Exorcist?
 Post subject: Exorcist?
PostPosted: Thu Mar 12, 2015 12:33 pm
Is this
http://www.ebay.co.uk/itm/Warhammer-40k ... 1619763791
some old version of the exorcist or just a hunter being mixed up? My idea of a sisters army is to have a female marine army, this version would work much better with that, plus its probably going to be much easier to make conversions from of whirlwinds/hunters.
If the answer seems obvious, its because I havent played 40k since the early 90ies...
 Post subject: Re: Exorcist?
PostPosted: Thu Mar 12, 2015 12:45 pm
That's the Sanctorum pattern exorcist. The one with the bling is the Prioris pattern and are ancient relics. IIRC, there's gameplay differences in 40k but at epic that'd be washed away (or should be, no reason for two of basically the same tank in the list). Basically if you've got hunters and want to swap out the turrets then go for it!
PostPosted: Thu Mar 12, 2015 12:52 pm
Excellent, thanks!
PostPosted: Thu Mar 12, 2015 1:36 pm
That's the old FW Exorcist they made before GW grafted the Phantom of the Opera to the back of a Rhino for their current release.
PostPosted: Thu Mar 12, 2015 1:58 pm
Dave... that.is.awesome. :D
