Bulkheads adding BHV to a vehicle...before or after?
 Post subject: Bulkheads adding BHV to a vehicle...before or after?
PostPosted: Mon Apr 02, 2012 9:01 pm
I see that Bulkheads are bought as a System, and add 10% to the vehicles Base Hull Value. Question: Does this 10% get added before or after the costs of other systems that are reliant on BHV for their cost?
In short (hypothetical only):
I have a vehicle that has 40 BHV based on the construction chart. I add Bulkheads, so I now have 44 BHV.
I also buy a system that costs me 50% of my BHV in points. Does it cost me 20 points, or 22 points?
Thanks,
Kealios
 Post subject: Re: Bulkheads adding BHV to a vehicle...before or after?
PostPosted: Tue Apr 03, 2012 4:10 pm
It's added to the BHV, prior to adding any components. In your example, 22 points would be correct.
PostPosted: Wed Apr 04, 2012 11:21 pm
There is no entry for Bulkheads in the SW Construction list for Systems, so I am assuming that the increase of the BHV is cost enough, eh? In other words, if I choose Bulkheads, I dont need to buy a system called "Bulkheads" - as long as I increase the BHV and then base all future cost calculations off that new BHV, Im good, right?
PostPosted: Wed Apr 04, 2012 11:26 pm
Correct; it's a modification to the base hull, not a system. :)
