Measuring Land Train weapons
 Post subject: Measuring Land Train weapons
PostPosted: Mon Nov 25, 2013 12:24 am
As the Land Train can get quite long I got to ask: how do you guys measure ranges and LOF for the LT weapons?
I just measure the range and LOF from the engine's cannon.
 Post subject: Re: Measuring Land Train weapons
PostPosted: Mon Nov 25, 2013 12:26 am
I measure it from the weapon, which I think is what you are supposed to do. From the weapon to the target model's base (of course I may be wrong here).
PostPosted: Mon Nov 25, 2013 12:45 am
From the weapons of the other cars as well? For example the berserker car cannons?
And if you are combining two barrage weapons?
It starts getting a bit more complex with the weapons from the cars
PostPosted: Mon Nov 25, 2013 1:53 am
Thanks. It makes sense. I started using the Land Train and it's size and costumizing raised quite a lot of rules questiosn for me.
PostPosted: Mon Nov 25, 2013 2:06 am
This was recently answered here.
PostPosted: Mon Nov 25, 2013 2:35 pm
I suppose how you organize your train has to do with your strategy. Not only do you have to consider ranges but the fact that the critical hit removes the back cart as well. So which car do you want to lose the least?
PostPosted: Tue Nov 26, 2013 2:43 am
Yep, I've tried so far double LT's with 3 Berserker Cars (works best one with 2 and the other with 4 cars because of BTS by the way) and and LT with Bomb Car+Berserkers for some added shields.
Both combinations pretty effective.
PostPosted: Wed Nov 27, 2013 3:13 pm
Hello !
Last wekend extactly that question occured.
Due to the fact that the land train is a war engine, tha (eventhough it consists of diffrent parts) we measured all the distances from the land train engine . A gargants weaponery is measured from the gargants center as well....
Stefan
PostPosted: Wed Nov 27, 2013 3:24 pm
1.9 Shooting Design Concept
The method used by the author (and the default you should use if you can’t agree to an alternative) is that a weapon is in range if any bit of the attacking weapon is within range of any part of the target model (or at least one of the models on a target stand).
So it's from the weapon, not the center or front or any other place, unless you agree to an alternative means of measurement of course. :)
