Fixed EW purchased at higher Tech Levels
 Post subject: Fixed EW purchased at higher Tech Levels
PostPosted: Thu Apr 05, 2012 8:52 pm
The footnote on SW p.37 says "Fixed EW may be purchased at TL higher than 2, but has the same EW rating limitations as those of EW at a higher TL.
1. The chart shows Fixed EW at TL2 having a max of 6. Is this supposed to be 8, like EW at TL3 is?
2. Does the above footnote imply that there are 2 more levels of Fixed EW:
- Fixed EW (TL3, max 10 pts)
- Fixed EW (TL4, max 12 pts)?
This is how Im going to enter it on my data sheet. Let me know if thats wrong. Thanks!
 Post subject: Re: Fixed EW purchased at higher Tech Levels
PostPosted: Thu Apr 05, 2012 10:28 pm
The limitation for Fixed EW at TL2 (6) is correct; Fixed EW at higher TL would be TL4/8, TL5/10, TL6/12, as per 'normal' EW.
PostPosted: Thu Apr 05, 2012 11:07 pm
Awesome. Data fixed. Thanks!
