What's better than infantry bases cut by LASERS?
 Post subject: What's better than infantry bases cut by LASERS?
PostPosted: Mon Sep 17, 2012 1:32 pm
Injected Plastic Infantry Bases, that's what!
 Post subject: Re: What's better than infantry bases cut by LASERS?
PostPosted: Mon Sep 17, 2012 1:35 pm
Henceforth all infantry blisters sold by Troublemaker Games will use our new plastic infantry bases.
We've also got them for sale separately, should they be wanted for other uses.
PostPosted: Mon Sep 17, 2012 1:51 pm
You would be able to fit them in there but they'd be little lost - our models are 10mm scale.
The bases are 58mm x 20mm, and the holes are 10mm in diameter.
The bases are living in the "rulebook" subsection for the moment, until I create an "essentials" sub section and move them there.
http://www.freewebstore.org/troublemake ... 21302.aspx
PostPosted: Mon Sep 17, 2012 3:36 pm
Looks good !!!! You are a talented Bloke ! :D :spin Image
