpity bump.
Hey CS/Primarch, any chance of getting this one pinned?
PostPosted: Wed Dec 05, 2007 12:37 am
Duly pinned.
 Post subject: Re: Cards for NetEPIC V5
PostPosted: Thu Aug 26, 2010 12:40 am
Hi all,
I'm new to this great game, and was excited to see NetEpic as an option to play rather than the GW Epic Armageddon.
It looks like not much has been posted to this thread in awhile, but is there a reason these cards aren't available in the downloads section? NetEpic Gold has these beautiful card examples for versions 5 and 4.1, but full card sets also don't appear to be available in the downloads section and while the NetEpic Gold table of contents has a section for "cards", it's just a table...
It would be great to get these cards hosted on the site itself, instead of hidden gems here in the forum.
