Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4
Ordo Xenos
 Post subject: Re: Ordo Xenos
PostPosted: Mon Apr 09, 2012 4:31 pm
Evil and Chaos wrote:
This is an example of some of the challenges I'm facing with taking over development of a list in mid-stream and without full knowledge of 40k hardware. Since Lord I had put this unit in the list, I presumed that it was mentioned somewhere in a codex or fluff that I haven't read. In some ways it would make more sense to use the Capitol Imperialis since it already exists.
Nope, Lord I just made it up AFAIK.
If that's the case then switching to the Capitol Imperialis makes even more sense.
PostPosted: Mon Apr 09, 2012 6:28 pm
I'm open. I'm not convinced it makes the list better or worse. It will be interesting to see if you can work it into the list.
PostPosted: Tue Apr 10, 2012 1:31 am
There's a pic of one in the old WH codex - but it's basically an Inquisitorial Capitol anyway.
If it looks like a duck and quacks...
My shifting projects
PostPosted: Wed Jul 18, 2012 1:47 am
Time for a long overdue update.
The Obsidian Fortress is being replaced with the Capitol Imperialis. Since there are no official stats, I'm going to give the following stats a try, which are based on stats proposed by Jervis.
War Engine, 10cm, Armor 4+, Close Combat 6+, Firefight 5+
Weapons: Behemoth Cannon, 75cm , 6BP, Forward, Indirect
Battle Cannon, 75 cm, AP4+/AT4+, Left Arc
Battle Cannon, 75 cm, AP4+/AT4+, Right Arc
Automated Defense System, (15cm), Small Arms,
Automated Defense System, Base Contact, Assault Weapons
NOTES: DC 10, 5 Void Shields, Reinforced Armor, Thick Rear Armor, Supreme Commander, Fearless, Transport (20, plus 3 Transport Vehicles), Firing slits: up to 10 Infantry units may fire with ranged weapons or use FF and/or CC without having to disembark.
Critical Hit Effect: Internal explosions cause one extra point of damage and D6 transported units are hit (determine randomly)
600 points
It seems to me the list needs a little more firepower. To avoid having to rely on Titans, I'm adding two units to Inducted IG Companies - a tank platoon of six Leman Russes for 375 points and an artillery battery for 250 points. The artillery battery consists of three Basilisks. I'm thinking of also allowing the option of taking three Manticores or Bombards instead.
Thoughts?
PostPosted: Wed Jul 18, 2012 5:06 am
not 100% sold on the inducted tank and basalisk formations.
RE the capitol - you ought to hash out an agreement with zombocom's Ministorium list, since AFAIK they're both the same chassis.
PostPosted: Wed Jul 18, 2012 11:29 am
Is Zombocom even doing Epic anymore?
PostPosted: Wed Jul 18, 2012 11:55 am
Firing slits is the same rule as the firing platforms in the Cadian list, I notice. Perhaps we should hash out a common name?
PostPosted: Wed Jul 18, 2012 12:10 pm
I figured he was going through one of his down phases. He's not here now, but I sorta expect to see him back in a few more months, based on the last couple of times.
PostPosted: Wed Jul 18, 2012 1:26 pm
Dwarf Supreme, it may be a good idea to PM the stats to Steve54 and Rug and then just move forward if you don't get any critique. Waiting on Zombocom to possibly return to the realm of Epic and give his feedback is only going to delay things more than necessary.
I'm curious how the tanks will be incorporated.
PostPosted: Wed Jul 18, 2012 1:59 pm
To be fair, I think Zombo's Ministorum 'Reverant Fury' is only based off of a Leviathan chassis and is actually an entirely different vehicle to both the Leviathan & the Capitol Imperialis so no reason to wait for feedback from him IMO.
Zombo's absence from epic is a concern for the Ministorum list though, it's early days yet I suppose, but worth keeping an eye on DS.
PostPosted: Thu Jul 19, 2012 10:12 am
DS - just confer with Rug over the CI and go with it. No point waiting for somebody who may or may not return. Especially when they are still 'on-board' just not commenting
www.epic-uk.co.uk
PostPosted: Fri Jul 20, 2012 12:09 am
Okay, PM sent to Rug. I don't see any point either in waiting for someone's possible return.
PostPosted: Fri Jul 20, 2012 12:11 am
What do you mean? What affect they'll have on the list?
