Post new topic Reply to topic  [ 192 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12, 13  Next
WorkBench Update
 Post subject: Re: WorkBench Update
PostPosted: Wed May 21, 2014 11:29 am
gotta moulding question AB – do you seal up the gaps/joints between parts with anything before moulding? if so, what/how?
Or is the rubber you use high enough viscosity that it doesn't matter?
Was just thinking that bits of textured plastic sheeting stuck together will have small gaps at the joins between faces.
Like the use of staples!
cheers
PostPosted: Wed May 21, 2014 11:35 am
Yes.
The actual making takes less time than the gap filling sometimes.
I use green stuff and or milliput to plug/fill the gaps.
Once I am 100% sure all gaps are filled, I then coat in gloss varnish to be sure, letting the varnish settle in the recesses.
The Junker buildings for example, especially the Junker dome took hours to make mould ready.
http://angelbarracks.co.uk/
PostPosted: Thu May 22, 2014 9:53 am
4th building.
Here we can see a funny door, patterned or force field/holo door, you decide.
Also I have added to this and a previous building the MKII Soper Power Generator, not as quiet or as fancy as the newer models, but solid and reliable and a good bit of kit.
PostPosted: Thu May 22, 2014 1:52 pm
Three more done.
That will do for now I think.
Just need to fill the gaps and add the detail.
Should be ready for sale in about 20 days or so.
PostPosted: Thu May 22, 2014 2:19 pm
PostPosted: Fri May 23, 2014 11:58 am
cheers
Like this:
PostPosted: Fri May 23, 2014 2:13 pm
Coming soon to a barracks near you!
Out of the moulds today:
Salvage Heaps
Structures of Unknown Origin
PostPosted: Tue May 27, 2014 6:45 pm
I like your new huts. Tempting.
PostPosted: Tue May 27, 2014 8:21 pm
Thanks.
Be tempted more!
:D
Added a roof garden to one of the SD's.
PostPosted: Tue May 27, 2014 8:37 pm
Well with the school holidays it could be Friday before I get them finished and into a mould.
Then about 10 days after that.
Soooo very roughly..
10th of June or so...?
PostPosted: Tue May 27, 2014 8:58 pm
Nice touch with the garden AB but i will have to file this of my ones as my occupants do not have/want or would even consider having a roof garden. :)
PostPosted: Tue May 27, 2014 9:00 pm
Orks?
PostPosted: Tue May 27, 2014 9:19 pm
Now being a badlands resident means the man isn't breathing down your neck, so why not get your favourite tatty armchair, complete with butt groove, stick it on your roof and drink some booze?
PostPosted: Tue May 27, 2014 9:45 pm
Thanks for the pic of the GSing/sealing. Great set of buildings shaping up there.
