6mm OKI walled corners
 Post subject: 6mm OKI walled corners
PostPosted: Sun Feb 10, 2013 3:05 pm
I have been making my moulds for the OKI corners and wanted to show you how they look and also the extra possibilities you may not have thought about.
First of all the initial corner as was originally intended:
Then of course, if you wish you could flip it around the other way:
Or you could make a small walled compound:
But then of course, you could put 4 together and make a small defensive structure:
Or you could make a bigger structure by using 4 corners, a wall and a gate section, just cut out a thin bit of plasticard for the roof and hey presto:
or or or…..
I have to go now, I am getting excited!
http://angelbarracks.co.uk/
 Post subject: Re: 6mm OKI walled corners
PostPosted: Sun Feb 10, 2013 3:25 pm
Cool design! Not so grim-dark with those soft lines, but very nice hightech concrete look.
PostPosted: Sun Feb 10, 2013 6:05 pm
Nice idea, very flexible. One question, how do the guys get up on these?
PostPosted: Sun Feb 10, 2013 6:10 pm
I did originally have a small door planned to go in one of the corners of the walls.
However whilst that would be fine for use as a corner, it would be daft if the corners were used to make stand alone buildings.
As such I opted to leave them off and suggest that if this bothers you (it does me a small amount) a simple plasticard door will suffice.
Though of course, when my 6mm window/door pack is released then bob is truly your uncle!
8)
PostPosted: Sun Feb 10, 2013 6:14 pm
Seperate doors/windows that will be useful. I'll shut up now. :)
PostPosted: Sun Feb 10, 2013 6:17 pm
No, not at all.
It is a very valid point.
One I pondered for quite a while.
PostPosted: Sun Feb 10, 2013 8:11 pm
i think it looks great, with some plasticard walkways it looks very starship troopers. 6mm doors and windows, yes please!
Fredmans
PostPosted: Sun Feb 10, 2013 9:22 pm
I concur wholeheartedly with the comments above. Love these!
