Scale question
 Post subject: Scale question
PostPosted: Thu May 09, 2013 2:07 pm
Can anyone say how the Lizardmen would look next to Warmaster? Especially, how would they look next to the "small" Warmaster pieces in Battle of the Five Armies?
Related: How many lizardmen with spears make one rank on a 40mm-wide base?
 Post subject: Re: Scale question
PostPosted: Thu May 09, 2013 9:37 pm
viewtopic.php?f=119&t=24995
These are microworld beastkin, they are mounted on 40mm wide 20mm deep bases. They are roughly the same scale as the lizardmen and sculpted by the same artist.
Blind-
PostPosted: Sat May 11, 2013 12:01 am
I would say 5 comfortably, maybe 6 if they want to get cozy. I plan on doing 15 per warmaster base. I have been painting up a ton of spearmen, I will see if I can't finish a stand and post it up so you can see it.
PostPosted: Sat May 11, 2013 2:49 am
Funny that you ask this question. I just bought a Microworld Lizardman army, and decided that there were a couple WarHamster minis that I wanted to use in it. To that end, I bought GW WarMaster Skinks to introduce into my army, figuring I could use them as a different type of lizard. Now, remember that Skinks are supposed to be small in the WarMaster universe. Comparing them to Microworld 6mm, they are a little taller and quite a bit chunkier. On a scale of Perfect----Good-----Fair------Poor, they will blend Good to Fair IMO. They could be used as a beefier type of lizard for 6mm. They do stand out as a bit chunkier or beefier for sure.
We were going to base our guys 20 to a 40x40.....5 across the front row, 4 columns deep for a standard rank. That also works well with how they are sold, standard infantry coming 60 to a pack.
~ Anthony
PostPosted: Fri May 31, 2013 6:39 pm
Much later than promised, but here is a pic of some lizard spears on warmaster bases:
Users browsing this forum: Bing [Bot] and 11 guests
